Where is the Vehicle Speed Sensor (VSS) located?
Old Jan 16, 2020 | 11:43 AM
06Maxima88's Avatar
Where is the Vehicle Speed Sensor (VSS) located? Manual Transmission
Hello from MI. Just bought a 2006 Maxima 6 Speed manual and I cannot seem to find the VSS (vehicle speed sensor) anywhere. All the info online shows the location for Automatics only. Do the 6 speed manuals get the speed information from another sensor?
Old Jan 16, 2020 | 12:16 PM
I revised your thread title. Saying hello and the year of your Max doesn't tell us what your question or comment is, and helps no one who uses the search engine.
Welcome the Org.
Hopefully someone will chime in and answer your question. You can start by downloading the factory service manual (FSM) for free in the link in my signature. From there, you can easily determine yourself the location of the VSS.
Typically, the VSS is located on the side of the transmission casing.
Old Jan 16, 2020 | 01:27 PM
06Maxima88's Avatar
Thank you for the revision and letting me know. After navigating the factory service manuals and locating the Manual transmission link I do not see any VSS on the manual transmission. Only a Park/Neutral position switch and the Back-up lamp switch both of which I have located on my actual vehicle. I have the slip, TCS off, Park, and ABS light on along with my Speedo not working at all.
Old Jan 16, 2020 | 04:51 PM
Was this originally an automatic and it was swapped? If so, then it sounds like the transmission module wasn't swapped along with the transmission swap.
Old Jan 16, 2020 | 06:34 PM
RA030726's Avatar
I'm nutty for Nissans
It is using an ABS sensor at the wheel.
Old Jan 20, 2020 | 01:58 PM
saig's Avatar
In component diagram, one looks like a shape of a VSS, but it is referred as 'Speedometer Pinion Gear'. It could be the location you are looking for, see item 21 in page MT-19.
tavarish
Jul 25, 2005 01:41 PM
b16cr-x
Mar 13, 2004 10:57 AM
dkris42
20
Feb 6, 2004 12:55 AM
DRN90GXE
Aug 24, 2000 09:39 AM
