went too wide on the rear
Old Sep 24, 2016 | 07:04 PM
Tigz's Avatar
I finally pulled the trigger and got a new set of wheels. I got a set of Spec- 1 spm 78 staggered 20x10.5 rear and 20x9 front. The front is ol. It's the back that's too wide. I was planning on lowering the car but it rubs on the rear. Is there any thing can be done with the rubbing issue?
Old Sep 24, 2016 | 10:02 PM
RickSmith's Avatar
Use this on your rear fenders. You can then lower your car as much as you want.
http://www.homedepot.com/p/Milwaukee...9-31/202438078
Old Sep 24, 2016 | 10:09 PM
punkfs's Avatar
lmao.. this guy..
Old Sep 25, 2016 | 12:04 AM
MrDillons's Avatar
Originally Posted by punkfs
lmao.. this guy..
Lmfao, that is hilarious, seriously
Old Sep 25, 2016 | 04:52 AM
lowriderman3's Avatar
You might just need to roll your rear fenders. What offset are you running? +35, +45, etc.
Old Sep 25, 2016 | 06:52 AM
Tigz's Avatar
in all honesty, I really dont know what the offset was. I left it up to the shop and failed, lol. I might just hae to invest on a fender roller and roll it out.
its almost 3/4" out
Old Sep 25, 2016 | 06:55 AM
tc8510's Avatar
You definitely don't need to roll your fenders that's not enough to warrant that. Based on your pic you negative camber is the way to go.
Old Sep 25, 2016 | 06:56 AM
Roll and pull baby.
Old Sep 25, 2016 | 04:20 PM
Tigz's Avatar
nobody ask you...your entitled to your opinion. This thread was to find idea on how to fix an issue..
Old Sep 25, 2016 | 04:39 PM
Ditto. You always have the select few that have to add their .02 without addressing the question.
Old Sep 25, 2016 | 04:58 PM
tc8510's Avatar
Did I miss something?
Old Sep 25, 2016 | 06:26 PM
Tigz's Avatar
apparently, my reply was offensive...Im not here to attack or bash anyone...from one car guy to another, please read the original thread and follow along. Now that's taken care off...carry on, .
Old Sep 25, 2016 | 08:01 PM
The poster deleted his comment that we responded too.
Old Sep 26, 2016 | 11:22 AM
MadMax07SL's Avatar
Those things are nice, but why 10.5 in the rear if it's causing this much trouble??? Go back to a 9 in the rear, it will likely eliminate all your problems.
Old Sep 26, 2016 | 08:33 PM
Tigz's Avatar
As I stated earlier, it was sold as a staggered set up. The shop assured me that there wasn't gonna be any fitment issue...until I drove it home...the shop won't replace or swap the wheels to a narrower set, so As pissed as I am, I'm stuck with it. They offered to install a 1/2" lift but that's not what I want the car to sit.
Old Sep 27, 2016 | 05:02 AM
MadMax07SL's Avatar
Oh, I didn't see that, must have been in the deleted posts. That said, man, that's harsh, I can't imagine a shop doing this kind of shoddy and getting away with it. Hope you find an option, but I would not roll the fenders...worst case get pair of 9" wide of the same wheels...take a loss yes, but don't destroy the car. ESPECIALLY not a lift! This shop sounds quite dangerous!
Old Oct 14, 2016 | 11:44 AM
Stopsweatinme's Avatar
So, what did you wind up doing?
My wheels are 20"x9" square. ET is 35 and they just make it. The only time anything rubs is when the front wheels are fully turned and I hit a bump. The clearance is millimeters, so I got lucky with my educated guess on sizing.
How much do your wheels weigh? I found some 20" wheels I liked and they weighed over 50 lbs per wheel. I was in disbelief, but verified the weight several places. The wheels I went with are 28 lbs each, which is fairly light for 20's.
That shop must not be very reputable. They tell you the wheels will fit, they're wrong, and their only option is to lift the car? WTF, I'd refrain from using them again. Good luck.
Old Nov 6, 2016 | 11:21 AM
bebanoscar1's Avatar
10x20 +40 offset 255/35/20 all around.
I went 10x20 all the way around and I have a real light rubbing issue in the back part of the front wheel wells, not the fenders but the plastic covers. I mean very minimal. I have noticed it when on an angle. No noise issues either.
I was told that I could just sand down the plastic cover that is rubbing. Any other suggestions?
Old Nov 8, 2016 | 05:06 AM
jerome johnson's Avatar
liner rub
I had same issues with mine with 20x9 on fronts. there isn't enough room for the liner to be pushed back with heat gun because there is a secondary metal brace behind the fender liner. I ended up cutting the liner where it rubbed and then banging the metal brace in a little, spraying undercoating over brace.
Old Nov 8, 2016 | 10:15 AM
The retailer is sending me me 4 245/35/20 tires to swap out. He said it should take care of the rubbing. Do you think it will work? And can you send me pictures on how the wheel well looks after you cut it?
Old Nov 10, 2016 | 12:41 PM
Fender liner trimming
Here's some of the of inner liner. I also downsized to 245/35/20 and it still rubbed until I ended up trimming.
Attached Thumbnails went too wide on the rear-20161110_151435.jpg   went too wide on the rear-20161110_151415.jpg
Old Nov 10, 2016 | 12:44 PM
20x9 and 20x10.5
Attached Thumbnails went too wide on the rear-20161023_121846.jpg   went too wide on the rear-20161023_121834.jpg
Old Nov 10, 2016 | 01:18 PM
Do you have any images of the stretch? The retailer is sending me tires (245/35/20) and I want to get an idea of how they are going to look.
Starrider
Oct 13, 2016 12:13 AM
beach50
Jul 24, 2016 10:28 AM
antnvlz1294
40
Jul 9, 2016 04:14 PM
aradhakr84
Jul 8, 2016 08:46 AM
RealityCheck
Jun 30, 2016 05:19 PM
