Rough Idle no CEL
Rough Idle no CEL
At stop lights rpm will drop to about 500 then attempt to recompensate to about 550-600. Car will rumble a little. No CEL. Any ideas? Are there obd2 scanners that can give me an idea without a CEL?
Probably not, unless you hook it up to Consult at the dealer. Which I would avoid,
I would start at page Page EC-581
https://www.nicoclub.com/FSM/Maxima/...0Maxima/EC.pdf
https://www.nicoclub.com/FSM/Maxima/2014%20Maxima/
Many scanners (even some cheap ones on Amazon or eBay) can connect to ECU and PCM and read codes from both engine and transmission. Including AFR ratios, fuel pressure, ignition timing, O2 sensors data, in real time as well as logging while you drive. You just need to research and learn on them.
As for the OP, rough idle can come from dirty air filter, worn spark plugs, bad ignition coils, bad gas, clogged fuel filter, clogged EGR valve, etc.. You have to rule out the mentioned things.
S1cTech
19
Feb 22, 2013 12:05 AM
Reizy
Jul 18, 2008 04:46 PM
infinitiman96
Feb 15, 2003 02:37 PM
