Help! I'm new here and have a question....
Old Dec 2, 2011 | 02:00 PM
  #1241
mseals's Avatar
you might be right
I think you may be headed in the right direction. When I start my car, the HVAC system resumes whatever it was doing when I turned the car off.
After 5 days I also noticed that the remote key fobs don't work to lock/unlock the car and open up the trunk. I could see this being the case where these items are disabled for storage or transport. It is a 2011 that I got new as the sales managers demo. He stated that he had never triedt he remotes when he drove the car. It makes sense because I went 5 days before I just wanted to make sure I locked the car and tried the key. Every other time I am right there and use the handle. I tried both keys and neither of them work.
Old Dec 3, 2011 | 06:33 PM
  #1242
lightonthehill's Avatar
If the batteries in your fobs were getting weak (or dead), you would get a display telling you that on your dash every time you started the car. So your situation almost has to be the shipping/storage setup. The dealer should handle that fairly quickly, and should give you an apology and something like a free oil change for your trouble.
Old Dec 10, 2011 | 11:48 AM
  #1243
mseals's Avatar
The fix
I just wanted to follow up with everyone and let them know the fix. It turns out that my car was in "storage" mode. This is used when the car is first built so that is has a little draw on the battery as possible during transport and storage. It took them all of 5 seconds to get it out of storage mode. You simply hold down the turn signal and wiper stalks at the same time for a few seconds and viola it is in normal mode. My car now keeps the settings for heat and radio as when it was last turned off. Before I had to turn the climate control and radio on every time.
Old Dec 12, 2011 | 08:24 AM
  #1244
Nemo7's Avatar
I have a 2009 S so I do not have stock fogs if I buy some fog lights is it plug and play or do I have to do some wiring in order for it to work?
Old Dec 13, 2011 | 07:59 PM
  #1245
ksellers10's Avatar
i have a few led mods ide like to do but i am not savvy when it comes to stuff like that but i dont wanna pay 490$ to have it done lol so my question is for led strip lights with neg and positive connections how hard is it to do? considering the max doesnt have drl lights how do i connect them to be drl's or to come on as soon as the car is started?
Old Dec 14, 2011 | 05:39 AM
  #1246
Kmoney's Avatar
Get the DRL n purchase the automatic relay switch n connect that to the battery
Old Dec 14, 2011 | 09:36 AM
  #1247
ksellers10's Avatar
Is that by far the easiest way for a new-bee?
Old Dec 14, 2011 | 02:59 PM
  #1248
Kmoney's Avatar
Yea for someone new.
Old Dec 14, 2011 | 04:55 PM
  #1249
ksellers10's Avatar
have you done an led mod on 7th gen if so will i have to remove the front bumber to remove the headlights?
Old Dec 15, 2011 | 08:50 PM
  #1250
HOH_Maxima's Avatar
So I am a recently joining member, but have been slowly looking over the site now for the past month. I have tried alot of things with my 11 S model but they have never worked, damn internet sites lying about things. What i need is an HID kit for heads and fogs, plus a good sit to by fogs from since the S model does not come with fogs. I feel the car would look complete since i have the SV spoiler installed I just need fogs, and then a good 6k hid kit for both. Any help would be much appreciated, im tired of cheap websites.
Old Dec 15, 2011 | 09:09 PM
  #1251
Kmoney's Avatar
Vleds for hid kits. As for OEM fogs, try eBay or courtesy Nissan part. Com
Old Dec 15, 2011 | 09:26 PM
  #1252
HOH_Maxima's Avatar
Thank you, already ordered the h11 6k kit from their, as for fogs would i need to buy another h11 kit or could i just change those bulbs?
http://www.dashzracing.com/09-11-nis...nm10-f-sm.html
i came across these fogs that have an option of adding H11 6k HID to them before the order...would these fit my 11, because i had bought previous Fogs that were "supposed" to fit and didn't, i dont wanna go through that trouble again. Also would these HID match the headlights?
Old Dec 16, 2011 | 02:39 AM
  #1253
Kmoney's Avatar
If u want hid on fog Then u need another h11 kit. It should fit. The title said it fit 09-11 Max
Old Dec 20, 2011 | 12:50 PM
  #1254
ksellers10's Avatar
another question
I dont want to waste money on mods. So i want a tighgter on center steering feel and less body roll. I come from a VW CC which we all know how german car steering is. How can i achieve this feel through mods. I read that i may have to lower the car then i read i need a sway bar and a front tower bar idk can someone help please?
Old Dec 22, 2011 | 05:24 AM
  #1255
Fundem's Avatar
I HAVE A QUESTION... WHEN I FLOOR MY CAR (2011 W/ SPORT) THERE SEEMS TO BE A "BUTTON" AT THE BOTTOM OF THE PEDAL. IF I FLOOR IT, IT'LL GO.. BUT IF I PUSH DOWN HARDER (ALL THE WAY TO THE FLOOR) IT FEELS LIKE THE PEDAL CLICKS A BUTTON OF SOME SORT AT THE BOTTOM... DOES ANYONE KNOW WHAT THAT IS?
THANKS,
DAN
Old Dec 23, 2011 | 01:28 PM
  #1256
richar52_99@rogers.com's Avatar
Creaking / Cracking noise
Does any one who owns a 2010 Max. have this sound somewhere in the body/frame in the rear of the car sometimes when you hit a bump??? It's not all the time, but it drives you crazzzzzzzzzy!!
Old Dec 27, 2011 | 07:00 AM
  #1257
slava2006's Avatar
THANKS,
DAN
Mine does the same thing and so the does any other nissan with a cvt that i have driven never figured what it does though!!
Old Dec 27, 2011 | 08:43 PM
  #1258
Dieseldan's Avatar
i noticed that also very weird
Old Dec 27, 2011 | 09:11 PM
  #1259
slicknick's Avatar
My buddy calls it the "kick plate", when given throttle it pushes the plate and gives full power for whatever speed you are at. Like an automatic car that downshifts for maximum power. Then again...he does a lot of drugs.
Old Jan 1, 2012 | 01:19 PM
  #1260
bw1128's Avatar
with the navi on my 2011 maxima, can you have a split screen showing half nav and half radio, like the channel info and artist/song info? my motherinlaws jeep does this i like how you can view all the info and have the map up at the same time, rather than our map with just the ch#. hopefully im just missing something.
Old Jan 2, 2012 | 05:54 AM
  #1261
jasn's Avatar
I too wish the display would list both the Artist and Song Title in the lower part of the map screen. The best you can get is by pushing "Status" to display the song info at the top and route info on the bottom. Then again, that will only work if you have a destination provided.
Old Jan 2, 2012 | 06:34 AM
  #1262
eljoker's Avatar
Hey guys new here,
Bought on the 31st 32k miles, $24ishk plus negative added for impala.
09 Maxima, Leather, sunroof, heated seats and stearing wheel, bluetooth, non nav, non bose. I think its an SV. does have red stiching tho!. How do I know if its sport? And can some one verify it is SV? Sorry its been a long time since I jumped back into the Nissans. Ive been on the G37 boards way to long
Mods (planned at least.)
1st. Led and HID upgrades. (1/2 way complete 1/1/12)
2nd. Redo tint and add Bats overlays. Maybe black roof.
3rd. Idk, Vossens or RennForged.
4th, Akenbo BBK, just for looks (i think they will fit, might be 1st ever???)
Old Jan 2, 2012 | 08:11 AM
  #1263
Car Addict's Avatar
Sport has silver stitching, spoiler, 19s and no wood grain. Sv has leather and fog lights I believe.
Old Jan 2, 2012 | 08:30 AM
  #1264
eljoker's Avatar
Well I have leather, 19s, fogs, heated everything, paddles, and HIDs. I take it I have an SV sport?
Old Jan 2, 2012 | 02:07 PM
  #1265
Car Addict's Avatar
sounds like it. i think the easiest way to tell is if it has wood. the 19s could've been added.
sport
premium
Old Jan 2, 2012 | 03:29 PM
  #1266
w06ejmm's Avatar
For those of you with Navigation, how often does NAVTEQ update maps? My 2011 Max's maps are seriously behind yet the NAVTEQ website continues to tell me I have the latest maps. I mean in the area where I live, it is 5 years behind on some of the streets. So far, I'm really dissapointed in the navigation package. I have little trust in it. With the Garmin I use in my other car, I get 4 map updates a year and have a lot more faith in it than the built in navi on the Max. Other opinions? Comments?
Old Jan 2, 2012 | 08:25 PM
  #1267
Unless they have changed recently, I believe NAVTEQ only releases a new version around once a year. I updated my nav around 18 months ago, and still do not have some subdivisions near me that had their streets in place in 2006. Yes, I found that a little disappointing.
Old Jan 3, 2012 | 08:23 AM
  #1268
eljoker's Avatar
Ok so I dont know what kind of oil was used last in it but I work at a dealership and get my oil changes for free. Can I jump straight to Synthetic? I get mobile one for free. 32K miles on it.
Old Jan 3, 2012 | 10:06 AM
  #1269
Robdog289's Avatar
Can someone tell me how to change display color or monitor, I can only seem to get it to go light and dark. It has 1-9 on it when i am in the display settings but i can't scroll through colors. Or am i just plain wrong and you can't change the colors. I have the monitor package, no nav. 2011 sv premium.
Old Jan 3, 2012 | 11:20 AM
  #1270
At 32K miles, no matter what oil may currently be in your car, you can jump to any kind of good oil your heart may desire. If you can get Mobile1 for free, grab it. Your car will love it.
Old Jan 3, 2012 | 12:12 PM
  #1271
Car Addict's Avatar
Color theme:
Select the “Display” key, then select the “Color
Theme” key. The Color Theme select screen will
appear.
Select the key for the desired color. The appear-
ance of the background, arrows and bars will
change for all screens accordingly. You can
choose a black, blue or red color theme.
Old Jan 3, 2012 | 02:36 PM
  #1272
esco115's Avatar
This is correct once a year at the end and/or the beginning of the year.
FYI no matter what car brand anyone desire if they use NAVTEQ its all the same whether its a AMG E63 or a Prius...
Old Jan 4, 2012 | 08:15 AM
  #1273
brooklynyc1's Avatar
need help! i have a 2009 maxima s with roughly 18000 miles and up to date with oil change(mobile1). its about 20 degrees Fahrenheit outside and my car wont start. all electrical turn radio, speedometer, headlights etc but the engine hesitates to start. cleaned the battery from corrosion but to no avail. would call a tow truck but car is in my back yard.
Old Jan 4, 2012 | 10:55 AM
  #1274
StLDave's Avatar
Windshield Washer
Been signed up for a bit, need some help. My son drove his 2011 in this weekend, windshield washers worked fine. He got ready to leave the other morning and mentioned his washers quit working. I filled up the reservoir, but it still did not work. He assures me he never put straight water into the tank. It is now warmer out and it still does not work.
Any thoughts? It there a fuse on this? Is pump under the tank or somewhere else?
Old Jan 4, 2012 | 12:53 PM
  #1275
w06ejmm's Avatar
It's interesting that the Maxima and Garmin updates both come from NAVTEQ, yet the Maxima maps are so far behind.
Old Jan 4, 2012 | 04:09 PM
  #1276
esco115's Avatar
Its not ONLY maxima's... Every car brand that uses NAVTEQ are the same... there are streets that have been around for years and my TL nor my Maxima picks it up... Drove around my buddies 2011 XJ and same ****.. lol
Cant comment on Garmin I ready dont know...
Old Jan 8, 2012 | 11:11 AM
  #1277
slava2006's Avatar
ur buddy is right though if u put your max into sixth or any other high gear and floor it ill down shift automatically and your car will take off like a bullet. --------->
Old Jan 9, 2012 | 01:45 PM
  #1278
tjack57's Avatar
power steering force
Hi,
I have a 2011 Max with 11000 miles on it. I have a question about the additional force required to steer at highway speeds. It borders on actually being tiring to make the usual little steering corrections needed while driving. It is especially annoying when driving long distances. I understand there is a REDUCED power assist at faster speed (the faster you go the less assist). Is it possible to electrically disconnect this so called benefit?? If so what would be the downside? I have had it to the dealer and he said he can't find anything wrong.
thanks for any help.
Old Jan 9, 2012 | 04:06 PM
  #1279
Cleary D's Avatar
One time this happened to me in a parking lot, I took off the battery wires and placed them back on and tightened them up and it started right up, also, your battery may just be dead and able to power up the basics, this happened when my first battery went out, not sure but thats what I would try to go with.
Old Jan 9, 2012 | 04:47 PM
  #1280
eljoker's Avatar
Any one have any idea what bulb size the vanity mirros are?
