Remote starter issues
Old Aug 17, 2016 | 09:03 AM
Yes2pfs's Avatar
Has anyone had issues with their remote starter not always working?
Mined seems to work sometimes and not other times.
2016 Platinum
Old Aug 17, 2016 | 09:09 AM
raven69david's Avatar
2016 Platinum
I've experienced the same issue but I thought it was due to the other transmitter being within range of the vehicle. It's worked 90% of the time that I've tried it so not sure if it's an issue with the vehicle or with something I'm doing wrong.
Old Aug 17, 2016 | 09:33 AM
Yes2pfs's Avatar
My 2nd transmitter is never with me when I try and use my remote. I have read and re-read the instructions in the manual. Make sure the car is 1st locked then press the remote. I've pressed it quickly and I've held it down for a few seconds, still intermittent working and not.
I think I'll take to the dealer.
Old Aug 17, 2016 | 09:50 AM
BxBorn65's Avatar
I found this info on an Altima site. Their remote is essentially the same.
http://www.nialtima.com/remote_engin...pped_-127.html
The remote engine start operating range is approximately 197 ft (60 m) from the vehicle.
The remote start will not operate if any of the following conditions are present:
● The ignition switch is placed in the ON position.
● The hood is not securely closed.
● The hazard warning lights are on.
● The I–Key Indicator Light remains solid in the vehicle information display.
● The alarm sounds due to illegal entry into the vehicle.
● The ignition switch is pushed without an Intelligent Key in the vehicle.
● The ignition switch is pushed with an Intelligent Key in the vehicle but the brake pedal is not depressed.
● Two remote vehicle starts, or a single remote start with an extension, have already been used.
● The vehicle is not in P (Park).
● The Remote Start function has been switched to the OFF position in Vehicle Settings of the vehicle information display. For additional information, see “Vehicle information display” in the “Instruments and controls” section of this manual.
The remote engine start may display a warning or indicator in the vehicle information display. For an explanation of the warning or indicator please see “Vehicle information display warning and indicators” in the “Instruments and controls” section.
Old Aug 17, 2016 | 09:59 AM
Yes2pfs's Avatar
Thanks! I'll double check all of these.
Old Aug 17, 2016 | 12:48 PM
PapaDroid's Avatar
You may be implying this but for clarification on the car being locked, you must hit the lock button on the remote and then press and hold the remote start button.
Old Aug 17, 2016 | 03:04 PM
Yes2pfs's Avatar
I always press the lock button prior to the remote start button. How long is normal to hold it down, 2-3 seconds?
Old Aug 17, 2016 | 03:13 PM
1. Lock the car
2. Press and hold the starter button on the remote for 3-4 seconds or until the car starts.
I just did this and it took exactly 3 seconds for the car to start.
Old Aug 18, 2016 | 06:34 AM
PapaDroid's Avatar
I have noticed if I lock the car and very quickly hold down the button sometimes my car will not start. I try to pause for 1 second before holding down the auto start button for 4-5 seconds. Quirky, but it works.
Old Aug 18, 2016 | 08:31 AM
JSROOKS's Avatar
mine is about 5-7 seconds also depends on your distance.
Old Aug 18, 2016 | 05:00 PM
lightonthehill's Avatar
I have noticed this slight delay in performing other functions with this car. For instance, with my 7th gen Maxima, when approaching the locked car, I could push the door button twice with no pause between pushes, and the door on which I pushed the button would unlock, then immediately, all other doors would also unlock. But with the 8th gen, unless I pause a second or so between pushes, only the door on which I pushed the button will unlock.
I haven't tried unlocking the doors from a distance with the remote yet, but I suspect I may find the same pause needed there also.
But the 7th and 8th gens are alike in one detail - I can lock this car from almost three hundred feet away, and that has saved me retracing my steps in shopping centers more than once (when I couldn't remember if I had locked the car).
Old Aug 25, 2016 | 06:02 AM
Yes2pfs's Avatar
I think I was not holding the remote button down long enough. In the past week I have been holding down 3-5 seconds or until I can see or hear it started.
Thanks for your help.
Old Sep 19, 2016 | 06:47 PM
me9798's Avatar
Yes!...I get the same pause between pushes; and my passenger yanks on the door handle to no avail (almost yanking it off). I thought I was the only one! My '07 Alti was instantaneous.
Old Oct 22, 2016 | 10:42 AM
Jamgar1's Avatar
You can roll down the front windows with the key fob, unlock the car with the fob then hold the unlock button until they roll down.
MyMax1
Jun 28, 2016 04:30 PM
Derelique
Jun 22, 2016 05:53 PM
vishvjv
Jun 18, 2016 10:31 AM
Jarman Francis
Jun 16, 2016 12:05 PM
Jared526
Jun 8, 2016 11:59 AM
