2021 Maxima water issue
I have a 2021 maxima and iam getting water in the driver side
front door. its inside the door panel. I dont know how its getting in there. door closed tight, windows up. and when i push and pull the door back and forth you can hear the water. unreal would this be under warranty anyone having or had this issue?
Do not dispair, a solution is at hand...literally.
Each of the four doors have small drain holes in the bottom of the door, which in your case are clogged with who knows what debris.
Bend, kneel, lie on your back... but with a small flat bladed screw driver in hand, somehow manage to look at the bottom of the door.
You should find the drain hole/s.
Use the small screwdriver to clean out the hole/s.
Problem solved.
Problem solved.
Problem solved.
Problem solved.
