CVT “downshifting” on Highway
Old Jul 26, 2020 | 01:09 AM
Oaklifornia's Avatar
So I’ve had my 07 SE Maxima for a full year and its been giving me issues preventing me from driving on the highway. If I go 70+ mphs for a period of time the car would “downshift” with the rpms shooting up to 4500-6000, I’d have to put it in neutral, coast it down to 55mph then put it back in drive for the rpms to drop back down to normal if they do at all. If it doesn’t I’d have to get off the highway and drive on the roads going no more than 50mph. It currently has 205k miles. I’ve searched all over the forums for these specific symptoms with no luck.
Old Jul 27, 2020 | 03:20 PM
User1's Avatar
Pull codes.
Old Jul 28, 2020 | 12:38 AM
Originally Posted by User1
Pull codes.
The codes I have are p0111, p0420, p0430. I’ve searched the forum regarding these codes reading threads from start to finish but I don’t see anyone mentioning anything similar my symptoms. The cats are definitely toast but would they affect the cvt in this particular way? Would the solenoid affect how the cvt knows what “gear” to be in?
Old Jul 28, 2020 | 03:26 PM
Costee's Avatar
I think you should address the codes, namely, the cats and the MAF sensor.
Old Aug 3, 2020 | 11:09 AM
I apologize I wrote the “Intake Valve Timing control Bank 1” code number incorrect it wasn’t p0111. The replacement catalytic converters are on the way. Which solenoid is bank 1? Left or right? Is the variable valve timing control solenoid the same thing?
Old Aug 3, 2020 | 12:51 PM
Costee's Avatar
It's the same. I'm not too sure of the orientation of the banks, however. One way you could determine this is to unplug the harness of each solenoid and see which throws up P0021 to identify bank2.
See this:
Watching this I guess bank1 should be the left side as it's close to the firewall. Part number is 23796-EA22B. Part number for bank2 is 23796-EA22A
Old Aug 3, 2020 | 03:14 PM
User1's Avatar
Bank 1 is firewall, bank 2 is radiator.
Old Aug 3, 2020 | 03:16 PM
Costee's Avatar
Right.
Old Aug 3, 2020 | 03:20 PM
Costee's Avatar
Did you scan the transmission (TCM)?
Old Aug 3, 2020 | 08:43 PM
Where do I look to scan it ? can I use a regular obd2 scan tool with the tcm?
Old Aug 3, 2020 | 11:44 PM
Costee's Avatar
I'm afraid not. You'd need a tool with a higher capability.
Old Aug 4, 2020 | 09:58 AM
User1's Avatar
I'm not familiar with a specific scanning tool. As far as I know, codes from all modules are stored in the ECU. I got TCM tranny codes from OBDII when my speed and turbine tranny sensors were toast. I don't think a separate tool is required, not how it works.
Old Aug 4, 2020 | 10:43 AM
Costee's Avatar
Yes, I think you're right to the extent that in a 6th Gen, for example, the TCM is linked to the ECM to light up the SES lamp. It's not correct, however, that all modules are so connected with the ECM. A code for an intelligent key (controlled by the I-Key module) in a 6.5 Gen, for example, will not light up the SES lamp.
Old Oct 9, 2020 | 10:18 AM
Roymg's Avatar
Worn motor mounts?...my 03 would do that but not to the degree you mention here.
NCSUpilot
Sep 14, 2014 03:01 PM
coolsun
Sep 26, 2012 08:43 AM
Jatan
22
Dec 4, 2009 01:42 PM
RED BARON
Dec 17, 2008 11:11 AM
MaxMaybe
Apr 23, 2007 08:23 AM
