Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
K-Sport Coilovers Talk
Old Mar 18, 2006 | 07:38 PM
  #881
lex4style's Avatar
I went on mini road trip to atlanta. well 2hour drive for me all the way to downtown atlanta. I had the chance to take my car and test out how the ksports were on the hwy. I was alil scared with hitting uneven pavement on the hwy but hell it was a great ride! I'm 3/4 soft front and rear and it felt pretty darn good. Even tho I've had problems with them they ride great. I'm 3inches dropped and i think the ksports ride like Tockio/H&R setup or maybe even better if I tune it them alil more. rock on ksports
Old Mar 19, 2006 | 05:47 PM
  #882
brooklynK3Y
hey. I got a question. I just got my hands on k- sports.. I slammd da car, but ever since I put it on, I been hearing something in the back thumpin/bangin mad hard like somethings loose or something. anyone know what this could be?
Old Mar 19, 2006 | 06:42 PM
  #883
Black Maxima
Make sure the collars are tight...
Old Mar 19, 2006 | 10:54 PM
  #884
TJ_Max's Avatar
Paradox Systems Vendor
Fellas, what's full stiff? Righty tighty? Turn it clockwise until they dont turn anymore? Is that full stiff or full soft? Thanks.
Old Mar 19, 2006 | 11:01 PM
  #885
Poowill's Avatar
That is correct. Just follow the arrows on the allen wrench. All the way right is full stiff, all the way left is full soft.
Old Mar 20, 2006 | 09:12 AM
  #886
i30dvr's Avatar
ok, i just installed my ksports and i love them, but i noticed that when i put them on the were slightly lower than my gcs w/ tok. blues right out of the box. I also noticed that there is a slight clicking noise when im driving but mainly when i am turn with the wheel almost locked. could this be my halfshafts making the noise. I am planing on raising it up a little, but my question is are the ksports dropped all the way when they come from the factory? how much lower can i go, also could i possibly damage anything by going too low? thanks
Old Mar 20, 2006 | 09:39 AM
  #887
chillin014's Avatar
The concept is pretty simple really. If you play with the coilovers enough you can see how the collars and everything works.
Bottom mount spins on the threads making it longer or shorter. The skinnier collars lock against the bottom mount and the top one goes against the preload spring.
There is no "factory height" I don't think. It just comes threaded on there.
Old Mar 20, 2006 | 02:25 PM
  #888
Max4Spd's Avatar
yea its kinda tricky at first....took me some time to figure it out.
Old Mar 20, 2006 | 04:44 PM
  #889
chillin014's Avatar
same here, in fact me and my dad and his friend were looking at the damn things like they were some foreign object from outer space. but the point i was trying to make is, its alot easier to understand things when you TRY to under stand them instead of just expecting instruction.
when reading about these things before i bought them, i was extremely confused. but once i bought them and took a gander, it wasn't really all that complex.
Old Mar 21, 2006 | 04:26 AM
  #890
i30dvr's Avatar
ok, i know how they work, but my main question is that my car is making like a ticking noise doing about 40-50mph slightly on/off the gas. Could this be b/c of the height, could i damage something? please help asap thanks
Old Mar 21, 2006 | 05:51 AM
  #891
d00df00d's Avatar
Old enuf to pick his own gears
Axles. My car is doing the same thing, and this is its third set of axles....
I've said it before, and I'll say it again: If your axles are anything less than PERFECT, you WILL notice it with a drop. I got cheap NAPA remanufactured axles, and now I'm definitely regretting it.
Raxles will definitely be seeing the next $260 I get once I recover from some recent expenditures.
Old Mar 21, 2006 | 08:13 AM
  #892
i30dvr's Avatar
ok well with my car that low generally how long will the axles last? or should i raise it to where the a-arms are almost evenq
Old Mar 21, 2006 | 09:19 AM
  #893
d00df00d's Avatar
If it's any consolation to you, 99% of the time the only serious problem you'll get from your axles is noise. They won't wear down to the point that they break completely; they'll just make more and more noise over the months (or years) until your replace them. In the worst possible case, you might get a little bit extra torque steer or uneven braking, but unless you're big into performance driving, it most likely won't be a big deal.
Just replace them when the noise becomes unbearable.
Old Mar 21, 2006 | 09:31 AM
  #894
azn_s3nsation87's Avatar
Hey guys, am planning to get myself a FSTB and/or RSTB after my Ksport is settle, but i not sure which one to get? Does it matter which one to get, if its not then i'll go for cheap EBay, since am nearly broke.
Old Mar 21, 2006 | 09:34 AM
  #895
d00df00d's Avatar
FSTB, definitely. RSTB doesn't do much.
Old Mar 21, 2006 | 09:39 AM
  #896
But does it matter which brand i get? Thinking logically, i wouldnt think it matter right, as long as the the bar can handle then is fine right?
Old Mar 21, 2006 | 10:18 AM
  #897
d00df00d's Avatar
It's debatable. If you're really particular about how your car handles, then shell out the extra and get at least the Otto Racing bar (other alternatives are Alutec and Stillen). Otherwise, get the cheapest you can find.
If you can't decide, just get the Otto Racing bar. Should be $50-ish.
Old Mar 21, 2006 | 10:20 AM
  #898
there a specific site i can get that Otto? thanks mucho
Old Mar 21, 2006 | 10:28 AM
  #899
d00df00d's Avatar
Not sure. It should be available on eBay though.
Old Mar 21, 2006 | 03:43 PM
  #900
VQuick's Avatar
Chassis Freak
When I tightened my FSTB and RSTB with the car jacked in the air (a huge controversy surrounds this; most of the Org thinks this is pointless), I noticed a big difference from both the FSTB and RSTB. IMO it's an Org-perpetuated myth that the rear of the car doesn't really need a strut tower brace because the backseat/rear deck somehow provides enough structural support. This is all based on my limited experience so don't take my word for it.
Old Mar 21, 2006 | 06:24 PM
  #901
JeremysBlkMax97's Avatar
Would the JIC coilovers make the same noises as these?
Old Mar 21, 2006 | 06:33 PM
  #902
d00df00d's Avatar
They have the same general design as the Ksports, so theoretically they could have the same noise problems.
On the other hand, they're supposed to be a little better made... JICs have been getting some conflicting reviews so it's hard to tell.
But either way, if you install them right you won't have any problems.
Old Mar 21, 2006 | 09:41 PM
  #903
joebangaa's Avatar
i was curious... how often (if at all) do you guys have to tighten stuff up? I joined the ksport club last week and started having noise issues from day one after a hundred miles of driving. after dealing with it for a week, i finally got my lazy *** to check out what was wrong yesterday... turns out it was just a loose spring perch on the front driver's side. now.. today i was doing some HARD driving w/o any noises... when i finally got home and made a 3 point turn to park against the curb, the noise came back! it's too late and cold to check on it now, but i'm pretty sure it's the same issue...after one day! now, i know it's best to tighten the perches w/ the shock uninstalled, but since it's already in there, what's the best way to tighten them? yesterday when i was tightening it up, i simply put all my weight into it and used both wrenches at the same time... but apparently this isn't enough. i'll try again in the morning but if it happens again i guess i'm gonna have to reapply some threadlock... i have zero issues w/ noise or looseness on the other ones though (they too have threadlock applied)
Old Mar 22, 2006 | 04:10 AM
  #904
d00df00d's Avatar
Hard driving doesn't put anywhere near as much stress on those collars as steering while you're at a stop, so it's not really surprising.
As for how to tighten them... have you been reading?
Old Mar 22, 2006 | 05:06 AM
  #905
Iron Scimitar's Avatar
Tha Snatcher
longest thread eVar...
Old Mar 22, 2006 | 05:32 AM
  #906
i30dvr's Avatar
do you think anyone has got custom driveshafts to accomodate the driveshaft angle when the car is slammed. I had to raise my car back up b/c it seems like the cv's were angled to much. Does anyone have a fix other than raising the car up??? thanks
Old Mar 22, 2006 | 05:49 AM
  #907
d00df00d's Avatar
Raxles axles...
Old Mar 22, 2006 | 06:45 AM
  #908
i30dvr's Avatar
what kind of price are we talking? I mean if i got custom ones (shorter) which is why i think its making noise because have the a-arm flexing past 0 it pushes the driveshaft more into the cup for the diff
Old Mar 22, 2006 | 03:53 PM
  #909
Poowill's Avatar
Raxles are $119 drivers side and $149 passenger side. Well worth it though if you are lowered and don't want to hassle with going through autozone axle's every 2 weeks. Check out their site, they just look like high quality stuff! Ofcourse, raxles hold up to your axle problems, but i don't think it solves the CV boot and other issues. but overall raxles are just built very tough.
As far as i know, nothing has been made to accomadate a severe drop. Anything over a 1.5" drop distorts the geometry. If something were to be made that would be awesome. I know to many people *cough* VIP maxima *cough* it would be a relief from all their lowered problems. Me, i'd hate to raise it up...it just looks so good slammed
Old Mar 22, 2006 | 06:07 PM
  #910
i30dvr's Avatar
exactly, i love the way my car looks but the noise is ridiculous......
Old Mar 22, 2006 | 10:05 PM
  #911
VIP Maxima
i just found pics of rockin stock rims on k sports. i have to admit that proper offset can make your car look really low or high. in these pics my car looks like those two cars in NYC posted a few pages back.
boy was it slammed back then. im talkin about less than 2" ground clearnace. the 19's definetly raised it up by two inches. scrary stuff.
Old Mar 23, 2006 | 04:59 AM
  #912
i30dvr's Avatar
how many miles are on your car? have you gone through any axles yet?
Old Mar 23, 2006 | 06:16 AM
  #913
Black Maxima
Those pictures are not very clear. But looking at them they seem no where near as low as the two NYC Maximas that were posted.
Old Mar 23, 2006 | 12:00 PM
  #914
VIP Maxima
49k. i got two NEW autozone axles when i lowered my car and they are both destroyed right now.
Old Mar 23, 2006 | 02:01 PM
  #915
check mine out, the back is lower than the front am thinking of raising it up cuz it keep scratching my stock exhaust (piece of crap aniway), suggestion shoudl i raise it up an 1" or 2" for later one for my ionic side skirts and 2 rear piece.
Old Mar 23, 2006 | 03:30 PM
  #916
Black Maxima
I love your car. Man that is low. And the front lip looks excellent. I say keep it that height. How many inches is your wheel well from the ground?
Old Mar 23, 2006 | 03:47 PM
  #917
VQuick's Avatar
Chassis Freak
That's a very clean car, nice paint, but it looks way too low and you need some rims with a lower offset. I don't like the tucked under look. I think the back should be equal or higher than the front, otherwise it looks like you've got all your possessions in the trunk.
Old Mar 23, 2006 | 04:07 PM
  #918
Poowill's Avatar
Very clean car, i still wish i coulda found a black one. It looks awesome!
I like the drop but i agree with Vquick, a little lower offset would help. You could get some spacers to fill up the front a little more. I have 37mm offset on mine and it fills out about perfect:
But nice max, i actually kinda like the primed front bumper and lip
Old Mar 23, 2006 | 04:10 PM
  #919
MDeezy's Avatar
**cough** **cough** get raxles' axles **cough***
Old Mar 23, 2006 | 04:46 PM
  #920
VQuick's Avatar
Chassis Freak
I think his car is dark green, not black. Hard to say from pic.
Spacers in the front? I have spacers in the rear to even it out. Spacers in the front only would look really bad on a Maxima IMO. Do you have spacers? Your rears look about as flush as your fronts.
