HID issue...
Old Oct 2, 2012 | 10:31 AM
Fundem's Avatar
HID issue...
Hey, Im on my third pair of HID's.. For some reason the passenger side one blew twice. Now with this pair I noticed as I turned the car on in front of a store front, that the passenger side light takes longer to fully light up than the other. Could that have something to do with that side blowing?
Old Oct 2, 2012 | 10:39 AM
Are you running a relay harness?
Old Oct 2, 2012 | 10:48 AM
Fundem's Avatar
I dont know what that is. I didnt do the install, but from what i understand its just plug n play
Old Oct 2, 2012 | 11:41 AM
I doubt you're using one then. Get one:
http://www.theretrofitsource.com/pro...roducts_id=166
Old Oct 2, 2012 | 12:10 PM
Fundem's Avatar
These are for my fog lights by the way. Is that the same thing?
Old Oct 2, 2012 | 12:34 PM
Yup! That will work for your fogs.
Old Oct 9, 2012 | 06:58 PM
Fundem's Avatar
Excellent!... Do I need to remove the bumper again? I assume I do?
Old Oct 9, 2012 | 07:09 PM
Yup. It adds on to your current set up pretty much.
Old Oct 10, 2012 | 05:32 AM
Fundem's Avatar
Anyone know where there is that write up on getting to the fogs without removing bumber? I promised my self I would never remove that again, Pain int he *** to get it lined up and a shop charges me $100 for labor.
Old Oct 10, 2012 | 06:53 AM
madmax17's Avatar
You can either take the wheels off and go through the wheel well lining or lift the car up in the front and remove the front shields below the car. There both pretty easy.
Old Oct 15, 2012 | 05:38 PM
Fundem's Avatar
Ok I got that harness... Quick question, once I connect it there should be an extra wire left over hanging right? What do I do with it? Or am I looking at the diagram wrong and every plug will be plugged somewhere?
I'm thinking of the passenger side, since only one wire goes that way. Where does that plug into?
Old Oct 15, 2012 | 06:26 PM
Quick question, once I connect it there should be an extra wire left over hanging right? I'm thinking of the passenger side, since only one wire goes that way. Where does that plug into?
That plugs into the ballast on the passenger side if it's the connector that I'm thinking of.
Old Oct 15, 2012 | 06:38 PM
Fundem's Avatar
But what happens with the plug that was originally there?
Old Oct 15, 2012 | 09:06 PM
Nothing. Grab a zip lock bag and tape it up.
Old Oct 16, 2012 | 04:58 AM
Fundem's Avatar
There we go... Thanks man, I figured there would be one left over. Im assuming its the one that comes from the bulb?
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Mochedda
Dec 15, 2015 11:27 AM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
