Remote start?
Old Feb 1, 2011 | 01:19 PM
  #121
Maxfanatic's Avatar
Viper alarm causing check engine light to come on
Hey has anyone had a problem with the viper alarm causing the check engine light to come on 2009 nissan maxima?
Old Feb 1, 2011 | 02:02 PM
  #122
maxima1010's Avatar
My Viper Smart Start doesn't turn on my check engine light. But after I get into the car and take over with my Intelli key, my security light and electronic steering lock light (yellow-colored "KEY" light) both come on my dash. When I just start my car with the push button, I have no issues.
Is anyone experiencing anything like this? To the other guys with a Viper Smart Start, do you have a flawless takeover?
I want to know if I really have a problem, or if this is happening with everyone.
Old Feb 1, 2011 | 02:15 PM
  #123
Ghozt's Avatar
if your car alarm goes off, does it show you on the SmartStart app?
Old Feb 1, 2011 | 02:16 PM
  #124
maxima1010's Avatar
I have had the Viper VSS4000 installed in my Max. Works great! The only issue is when I get in my car and step on the brake, my security light (red-colored light) and my electronic steering wheel lock (yellow colored "KEY" light) both come on. My car doesn't shut down or anything, so it is a smooth takeover. But it looks like there is an issue. I had Best Buy do the install, and the guy never did this type of car before. I know, I shouldn't have taken it to them, but they are the only ones around that sell the SmartStart. They did a terrible job, with messy wiring. Really sloppy. They called customer service and they couldn't figure it out.
Juggernaut23: Can you help me please!?!? Can you tell me how you wired everything so I can compare to mine?? Thanks!!
Old Feb 15, 2011 | 08:22 AM
  #125
Maxfanatic's Avatar
You know what i haven't checked my Iphone and see if it was giving me a notice. I'll do that today. Well this Friday i'm taking my car to another authorized Viper installer to see if they can fix this check engine light issue. getting kinda fustrated now its been 2 weeks since i got my car back and that damn light won't go off. I don't want to pull the alarm but i might have no choice.
Old Feb 15, 2011 | 06:09 PM
  #126
Juggernaut23's Avatar
Guys,the only time I see those lights on the dash is when I dont close my doors when I get in prior to tapping the brake for the take over.Then it trips the yellow key light and the tpms light.But no ill effects.
I need to know which bypass they used to guide you to the correction. I really like this type of system but I hope they fix some of the irritating quirks of it soon.It has the potential to be the best with just a few more tweaks and refinement.
Old Feb 16, 2011 | 03:59 PM
  #127
maxima1010's Avatar
I used the FLCAN bypass by Audiovox. Actually, this bypass is made by idatalink, who I think made the one you are using. My remote start module is a Viper 5101.
If you go to www.flash-it.com, and look up the installation guide for a 2010 Max, that is exactly how it is installed in my car.
Old Feb 16, 2011 | 04:32 PM
  #128
There is 3 of them listed in that link.Which is the one you followed? ni3,ni2,ni1?
Iam using the idatalink and i did all 3 of the take over routes. I did the relay under the hood and the door trigger with the proximity key sensor.it only said to do 1 of them but i did all 3 to ensure there is no issues.
After opening the pdf i did the relay under the hood and grounded the purple/yellow wire.I also just tap the break to do the take over every time i get in the car. The pdf says you have to push the start button twice prior but i dont.and mine stays running with no issues.do a reset on the module and try again to see if it helps.
I also noticed page 3 and page 36 say to do the take over 2 different ways. lol lol lol lo
Old Mar 6, 2011 | 09:35 PM
  #129
uberdrift's Avatar
Are you unable to get it from the factory?
Old Apr 18, 2011 | 10:54 AM
  #130
ehyoitzjeffo's Avatar
For those who have the viper 5901, I was wondering what aux options did u add for convenience and does the shop make u pay for each of the aux setup
Old Apr 19, 2011 | 04:53 PM
  #131
2010maximaS's Avatar
most shops will charge for an aux. i dont.. unless its something complex. you can do 2 front windows and sunroof.. other than that anything else would be a pain in the but
Old Apr 19, 2011 | 11:07 PM
  #132
What about windshield defroster and heated steering wheel. Will it be a pain to install?
Old Apr 26, 2011 | 08:57 AM
  #133
Ghozt's Avatar
Did you all have you Viper alarm installed by a Viper authorized dealer or the Nissan dealership? I want to get the 5902 in my whip but have read some stories on here about people not knowing how to install it in the Max and would rather avoid that. Think I'm okay with hunting down a Viper authorized shop and just ask if they've done 7th gen Maximas? Also does anyone have a hook up on the actual alarm system itself? Just seeing if I can avoid paying retail.
Old May 27, 2011 | 06:25 PM
  #134
jgrimberg1979's Avatar
2 front windows?? Why only the front two? I Installed the viper 5901 myself and it took about 10 mins to hook my aux 1 to lock switch on the drivers side door and aux 2 to unlock. Aux 1 set to pulsed and linked to arm so when I get put and arm my car it automatically rolls up four windows. And to rol
Them down I just press f f aux to roll them down. To roll them up at any given moment rather than arming it I hit f aux. It was so easy to do and free as opposed to buying the dei window module which is completely unnecessary
Old Jun 4, 2011 | 06:29 PM
  #135
ru0023's Avatar
how does the autostart affect auto adjusting seats... more specifically .. when i sit in the car and start the engine.. the seat moves in and steering wheel comes down... if i auto start the car.. will it do this before i get in the car?
Old Jun 16, 2011 | 01:54 PM
  #136
bigwally's Avatar
I just had remote start installed on my 2011 Maxima and it works great so far, not sure of the names of the components used but I love the way it operates, on mine you push the lock button on the oem fob twice and the car starts, once you enter the car you have 30 secs to push the brake pedal and once you push the brake pedal the ignition switch automatically goes to the on position and the seat and steering wheel go to the set position. I hope this helps and if anyone needs the parts used, I can find out, and btw it took over 8 hours for the install and cost me $450
Old Jun 16, 2011 | 03:23 PM
  #137
Scott_L's Avatar
Sounds great! I'd like to know what system was installed.
Old Jun 17, 2011 | 06:58 AM
  #138
bigwally's Avatar
ok, I called the shop this morning to ask what parts they used on my Maxima and the guy told me the remote start module was by Avital and he used 2 bypass modules, one by Directed Electronics and one by Omega, I hope this helps, btw I just had remote start only, no alarm
Old Jun 17, 2011 | 12:04 PM
  #139
Scott_L's Avatar
Thanks. I'm not sure if this is unique or not but I love that it's integrated into the OEM key fob.
Old Jun 17, 2011 | 05:52 PM
  #140
bigwally's Avatar
I think other people on here have it integrated into the oem key fob, I really like that i dont have to push the ignition button to the on position or adjust the seat or steering wheel, its done automatically when u push the brake pedal when you enter the car. I hope this helps you
Old Jun 18, 2011 | 06:57 AM
  #141
bluelion's Avatar
Sounds perfect....now that its summer time in Houston, I'm really wishing I had that...I've been using the auto window down and although it helps a lil, I really wish I could start the car for the a/c...
Old Jun 21, 2011 | 11:19 AM
  #142
jspagna's Avatar
The Avital System is what i have had on my 4Runner for the last 10 years and still works great and am very happy with it. I can't believe that Nissan does'nt offer a Remote Start as an accessory for the car. Any enrty level luxury car should IMO. Having to go to the Aftermarket for it is a PIA.
Old Jun 22, 2011 | 08:35 PM
  #143
Lani's Avatar
Just bought a Viper 5902... so which bypass and or bypasses are needed?
Old Sep 17, 2011 | 03:46 PM
  #144
bw1128's Avatar
so whats the best remote start that uses the oem remote or smart phone? i just dont want to have to carry around 2 different remotes.
Old Sep 17, 2011 | 09:04 PM
  #145
Ghozt's Avatar
Dont get just the viper vss system lots of people complain about the smartstart app not working. I got the viper 5902 and its a second keyfob but not much you can do to avoid that.
Old Sep 18, 2011 | 11:01 AM
  #146
bw1128's Avatar
How can I get the remote start to work with my oem remote?
Old Sep 18, 2011 | 05:05 PM
  #147
Maximum Drive's Avatar
Ummm....Did you try reading any part of this thread at all?
Old Sep 22, 2011 | 01:59 PM
  #148
bw1128's Avatar
i did but i cant seem to find anyone in the central texas area that is even willing to do a remote start on our vehicle. they dont know how to do the remote start on a push button start car. this stinks!
Old Sep 25, 2011 | 05:19 AM
  #149
Ghozt's Avatar
have you tried using the Viper website to find an authorized dealer near you? i used that and it came up with a long list of options, the first few i called said the same thing they've never done push button start but the 4th place I called had done the new Max's before so it was money. i love the remote start..nothin like having your car already warmed up ready to go.
Old Oct 17, 2011 | 11:21 AM
  #150
slvr_4dsc's Avatar
So if I understand your post correctly, I do not need to purchase any additional module to make the windows roll up automatically when I lock my car. This functionality is built into Viper 5901 and its just the matter of configuring it?
Also, if I use iDatalink bypass module with a viper 5901 and lock the car using Viper security alarm, can I retain all the push button functionality including unlocking doors and popping the trunk using push button on the door handles and trunk release respectively? In other words, can I use my OEM key fob to arm and disarm viper alarm?
I would appreciate if you or someone on this forum is kind enough to help me with my questions. By the way, which idatalink bypass module do i need for my 2009 Maxima? Thanks in advance.
Old Oct 17, 2011 | 12:01 PM
  #151
Ghozt's Avatar
nah the windows rolling up when you lock is a feature of the car. as far as i know Maxima's do not do this, at least mine doesn't. no idea how this member wired up to the lock button to get his windows to roll up/down.
yes you can still use your OEM keyfob to unlock/lock/disarm/arm. just no remote start obviously since theres no button for that.
not sure on which idatalink module u need.
also in case u didnt know, by wiring this up yourself you're potentially voiding all kinds of Nissan warranties in addition to the warranty on the alarm itself. if you ever have any electrical issues with the car they'll open your fusebox see all the splicing and blame that. if its done at an authorized installer they cant void anything
Old Oct 17, 2011 | 12:59 PM
  #152
20_Maxima_10's Avatar
I am an installer and I just ordered the Viper Smart Start VSS5000 for my Max. The reason for this is I didn't want to carry around two seperate remotes being that the smart key is the remote as well. The bypass i'm using allows every to be controlled via data and the added bonus is that the factory remote will also control the aftermarket security portion of the alarm system. The only thing that I can't do from the factory remote is remote start the car, which is what I will use my phone to do.
I am going to do my research as far as using the buttons on the door handles to arm and disarm the viper alarm though. If I can't do this I might consider not doing the install at all. I am one for must having full functionality of all factory and aftermarket systems.
Old Oct 17, 2011 | 01:19 PM
  #153
slvr_4dsc's Avatar
Thanks for your response. So, I guess I would have to pay extra to roll up my windows. I can live without it.
How about the tilt sensor? is that included or do I need to purchase that module separately?
Just to confirm, you are saying that I can control Viper's security system using my Nissan key fob? So, lets say I arm my car by pressing the button on the driver's side door handle, then Viper's LCD screen will show that the car is locked?
If anyone can provide a link to the idatalink bypass module that I need for 2009 Maxima, I will greatly appreciate it.
I am not even thinking about installing this myself. I am buying the unit from Amazon and having one of the authroized dealers in Queens install it for me, name of the shop is USS Auto on Hillside. I dont believe this would void the warranty. Did any of the members here had any experience with this shop? I have been trying to reach out to PearlMax A.K.A Don but can't seem to get a hold of him.
Old Oct 17, 2011 | 01:26 PM
  #154
Ghozt's Avatar
oh, if you're an installer i'm pretty sure you can call Viper directly and they'll help you out. my installer had some trouble with my 5902 and Viper helped them out no problem.
nice part is the remotes are completely integrated. the Nissan keyfob (and the buttons on the doors) lock/arm and unlock/disarm. the only thing missing are the added features of the Viper remote which you wont need to carry if you have Smartstart. carrying around 2 keyfobs IS getting annoying. plus if you get the leather case for the 5902 remote it's comically large
well not sure if the feature isn't available at all, i know theres a window roll-up module (and sun roof open/close) that may be added. not positive if it works on the 7th gen's though.
Tilt sensor is an extra module with extra labor to install unfortunately.
and yeah you can use the Nissan keyfob, you'll see the word "ARMED" appear on your Viper LCD a few seconds later. likewise UNARMED if you unlock it.
honestly you'll probably pay just as much getting the Viper online + install that you would if you just paid for the unit + install at a Viper dealer. They get big discounts on the units so will charge you 300-500 in labor anyway so might as well combine it. Also a few Viper places will not honor warranty on any items purchased online, they state it needs to be purchased directly from a Viper distributor
Old Oct 17, 2011 | 01:54 PM
  #155
slvr_4dsc's Avatar
Thanks, this is most helpful!
I would really appreciate if someone can provide me a link for the idatalink or any other reliable bypass module. Thank you.
Old Oct 17, 2011 | 01:58 PM
  #156
DO NOT BUY VIPER ITEMS ONLINE! IT WILL NOT BE COVERED UP VIPERS WARRANTY.
Old Oct 17, 2011 | 02:01 PM
  #157
I know all too well about the size of these remotes. My Spec-V has a 5902 in it. My opinion is that any car that has a smart key needs to have smart start. It's just so pointless to carry two remotes. I can't wait to get it in tomorrow and get started on it. Seems like a simple but tedious install so will probably just make it a two day project and take my time to avoid any dumb lights coming on.
Old Oct 17, 2011 | 02:14 PM
  #158
Pearl96Max's Avatar
I tend to get a bit irritable
Amazon or any other etailer = zero warranty regardless of who installed it.
With all due respect you called me late on a Very busy Sunday. Which is a day that most shops aside from the big boxes are not even open. Your call was returned and a voicemail left. Within less than a full days time.
Old Oct 17, 2011 | 02:32 PM
  #159
slvr_4dsc's Avatar
Hi Don,
I just got your VM, thanks for responding. I am trying to call you back, but its going to your VM. I will try to reach out to you again tomorrow. Thanks again.
Old Oct 17, 2011 | 02:56 PM
  #160
Ghozt's Avatar
question guys - i got my 5902 through a viper distributor and installed at the same place as well. if i order a few brand new DEI modules online (tilt, battery, glass-break) and have them installed at the Viper place are those eligible for warranty coverage? or are those items not covered. or even worse, would those void the warranty on the rest of the system?
