What a mess
Old Jul 11, 2021 | 05:51 AM
Jocahox's Avatar
What a mess
I have 2004 maxima I changed out camshaft sensor w cheap one the didn’t work you push the gas and go nowhere pulled code of replace throttle body sensor and camshaft sensors and maf for good measure
has anyone else happen to them and what was the fix replacing it all ? Also it started to overheat while I was pulling codes
Old Jul 11, 2021 | 09:38 AM
Reality sucks's Avatar
Your Right this is a Mess.
If that is the only code you have, then start there. Did you relearn the throttle Body..?
you can get this code for several reasons.. First I ask what is the charge Voltage from the alternator.?
On that scan tool, I know your somewhat limited but under its functions see if you have any live data.. see what its capable of showing you. look at the TP values if avail.
bvb_09
Jan 5, 2016 07:22 PM
Deemadbeats
Dec 25, 2014 12:58 AM
Sean_a33
Aug 26, 2014 11:20 PM
wiseguy746
Nov 9, 2012 07:55 AM
MaxEx
Sep 22, 2011 09:12 PM
