Wheel Bearings already!?
I own a 2010 Nissan Maxima, which I purchased new in May of 2010.
Recently about a week ago I started to hear a growling noise coming from car driving around 45 miles per hour. Anything faster the engine sounds louder. At first i thought it was the dumb Goodyear RSA's making noise, so I budged and purchased new tires. I needed them anyway. No go, I was denying the fact that it could possibly be a wheel bearing. It wasn't the only issue, I would here a clunking noise when going over bumps when turning.
Just took it this morning and the dealer couldn't believe it was the wheel bearings already. They also told me I needed sway bars and strut mounts.
Im like What the? They have the parts in stock so I left the car for repair.
Its under warranty. They are doing everything is two's. So new sway, new strout mounts, and new wheel bearings.
Some quick info I have about 21k miles on it, Im not a crazy driver. Most miles are highway for work. All maintenance work is done at dealer. Even tire rotations.
Anyway have this issue or had it replaced already?
I can understand a wheel bearing going out prematurely (hey, things happen during production and maybe the tolerances weren't bang-on) but them saying the sway bars needed to be replaced as well?
Now... the strut mounts are a legit TSB issue. They got a bad batch of those back in July-Sept of 2009. Mine was one of the cars affected right outside that date range. I actually bought my car in April of 2010 brand new.
Good news is, they're taking care of everything under warranty.
IK waJust took it this morning and the dealer couldn't believe it was the wheel bearings already. They also told me I needed sway bars and strut mounts.
Similar boat, the strut mounts were shot on mine and the rear sway bar bushing were dried out as well. I think they replaced the entire strut assembly instead of tearing it apart. Same as GM Traitor3.5VQ my 2010 was 'not affected' by the recall but they went bad and were replaced under warranty. Are you sure it was the entire sway bar and not just the bushings? Mine made a nice squeak going over bumps in the early morning hours, it needed to be really cold out to do it. I don't see, short of it being parked in a pile of salt, anything going wrong with the sway bar so soon...
) If you've got problems with the sways squeaking, get some non-petroleum based thick grease (I found some good stuff from AutoZone by Valvoline) and just put a nice thick coating all over the inside of the sway bushings.
Yeah, the actual sway bar going bad would surprise the hell outta me (both of mine are powdercoated
2009 Maxima Wheel Bearing
I have a 2009 Nissan Maxima with 55K miles. It had been making noises that sounded like driving on a concrete highway that has rain grooves. The noise became pronounced when driving between 40 to 65 mph, with the noise becoming louder and more intense in relation to the increase in speed. At times the noise reminded me of (ok...this really dates me) the sound of a formation of WWII bombers flying on the old 60s TV show "12 O'Clock High". After awhile, it really gets on my nerves. Started to wonder if my Eagle RSAs were part of the fault. Had one automotive shop look at it and after checked the tires they said was not a wheel bearing but could not say what it was. Some people have commented online that if it was a wheel bearing, the noise would diminish when you corner/steer away from a straight line. The noise from my car stayed constant even when cornering. Took it to my Nissan dealer, and they diagnosed and replaced the Right Front Hub and wheel bearing, covered under the drivetrain warranty. Now my Maxima is back to normal, and I am thoroughly enjoying it!!!!!!!! Just wanted to share my experience with front end noise since you hear a lt of different experiences.
Wow, this is unusually short lifespan for these parts, I would have thought you'd get at least 160,000 km (100K miles) from OEM wheel bearings.
I wonder if all these cars with the big 18" + rims are putting a high load on the bearings? not that this shouldn't have been designed accordingly.
Do you happen to have the TSB on this ?
My car is a 09 and I can hear the mounts going, although it is 4 yrs old with 53,000km's on it, but I do have extended warranty on it.
Warranty
Correct... I just got in from DAVIDSON'S NISSAN in Watertown, NY and had my Hub Assembly replaced at 55K.. It was covered by the power train warranty
2011 Maxima, front left wheel bearing
Dec 2015. My 2011 Maxima with 40,000 miles started to have a faint helicopter sound. Like tire rubbing on wheel well. A little louder when making right turn. Vibration through the car. All four wheels checked for balance, they were good. Was the front drivers side wheel bearing assembly. Never had wheel bearing issues on cars with three times the mileage. I have a great mechanic. He said the other bearings were fine. Cost $375 total.
I have had three different wheel bearings go bad on my car. One of them had to be replaced twice! All occurred between 53-81 thousand miles on them. I didn't know that they were covered under the powertrain warranty, so they were changed at Firestone. So far so good for the past 27 thousand miles!
I have a 2010 Maxima. 3 wheel bearing now out in only 71K miles. First one went at 30K (right front). Dealer in Conyers GA replaced, but charged me even though I find out now that it was under warranty. He is now replacing under warranty the other 2 that are bad now (left front and right rear). Wish he would replace the left rear right away as a show of good will - seeing as there must have been a bad batch of bearing when they build this car. 75% failure don't lie. Unfortunately, not going that far for me. Tried telling me that it may have been potholes that did in my bearings. But the tires are low profile 45 series. Never any tire or rim damage from potholes. If bearing is weaker than a 45 R18 tire, then that is still a design flaw.
I have a 2010 Maxima S with 87K miles, bought it used a couple of weeks ago. Dealer did not disclose the fact that one rear wheel was bent, and noise coming from rear was not going to be fixable by simply balancing the tires. I bought new tires and a new wheel. Noise still there, but better. Last night I installed Timken rear wheel bearings on the rear. Noise is finally gone. First one I replaced seemed fine, which worried me. But when I got to the other side, that one was rough sounding. Now it drives quite. Glad I finally got it quite, but it was a lot of expense and time. Now I have a rattle going over bumps that I must solve... Otherwise, I really like this car!
I have a 2016 Platinum and have had one bearing replaced under warranty and now I am hearing the same whirring sound again. What the heck is up with the bearings they use? At least it is still under warranty now too.
I've started noticing a bearing noise coming from the driver's front side...seems to only do it whilst turning right. I bought the car a little over a year ago (2014 Maxima SV) and it now has about 70,000 miles on it. It's a 'Certified Pre-Owned' and supposedly has a 7 year, 100,000 mile warranty, which I will be demanding my local dealer honor and fix the bearing under warranty. I expect them to ***** and moan about it, though...
ghostrider17
20
Oct 7, 2011 05:01 AM
Teddie18
Aug 18, 2009 03:52 PM
Muyrec
Jun 18, 2009 07:36 PM
JtzMax
Apr 22, 2008 02:21 PM
