HID/Headlight/Foglight combo thread.
Old Sep 17, 2012 | 12:43 PM
  #761
eljoker's Avatar
Originally Posted by Utz716
Hey everyone
I just installed Hoen Xenonmatch (low beam) and Endurance (fog light) last night. I haven't driven yet. But the headlamps seem a little "dim"...maybe I am just too used to the yellowish of the stock halogen bulbs. The fog lights are outstanding!!
I was thinking it could be because of the projector headlamps. I have read other articles for years that projector headlamps can be problematic when using different types of bulbs.
Anyone have any xperience with these? I do like the way the Crystal Visions turned out. I might use those in my headlamps if I end up changing. I will have pics later tonight.
What temp bulbs did you get for your low beams? I put 8000k on mine and it is alot dimmer than the ones that came on it stock which was 4300K. The projectors in the maxi-ma make the 8000ks dimmer than the halogen headlights i had in my impala with an 8000k hod kit on.
Im currently looking into 6000k or 5500k (if i can find them) for my next sett up.
Old Sep 17, 2012 | 04:37 PM
  #762
Utz716's Avatar
They are 4300K. I was thinking of trying Phillips Clearvision after some night driving.
Old Sep 30, 2012 | 06:44 PM
  #763
Triaxtremec's Avatar
recommendations on matching color high beams for both the 6000k and 5000k HID lamps?
I have the 6000k in my Max and the 5000K in the wife's Edge. Bought the top of the line sylvania silverstars and they are bright but don't match my 6000k's at all.
Old Oct 8, 2012 | 09:38 AM
  #764
slyslate07's Avatar
I think this is as good a place as any to post this. I recently changes my stock fog bulbs out for nokya yellow halogens. I wanted to try these first before investing the $ on HIDs. I like how they look. I followed video instructions found through a google search. I did not remove the wheel.
I did the first bulb (driver's side) this way and found I could create enough room to get my hand/arm in there. When I went to do that passenger side bulb, my arm was getting pinched and I did not have as much room behind the bumper cover because of the windshield wash fluid reservoir.
I instead removed the clips on the bottom of the bumper, peeled back the plastic, and reached up right behind the bulb to remove it. I hadn't seen this done or mentioned on here before.
fire those of you that don't want to remove your wheel to change fog bulbs, I would recommend this methods. note that you still have to remove the clip inn each wheel well and the 3 screws on the bottom of the bumper near the wheel.
Old Dec 10, 2012 | 06:47 AM
  #765
avusm3's Avatar
I am replacing the Halogen low beam bulbs on my '10 S with HIDs. Should I get a wiring harness that includes Can-Bus support? Is that needed on a '10 Maxima or should I just go with standard relays?
Thanx.
Old Dec 10, 2012 | 07:17 AM
  #766
PSU09MAXIMA's Avatar
Thanx.
Standard relays are all you need
Old Dec 10, 2012 | 08:50 AM
  #767
avusm3's Avatar
Thanx!
Old Dec 10, 2012 | 06:07 PM
  #768
Timmy's Avatar
Originally Posted by Triaxtremec
are most of you replacing the low beams or both high and low? I just purchased a 2009 and was thinking of getting a kit for mod-express.com but not sure should I do both for just the low beams.
most people do just low beams and fogs... im going to do high beams as well eventually lol
Old Jan 12, 2013 | 09:17 PM
  #769
MaxFrost2011's Avatar
To me, on our cars, it looks "ugly" to have the factory HID's with halogen fog lights, so I will be changing them out to HID. My issue is that I can't decide on which color to get. From the posts it seems the factory HID bulbs are 4300K which I am happy with. I would like the fog lights to match, so should I get the 4300K or 6000K?
From the color charts, it appears as though the 4300K has a yellow tint but mine seem more white than yellow? Anyone have any pics of factory HID's with 4300K or 6000K fog lights?
Old Jan 13, 2013 | 10:19 AM
  #770
Car Addict's Avatar
Even though the stock HIDs are 4300k, what gives them the slight blueish color are the projectors. Since the the fog lights have reflectors, you'd need 5000k to 6000k for them to match.
Old Jan 13, 2013 | 11:17 AM
  #771
Jig9798's Avatar
No freakin way! Ever seen a 7th Gen coming up in your rearview with lights blazing???
Thing looks like a friggin BEAST!
I think the halogen fogs actually over emphasizes the HIDs. And I absolutely love the placement of the fogs ... just inside the headlights. Definitely contributes to the sporty/aggressive styling of the Max.
Old Jan 13, 2013 | 08:03 PM
  #772
Thanks! Going to go 6000k.
Haha, I agree with you about styling and placement, but I think the halogens take away from the HIDs. I could turn them off, lol.
Old Jan 16, 2013 | 11:20 AM
  #773
Staggered357's Avatar
6k headlights
8k fogs
Old Jan 17, 2013 | 09:00 AM
  #774
doberman16's Avatar
I'm looking into getting this kit:
http://store.ijdmtoy.com/Projector-H...ctor_sku76.htm
Since its "universal", I'm looking for input from people who've opened up the front bumper underneath. Do you think those brackets will install pretty easily? I'm sure I'll have to drill, but I haven't seen that part of the car yet and I'd like to know what to expect.
Old Jan 17, 2013 | 11:26 AM
  #775
When changing to HID's in the fog lights, do you lose brightness compared to stock since they are not projector style?
Old Jan 17, 2013 | 12:45 PM
  #776
Ryan31's Avatar
That all depends, if you stay within the 3000k (yellow) 4300k (Brightest) - 6000k (Border line blue) it will still be pretty good. Going to 8000k will look extremely bright but visibility will be shot.
Old Jan 19, 2013 | 03:46 AM
  #777
Great, thanks Ryan. I order the 6k yesterday and hopefully will get them installed later today!
Old Jan 24, 2013 | 09:16 PM
  #778
wope's Avatar
What is the best set of aftermarket HIDs to get these days? I haven't bought any since around 2009, and am in need of a new set. Looking for 4300K or 5000K in H11. Whats good these days? I don't care about price. Is there anything besides the Chinese kits on eBay?
Old Jan 24, 2013 | 10:42 PM
  #779
Car Addict's Avatar
oracle or philips
Old Jan 24, 2013 | 10:48 PM
  #780
hero782's Avatar
oracle or philips
Oracle? Do you mean Osram? Best hids are oem components. Best aftermarket are the Morimoto from TRS.
Old Jan 25, 2013 | 12:06 AM
  #781
Car Addict's Avatar
oracle. i know of a lot of people that used them.
Old Jan 25, 2013 | 06:21 PM
  #782
I just bought 4 sets from www.hidnation.com we tested them on a mustang and they are decent been running for about a week now no issues... I will be buying my kits from them here on out...
Old Apr 18, 2013 | 11:54 AM
  #783
wope's Avatar
Does anyone have any pictures of where they mounted their relays?
Old Apr 21, 2013 | 06:15 AM
  #784
Propa Teknique's Avatar
I have fog lights that I had never mounted on my 6th gen and I believe they were H11 with the ballasts. they came off of a 6.5 gen. Would those work in my 7th gen Max?
Old Apr 24, 2013 | 06:19 PM
  #785
kneehead's Avatar
[IMG][/IMG]
Just Installed 10k with stock fogs
Old Apr 25, 2013 | 06:39 AM
  #786
Blackmax12's Avatar
Wow. Those are gonna sear some retinas! Very nice. I have stock HID headlights and would like to do a simple upgrade (bulb change) to my fogs. Any recommendations?
Old Apr 25, 2013 | 06:55 AM
  #787
Blackmax12's Avatar
I find that my stock HIDs have a sharp drop off. I realize that's a function of the reflectors and not the bulbs but do the brighter bulbs help with that? The length of the beam seems a bit short to me. The HIDs in my 5th gen seemed to light up the world.
Old Jul 15, 2013 | 07:22 AM
  #788
RudeMax2012's Avatar
Does anyone know if it is ok to have 55w HIDs with no relay?
Old Jul 15, 2013 | 06:48 PM
  #789
acdna's Avatar
Just finished my Ford Fusion projector fog light retrofit. Now I've got color flicker on my fogs too
Running 5000K Osram CBI bulbs for my low beams and 4300K Morimoto XB35 bulbs for my fog lights. I can say that driving at night is a true pleasure.
Old Jul 15, 2013 | 07:24 PM
  #790
escblads's Avatar
I highly don't recommended it b/c you will have issues down the road from your headlight harness wires being worn from the strain of starting those 55w ballasts.
Old Jun 26, 2014 | 01:59 PM
  #791
MidnightMaxima_22's Avatar
i installed sum 10000k hids onmy headlights and one seems to be more blue than the other does anyone know why this might be??.. also sumtimes my lights go off if itry to turn them on manually... help anyone??
Old Jul 1, 2014 | 07:31 AM
  #792
cali760's Avatar
i have a 12 limited edition. with stock hids i want to see a little farther at night what bulb should i choose?
Old Jul 4, 2014 | 08:41 PM
  #793
Mike11SV's Avatar
Go with the ones acdna has, 5000K Osram CBI D2S
Old Sep 25, 2014 | 10:24 AM
  #794
CharlieSuede's Avatar
Has anyone successfully installed fog light with the associated relay harness???
Old Dec 17, 2019 | 07:22 PM
  #795
levonlynch's Avatar
Originally Posted by COOLWHP
Mind you my headlights are tinted slightly. But here are a couple shots I took with my cell phone. It looks way better in person.
Are those 8000k ice blue fogs?
Ben2003GLE
31
Jul 17, 2016 08:13 AM
TheMafia
Sep 4, 2015 08:26 AM
Maxima_Joe
Aug 27, 2015 12:01 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Superbform
Aug 11, 2015 08:10 PM
