New here please help
Old May 17, 2021 | 06:37 PM
Smokescreen_3.5's Avatar
So I have a 08 maxima with an abs issue that I’ve been beating my head with I have replaced the following parts and can seem to shake the issue
cam shaft position sensors all 3
All 4 abs sensors
the abs actuator module behind the engine on passenger side of vehicle
topped off the brake fluid
topped off the power steering fluid
changed all brake pads
On top of all that I have replaced the left rear abs sensor twice because of the car throwing a c1124 code on the scanner but all the lights (abs slip brake and tcs off ) are still on tried erasing the codes but as soon as I drive the car they come back on I’m at my whits end and can’t figure this out any help would be a blessing
Old May 20, 2021 | 03:06 AM
User1's Avatar
Post all codes and describe the "issue".
Sounds like you might have voltage/charging system problems.
Old May 20, 2021 | 03:37 PM
the only code it’s reading is c1124 for the left rear abs sensor the car is in limp mode because of it won’t go over 45mph and the following lights are on (slip abs tcs off and brake)
Old May 20, 2021 | 04:16 PM
User1's Avatar
Probably something related to the work you did with the ABS system.
Old May 20, 2021 | 04:33 PM
all I have done from this point myself was change the brakes and the abs sensors and topped off the fluids I took the vehicle to a shop to have the actuator replaced
Old May 20, 2021 | 04:34 PM
User1's Avatar
Then take it back to the shop and have them fix their screw-up.
moudmah1
Jan 28, 2014 02:37 PM
TunerMaxima3000
Jan 9, 2013 02:19 PM
stansharp
Oct 27, 2009 11:11 AM
alextothestars
Apr 4, 2009 09:23 AM
ymax
Dec 19, 2001 05:12 AM
