Apple CarPlay
Old Jan 25, 2020 | 12:35 PM
  #281
Kevin1960's Avatar
Make sure you check your harness connections
Bought a ‘17 unit
got the entire unit out and reinstalled and the connection clip was broken
all for nothing
now have to find another unit
have them take picture of the connections on back
i will now
kevin
Old Feb 21, 2020 | 06:31 PM
  #282
IndianExpress's Avatar
Having the same problem. I put a 2018 Bose H/U in a 2016 SL and my backup camera won't work. Looking for any information / advice.
Old Feb 22, 2020 | 03:49 PM
  #283
SDMaxMike's Avatar
Originally Posted by Kevin1960
Bought a ‘17 unit
all for nothing
i will now
kevin
I had the same problem in my 2016 SL. Check the hidden settings on the headunit. If the new headunit is coming from a platinum model with the all around camera system you would have to change it in the hidden settings menu to rear view camera only. That solved the problem for me.
Old Apr 11, 2020 | 08:35 AM
  #284
Rich891's Avatar
Were you able to get the 2018 unit working? I’m currently looking at a 25915-9DE1B/A for my 2016 SR
Old Apr 14, 2020 | 10:28 AM
  #285
J Rod's Avatar
If that doesn't do it, check the connection for the camera wire on the back of the radio. It may be loose or not plugged in, there are several connectors going into the back of the HU so it's possible that one may have been overlooked.
Old Apr 14, 2020 | 04:58 PM
  #286
Rich891's Avatar
Electrical noise possibly
I have swapped the stereo out of my 2016 SR with Bose to a 25915-9DE1A. Everything seems to be working fine other than I am noticing a possible electrical noise when changing temperature on the AC controls. The head unit came with the ac controls and I used the new ones that came with it. Any ideas on why it would be making a noise I don’t remember it doing it before.
Old May 6, 2020 | 02:41 PM
  #287
Luke Sandrock's Avatar
What trim is your car, and what was the trim of the car you got the radio from?
Old May 6, 2020 | 03:40 PM
  #288
compyelc4's Avatar
Originally Posted by BxBorn65
Hopefully AndroidAuto gets added as well for access to GoogleMaps.
I have Apple CarPlay on my 17 Max and it supports google maps just fine.
Old May 21, 2020 | 06:59 PM
  #289
Croft315's Avatar
Hey all, just wanted to say THANKS!
I joined this forum I bought my used 2016 Platinum. It was a surprise/huge letdown that there was no Android Auto but I hadn't even thought about it before buying the car. Oops.
Thankfully, you all have been thrashing this issue over for several years now! Lol.
Just wanted to say thanks for those who contributed.
With the right info in recent couple pages of this thread including proper part numbers, totally plug and play! 🤘
Old Jun 9, 2020 | 02:02 PM
  #290
coasterswim's Avatar
A special thanks to everyone in this thread I found a 2018 unit on eBay and installed it this morning. Special thanks to @kilowhisky for the super helpful and detailed pics and to @wsrobert for identifying the right radio models!
I've had my car since Sept 2015 but this upgrade is going to breathe new life into it. Now I gotta find a buyer for my old unit...
Old Jun 15, 2020 | 11:13 AM
  #291
Keron Lezama's Avatar
Talking Need part # for my 2016 Platinum
Hello, i have a 2016 Platinum and need to know which part number to use for my install as well.
I want to do the same 2018 unit for Android Auto just need the part number.
Did you have any issues with steering wheel buttons, 360 cameras, backup cameras or anything not working?
Also will i need to get a new SD card for anything too?
Thanks for your advice!
Old Jun 15, 2020 | 11:39 AM
  #292
thisguy159's Avatar
Hello all...I'm hoping you all could help me with purchasing the right head unit. My wife has a 2016 murano platinum (bose system) and its one year before CP would become available. Similar to the maxima situation here. I have heard of units being changed out but nothing has been as detailed or extensive as here. About 5 months ago, I had purchased NavTool for her car which is absolute garbage and my wife is pissed because now even Bluetooth will not work. The Bluetooth issue is my fault I went into setup on the head unit and messed with it and broke it. SO to save my marriage I want to get a 2017 head unit and get that installed, the problem is I do not know which model I should be looking for. Our car has 360 camera too if that matters at all. Would any of you be able to help me survive Corona with very mad wife.
Old Jun 15, 2020 | 12:43 PM
  #293
Croft315's Avatar
My 2016 Max Platinum has the BOSE system.
If you didn't have BOSE it'll be a different part number. I sourced my part number in this thread then double checked online to be sure.
The part number I looked for and bought used/takeoff on eBay is 25915-9DE1B
For me it was plug and play.
It came with the SD card installed. I did nothing but connect the new unit. All cameras and steering wheel functions are as they were. No issues.
Old Jun 15, 2020 | 02:27 PM
  #294
thisguy159's Avatar
Thanks but I assume this is Maxima specific, I'm looking for a model number for Murano.
Old Jun 16, 2020 | 06:48 AM
  #295
robtroxel's Avatar
Crooft3,
Thanks for your report and its successful conclusion. Of all the mods out there, day to day, this one makes the most sense. One take away I get its to be sure you have a matched SD card specifically for the unit you buy to upgrade your 2016+ with.
Now then, there are enough 2019-2020s out there that I am wondering if their radio units can be back swapped to the 2016-2018 Maximas? I do understand the head unit is made by a different manufacturer and dispenses with the whole notion of an SD card. Anyone know if this can be done?
Old Jul 25, 2020 | 01:35 PM
  #296
Ahmed1985's Avatar
Good day for everyone.
Thank you so much for creating this very helpful forum .
well , I have funny issue ! I have maxim 2017 meddle east edition and there is no Apple CarPlay!
Any suggestions please how could I sort it out ?
thanks ,
Old Oct 19, 2020 | 12:41 PM
  #297
flixxx's Avatar
Thank you all for all the hard work to update our console without requiring to update the whole car just to get car play.
After reading this thread, and looks like a 2018 fits a 2016 model (to take advantage of Android also), I am about to pull the trigger and make the purchase for a 25915 9xx1x for my 2016 platinum.
The problem is, these are difficult to find and have been coming across models such as 25915 9DE3A for example... the 3 is throwing me off... I have been looking for a 1 for my version vs the 0. Anyone have any insight? When i call to get information they confirm this is being pulled out of an 11 speaker setup but I am concerned that it will not fit the 2016 model because it goes against the grain on this thread.
Old Oct 19, 2020 | 01:09 PM
  #298
robtroxel's Avatar
11 Speaker means it is a Bose factory system. Head unit may not work if you don't currently have Bose system.
Old Oct 19, 2020 | 01:23 PM
  #299
flixxx's Avatar
Understood, an I have the platinum edition with the Bose system.
This thread suggests that I need to look for a "1" instead of the "0"... but what happens when it's a 3?
Old Oct 20, 2020 | 04:23 AM
  #300
robtroxel's Avatar
Unless the 3 denotes a 2019-2020 head unit? Not sure otherwise
Old Oct 24, 2020 | 08:23 AM
  #301
J_A_D_2002's Avatar
Crooft3,
I'm curious if you have heard anything new regarding this? I am in the market for a 2018 Bose compatible headunit but wonder if the newer models will work too.
Old Dec 28, 2020 | 09:29 AM
  #302
shadowofthecrow's Avatar
Help a lost soul
Sorry to rehash and old topic but Newbie here...
I've been following this issue off and on for the last few years. I'll think about swapping out then keep faith for an OTA (since I don't drive as much) then get frustrated again. I have a '16 Maxmia SL w/Bose Integration and I'm torn between these three head units. Any help as to which would be best for me to do a plug and play? I've never done anything of the sort before. I love all the hard work as it seems in the realm of possible so thanks so much in advance.
Option 1​ Option 2 Option 3
Old Dec 28, 2020 | 09:49 AM
  #303
robtroxel's Avatar
I don't see any mention of Carplay or Android on the last 2 options. Do you want Carplay? If so option one works but I am sure other vendors might have a 2018 Bose headunit which should work for you without the high price. That would get you both Car Play and Android.
Old Dec 28, 2020 | 09:59 AM
  #304
Yeah, I definitely want the Carplay. That's my whole reason for looking to upgrade. I've been having trouble finding other options that say they will line up with my '16 SL though.
Old Dec 28, 2020 | 10:06 AM
  #305
robtroxel's Avatar
Keep checking Ebay or find an auto wrecking yard. They also have a parts system for lists what is wanted across the US. Be mindful on the actual part number you need for a Bose Maxima system and that it includes the original SD card.
In 2019 Nissan dropped the SD card radio and went with a newer system that provides USB update support as well as the Car Play and Android standard. I wonder if that unit might also be plug and play?
Old Dec 28, 2020 | 10:49 AM
  #306
Dunno, I found this '17 one though however it doesn't mention if it supports carplay or either the bose system in the SL.
https://www.lkqonline.com/2017-NISSA...O/-i~267852278
Old Dec 28, 2020 | 10:55 AM
  #307
robtroxel's Avatar
Looks like it might be out of a SV based on the interior shot of the driver's seat. Has the thigh support and what looks like perforated leather. But you need to verify the part number to be sure. I am not sure the 2017 supported car play either?
Old Jan 8, 2021 | 10:43 AM
  #308
SomeoneElse's Avatar
Since I swapped my 2017 SV head unit for a 2018, I haven't had the "sonar" aural warnings when the corners were too close to something. I know the 2018 head unit has older nav software than the rest of my car, and I'm tempted to buy a 2018 nav update to see if that fixes the problem. Has anyone attempted a nav update after swapping a head unit?
Old Jan 8, 2021 | 12:01 PM
  #309
robtroxel's Avatar
I would bet that this would not fix your issue. Somewhere there is a hidden setup menu so the unit can "see" the sonar inputs and the back up camera. Do a search for the hidden menu discussion buried somewhere on this site. Beyond that maybe a service tech could say if it is a dealer accessible fix. Sorry to hear of the problems.
Old Jan 8, 2021 | 12:49 PM
  #310
If you're referring to the diagnostic menu on the head unit, I've been there and wandered around. I can't find anything regarding sonar there. The only settings for it appear to be on the instrument cluster. Is there another diagnostic menu on the instrument cluster?
Old Jan 8, 2021 | 01:20 PM
  #311
robtroxel's Avatar
Thanks for the report. ..It does look like a dealer diagnostic is the next step as they have the software to figure out what is going on.
Old Mar 26, 2021 | 10:24 AM
  #312
MaxPower16's Avatar
Wireless Carplay?
I got a great deal on a '17 Head Unit (Part# 9DD1C) for my 2016 SL, and it worked perfectly right from the start. Thanks to everyone who has contributed to this thread and provided all the great information - especially those who took the risk to see if this was even possible.
Now, my next question is, has anyone used one of the Wireless Carplay Dongles/Adapters to use CarPlay wirelessly? I've seen CPLAY2Air and Carlinkit 2.0... Curious as to how well these work.
Thanks,
-Matt
Old May 5, 2021 | 11:22 AM
  #313
accvx17's Avatar
Dallas,tx/ 16 maxima platinum
Hi! hopping on this post to see if anyone can help me find a 2017/2018 Head Unit w Carplay for my 2016 Maxima Platinum. If anyone happens to be on and knows any friends selling, salvage yards or any eBay finds would be greatly appreciated
Thanks in advance to this entire forum because I am using it to study and prepare myself to swap my unit on my own haha.
Old May 18, 2021 | 12:12 PM
  #314
tbird2340's Avatar
I just bought this
Amazon Amazon
hoping it would work for wireless carplay and when I plug it in I get "Apple CarPlay failed to start. Please confirm the compatible device is operating normally. Consult Apple for the compatible software versions."
Anyone able to get a wireless device like this working?
Old May 18, 2021 | 12:31 PM
  #315
White Fang's Avatar
Thank you for asking this question! I was wondering if it would work...
Originally Posted by tbird2340
I just bought this https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 hoping it would work for wireless carplay and when I plug it in I get "Apple CarPlay failed to start. Please confirm the compatible device is operating normally. Consult Apple for the compatible software versions."
Old May 19, 2021 | 04:42 AM
  #316
primeholy's Avatar
I get that sometimes when I just plug my phone in, so some kind of troubleshooting might help.
Will the dealership update your software for free if you are under warranty? I bought a certified pre-owned, and I wonder if they would do that.
Old May 19, 2021 | 04:45 AM
  #317
primeholy's Avatar
https://carlinkitcarplay.com/product...y-carplay#list
That list says maxima has unstable compatibility.
Old Aug 19, 2021 | 03:52 PM
  #318
Laurenash's Avatar
Update on all the units changed?
Hello! I have read almost every comment on this thread and am VERY interested in purchasing a 2017 head for my 2016 maxima platinum. Those of you who did this, how did it turn out in the long run? Did you notice any difference in any of the other functions. Did you regret the decision to change?
Old Aug 19, 2021 | 04:37 PM
  #319
PTEwD9zTZETEhTF3aJeZ's Avatar
Hey so i followed this thread and it worked out perfectly. I did not regret the decision to change, it changed my whole driving experience. I believe CarPlay is a must for iPhone users and cars. I recently traded in my maxima platinum for a new cx5 signature and that CarPlay is even better. I digress. It worked out in the long run so almost 2+ years it ran flawlessly. Everything worked with buttons on the unit to the touchscreen. Lmk if i can help answer any other questions. I'll try my best as I don't have the car anymore.
Old Sep 2, 2021 | 01:08 AM
  #320
mazinmohd11@gmail.com's Avatar
Hi, can you please help me with part number for my car which i can look for in Ebay
Nissan Maxima SV 2017 - Origin United States but middle east version with 11 Speakers Bose system
