Wire fog lights
Old May 16, 2011 | 03:28 PM
Kev7Gen's Avatar
Wire fog lights
Does anyone know how to make it so the fog lights can go on when the parking lights are on or to where I can just have the fogs on themselves.?
Old May 16, 2011 | 04:09 PM
maxxxxspeed's Avatar
U can swap the plugs... Put headlight plugs on fog lights and vise versa
Old May 16, 2011 | 04:10 PM
Buttttttt then the light switch will be opposite as well but that is what I plan on doing when my HID kits show up!
Old May 16, 2011 | 06:00 PM
shadowx3081's Avatar
My shop tryed everything possible the only thing that worked was putting a separate switch
Old May 16, 2011 | 07:29 PM
320driver
I just bought a 2011 S model, which doesn't come standard with fog lights. Since I actually need fog lights (mountain driving), I ordered the factory kit from Courtesy and installed them a couple of weeks ago. The installation was very straight-forward and easy, by the way.
It was very surprising to me that the fog lights are not switched to operate independent of the headlights (!). Anyone who actually drives in fog understands that flash-back reflection from the headlights is exactly what you don't want.
The factory light kit fits perfectly and works beautifully...but.... Yep, I need that same headlights OFF switch.
Old May 16, 2011 | 08:12 PM
Kev7Gen's Avatar
What do you mean by plugs? I'm kinda lost...
Old May 17, 2011 | 08:02 AM
Both the headlights and fogs run H11 style plugs that plug into the actual bulb... If u take the ones plugged into the head lights and swap them with the ones plugged into the fogs and vise versa... So the fogs run off the headlight switch and the headlights run off the fog light switch...
Old May 17, 2011 | 09:40 AM
MadMax07SL's Avatar
That's a very odd suggestion...
Old May 17, 2011 | 09:48 AM
K... then dont do it.
that was suggested by another member a long time ago. If you can figure out a better way enlighten us!
Old May 17, 2011 | 10:33 AM
MadMax07SL's Avatar
I'm just surprised that the wiring could be long enough to make the swap. You ever tried it?
Old May 17, 2011 | 10:43 AM
320driver
Schematically speaking, this would work just fine. It would also eliminate the need for splicing in another switch/fuse/etc.. Unfortunately, it results in a reverse scenario, where one can't get the headlights without the fog lights.
The Fog light kit comes with the lights and a new set of column levers. The lever and switch assembly is prewired and preassembeled. The true fix is in that left-hand lever/switch. I might dissect the original (non-fog) lever and see just how hard it would be to make the change and reassemble it without destroying it.
Old May 17, 2011 | 10:46 AM
Who uses the headlights without the fogs? That doesnt seem to be a big problem... I ALWAYS have my fogs on with my headlights, and most people driving around I see seem to always have their fogs on with the headlights.
If Nissan werent ******** and wired them up like damn near every other auto manufacturer we wouldnt have to try to jimmy rig something...
Old May 17, 2011 | 10:48 AM
I am getting HID kits soon. I will let you know. I do not know if they are long enough stock, but if they arent I would tend to bet that you can buy extensions for H11 plugs (I havent searched)
Searched:
http://www.hidspeed.com/880_harness_...stwire-880.htm
Or you can just snip and extend the stock wires...
Old May 17, 2011 | 12:04 PM
320driver
Often while driving on black, unlit roads at night it's courteous to keep the forward lights at a minimum for oncoming drivers. Maybe it's a "mountain" thing.....
Being able to control one's f'ing lights seems like a modest request for $32K+ (otherwise, I love the car - it's phenomenal).
Old May 17, 2011 | 02:34 PM
Kev7Gen's Avatar
I don't think my head lights are h11 though. Cuz I had the stock maxima hid on my car when I got it..
Old May 17, 2011 | 04:50 PM
Kmoney's Avatar
sorry for the off topic but do you guys know if the OEM fogs from 09 altima couple will fits our car?
Old May 17, 2011 | 05:17 PM
Llfe's Avatar
this is exactly what i did...i have 09 S and put hid kits in lows and fogs...the ballasts are mounted right next to each other so i just switched the plugs and bammm....fogs turn on with low beams and low beams turn on when i turn the fog light switch on
u can always switch it back whenever u want
only a temporary solution until my warranty is up in september/october this year
A32goldylocks
Sep 2, 2015 06:39 AM
umnitza
Sep 1, 2015 01:03 PM
robtroxel
Sep 1, 2015 08:12 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
