Rear brake issue
Old Nov 2, 2019 | 02:02 PM
MaximusN8's Avatar
Rear brake issue
Hi guys, I'm completely at odds as to what's going on, 3 weeks ago I replace the rear brakes on my wife's 2012 Maxima and noticed after about a week the left rear rotor had uneven wear on the surface and a rust ring midway from the top. So I replaced the caliper and rotor as well as the the brake hose and behold a week later same issue. So today I replaced the caliper under warranty and rotor and again after doing the brake embedding procedure I see this is going to happen again. Does anyone have any idea as to what could be possibly going on??
Old Nov 2, 2019 | 02:05 PM
MaximusN8's Avatar
Here is how it looks like today after caliper and rotor replacement. It looks to be happening again.
Old Nov 2, 2019 | 04:36 PM
User1's Avatar
Your pads are on backwards.
Old Nov 2, 2019 | 04:40 PM
MaximusN8's Avatar
I doubt their on backwards.
Old Nov 2, 2019 | 04:45 PM
User1's Avatar
Their what? Pants?
Old Nov 2, 2019 | 04:49 PM
MaximusN8's Avatar
Their what? Pants?
"I doubt they're on backwards" You are a reliable source around here I don't understand why your being wise? I'm just asking for honest advice and opinions and your responding with smart remarks.
Old Nov 2, 2019 | 05:01 PM
User1's Avatar
Your caliper bracket is misaligned. Check that your mounting contact surfaces are mated properly (square). Have someone stomp on the brakes while you inspect. Depress brakes, inspect, release brakes, spin rotor, inspect mounting points, etc. Use a flashlight, even if it's daylight, shine from behind and at different angles in attempt to see light where there shouldn't be any. You're looking for the reason the aft-half of the pad is all that is making contact with the rotor. Your reassembly procedure is the culprit. Easy fix though, you just have to find it. You did it right on the other side
Old Nov 2, 2019 | 05:06 PM
User1's Avatar
Forgot to add: Check for binding on the guide pins. Smooth action is the game here.
Old Nov 2, 2019 | 05:07 PM
MaximusN8's Avatar
Thank you.
Old Nov 2, 2019 | 05:10 PM
MaximusN8's Avatar
Yes will do! Tomorrow morning I'm going to take a look and see what's going on back there. Thanks for the input I appreciate it I'll post back after I figure out what's going on and if I resolved it.
Old Nov 2, 2019 | 05:14 PM
User1's Avatar
Get some photos while you have it apart if possible. Especially when you find the problem. Cheers.
Old Nov 2, 2019 | 05:19 PM
MaximusN8's Avatar
Will do! Thank you I appreciate the info very much!
Old Nov 3, 2019 | 01:19 PM
LtLeary's Avatar
I do truly hate to admit this, but i did but put my pads on backward with similar wear patterns . But it also looks as if if the pads arent the correct size. Do let us know what you find.
Old Nov 3, 2019 | 01:23 PM
User1's Avatar
It'll happen. I've seen if before
I think he just has a misalignment or pads not seated correctly. No big deal. He's probably burnishing them in as we speak.
Old Nov 4, 2019 | 11:15 AM
MaximusN8's Avatar
Hi guys, I spent most of the day yesterday trying to figure this out, removing the pads reinstalling etc. After many attempts it boiled down to improper alignment due to the wrong series pads being mixed in the box. I pretty much had one pad that wasn't to spec with the rest and causing that improper embedding. Thank you user1 for your input if you had not suggested I go back and re check multiple things I wouldn't of figured this out. LT Thank you as well and as always guys I appreciate the help!
Old Nov 4, 2019 | 03:50 PM
User1's Avatar
I wonder if you got a set that was previously purchased then returned with the wrong pad?
Glad you got it fingered out! Happy motoring!
Old Nov 4, 2019 | 04:27 PM
MaximusN8's Avatar
Yes I'm with you on that theory that's what I'm thinking too! Thanks again for the input and yes Happy motoring! Until the next project that comes up..lol
Old Nov 5, 2019 | 04:40 AM
MadMax07SL's Avatar
Brake pad boxes are never sealed with tape or labels in my experience. I always wondered if something like this could ever happen. Could have even fallen off a shelf, hit another box, both opened, and the clerk just put 2 of each backin. That's why when I buy shoes I always try/check both shoes, to make sure someone else didn't switch them out one for one...glad you got sorted out!
Old Nov 5, 2019 | 04:35 PM
MaximusN8's Avatar
Yes I'm glad too it was driving me crazy, I will in the future before leaving my local parts store check the pads and make sure they all match up..
JBruno
Jan 7, 2014 03:16 AM
m.maloney
Oct 18, 2013 06:57 PM
erictown
Jun 25, 2013 04:31 PM
mszilves
Sep 21, 2006 03:16 PM
Curt Deiner
Nov 15, 2001 08:45 AM
