Issues with car bottoming out/rubbing on tires
Old Oct 25, 2018 | 04:10 PM
Boojack66's Avatar
iHello All,
Anyone put aftermarket rims on their vehicle with the Eibach pro kit lowering springs and have the rear hit the tires with passengers in the car? Here's my dilemma: I have a 2016 Nissan Maxima SR and I purchased a set of 19 x 8.5 aftermarket rims(still OE size) with 245/40/19 tires(still OE size) with 35mm offset. Original factory rims are 50 mm offset. The other day, the family and I went out and the car started bottoming out/rubbing on the tires. Took the car back to the shop where I had the lowering springs installed, thinking there was an issue with the spring installation. Was told that it was because I installed bigger wheels, which I didn't, was causing the tires to hit the fender wells. The only difference in the rims was the offset; from 50mm to 35mm, Any suggestions on what I can do to be able to keep the wheels on the car without having the rubbing issue? I have a 2016 Nissan Maxima SR. Thanks in advance for reading my post.
Old Oct 25, 2018 | 05:10 PM
compyelc4's Avatar
Originally Posted by Boojack66
iHello All,
So your new wheels are actually 15mm narrower from the hub mounting surface to the centerline of the wheels. That should have tucked them inward close to 3/4, bringing the tires in away from the rim by the same difference. Tell me, how much distance do you have now between the outer edge of your tire and the point in the wheel well where it is rubbing?
Old Oct 25, 2018 | 05:18 PM
Boojack66's Avatar
Maybe a 1/4 of an inch.
Old Oct 25, 2018 | 05:45 PM
kasdepwel's Avatar
Its your offset, on the rear with oem wheels and 15 mm spacers i was very close to rubbing, You could roll fender. Did you get an alignment?
Boojack66's Avatar
Old Oct 25, 2018 | 05:46 PM
Boojack66's Avatar
Yes, got an alignment right after springs were installed.
Old Oct 25, 2018 | 06:54 PM
Boojack66's Avatar
Thank you for the info, I had a feeling it was the offset. I am going to look into getting the fenders rolled.
Old Oct 26, 2018 | 06:26 AM
MadMax07SL's Avatar
Or get the right wheels with the right offset, and sell these since you likely can't send them back.
Old Oct 26, 2018 | 09:18 AM
ragulto's Avatar
iHello All,
Hi Boojack66. I have the same car as yours lowered on Eibach Pro Kit. My rims are 20x9 +32. It was rubbing on the rear with full passengers so I decided to roll the fenders and it fixed the issue.
Old Oct 27, 2018 | 10:17 AM
Boojack66's Avatar
Thank you for the info, Ragulto, I am going to look into getting my fenders rolled because I like the wheels I have and it is only off by 1/4 of an inch.
Peter Taylor
Tires and Wheels
Feb 7, 2005 02:53 PM
Peter Taylor
Feb 7, 2005 10:25 AM
tpduke112
Tires and Wheels
Jan 13, 2005 05:46 PM
Modernceo
Aug 11, 2002 10:03 PM
