Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
K-Sport Coilovers Talk
Old Sep 3, 2006 | 03:35 PM
  #1241
d00df00d's Avatar
Old enuf to pick his own gears
-1 degree here.
Old Sep 3, 2006 | 03:43 PM
  #1242
vsamoylov
Originally Posted by MDeezy
I would let the shop adjust camber but for the moment, with the car up in the air try to align the wheel as straight as possible. Hopefully the shop is close by and you dont have to drive too far.
I put new inner outter tie rod on and it was very hard to keep a straight line when driving to the shop. Even running extremely bad camber you should drive fine and make it to the shop.
i know the shop will adjust camber. all i am asking is how much negative camber they have. and the peopel that are dropped that the tires are tucked they would have more negative camber because if they would have it set to factory sepcs the tires would rub the fenders.
  #1243
steven88's Avatar
Need A Light?
hows the tire wear with -1 degree camber?
Old Sep 3, 2006 | 04:18 PM
  #1244
Norm Peterson's Avatar
-1° camber should not be a problem, especially if you drive the corners with any enthusiasm whatsoever. In fact, the harder you typically corner, the more negative you should be setting the static camber in order to reduce wear (primarily on the outer shoulder areas). If you more frequently engage in very hard braking than in hard cornering, you'll probably want a slightly less negative camber setting.
Just for comparison, the factory shop manual for my 626 (which has struts all around) lists up to -1.6° up front and up to -1.15° in the rear as being factory-acceptable. Since I doubt that there's all that much difference between different factory struts, control arms, and bushings, -1° should be fine for the front of just about any strut-suspended car. FWIW, i'm closer to -1.8° on the front of that car but have no uneven tire wear problems to report.
Norm
Old Sep 3, 2006 | 04:35 PM
  #1245
steven88's Avatar
Need A Light?
Norm
what camber arre you running on the maxima though?
Old Sep 3, 2006 | 10:54 PM
  #1246
joebangaa's Avatar
my camber is -0.5*
Old Sep 4, 2006 | 06:46 PM
  #1247
MDeezy's Avatar
Oh your asking how much negative camber can we adjust to? I'm not sure exactly. If I had to guess I would say you could push the plate all the way in (towards the engine) and probably get about -3* Just a guess.
For those tucking they would be running more negative camber to point the tire inwards to keep it from getting cut up on the fender. Those people are probably very close to the edge of the factory boundaries.
Old Sep 4, 2006 | 06:49 PM
  #1248
vsamoylov
well i spent a good couple of hours today with the k-sports and i think i am satisfied with the way the front is. i still have to put the back in and get an allingment because my toe is out and the tires rub the fender wells even though there is some negative camber.
Old Sep 4, 2006 | 07:15 PM
  #1249
d00df00d's Avatar
what Norm said.
My tires are wearing evenly. I'm not exactly an easy driver, though...
Old Sep 13, 2006 | 09:48 PM
  #1250
eckounltd287's Avatar
Likes them corn fed
anyone selling there k-sports??????
Old Sep 13, 2006 | 09:57 PM
  #1251
steven88's Avatar
Need A Light?
try the group deal forums...
Old Sep 13, 2006 | 10:18 PM
  #1252
Likes them corn fed
i'd rather pay for a used set to get a feel with out paying retail price
Old Sep 14, 2006 | 08:22 AM
  #1253
amolao's Avatar
Hi',
This is my first post, I've been a avid Nissan user for many years. I do own a 240sx and while looking for info about the ksports, found this interesting thread. This is the best I've seen about ksports. I have a fairly new set on my car now. The right front started clunking yesterday, I found that the bottom plate came loose, making the spring chew the isolator and bounce around a bit. I readjusted everything and it seems to be working now. Something else, the pillow ball is rusty....yes rust...
I think this keeps the coil from turning when is supposed to and the bottom plates work his way loose due to this. Is it safe to lightly lube the ball to keep it from rusting?? I also have a small amount of oil around the rubber protector cup on my left front coil...Is this a leak??? do I need to send this in for replacement??? The coils warranty will be over in Dec this year....
thanks and keep the great work, I will be reffering a lot of ksport users to this link......
Old Sep 14, 2006 | 04:08 PM
  #1254
d00df00d's Avatar
Yes, yes, and yes.
Old Sep 15, 2006 | 09:24 PM
  #1255
vsamoylov
what torque do you guys tighten the upper nut where the camber plates are? or do you tighten it with an impact gun? i think the noises that most people have are comming from the pillow ball area.
Old Sep 15, 2006 | 09:55 PM
  #1256
steven88's Avatar
Need A Light?
what torque do you guys tighten the upper nut where the camber plates are? or do you tighten it with an impact gun? i think the noises i have are comming from the pillow ball area because everything else is tight. I even replaced the spring isolators with ones from energy suspension.
according to ksports, it's 40lbs...
Old Sep 16, 2006 | 06:20 PM
  #1257
vsamoylov
Anybody else had this problem?
Quick question. Am I the only one that has had this happen? When installing the k-sports on the rear the whole assembly comes really close to the rear beam. Actually it hits it. This has happend both on a 5th gen and my 4th gen.
I have some pictures to show what I mean exactly.
These pictures you can see where the assembly was hitting.
Old Sep 16, 2006 | 06:23 PM
  #1258
vsamoylov
Now these two pictures show the rear k-sports installed and tha part that was hitting had to to be grinded down so there would be some cleareance.
Now this was on both sides meaning the rear right and the rear left.
Old Sep 16, 2006 | 06:24 PM
  #1259
steven88's Avatar
Need A Light?
hmm, how weird...i never had this problem...seems to be sufficent clearance when i install the lower bolt
Old Sep 16, 2006 | 06:49 PM
  #1260
vsamoylov
Well the thing is when maxs had these installed on his 5th gen he had this problem adn then when we were installing them today on my 4th gen the same thing hapend. So maxs took a grinder and fixed the problem. I am just posting this because it could be a source of noises.
Old Sep 16, 2006 | 09:59 PM
  #1261
steven88's Avatar
Need A Light?
has anyone tried 7/5 spring rates? i believe this is the lowest spring rate you can go, without ksports charging u extra for re calibrating the dampers...how is the ride quality with 7/5 springs?
I'm interested in hearing soft, medium, and full stiff settings...and what kinda tires you running?
Old Sep 16, 2006 | 10:26 PM
  #1262
Likes them corn fed
i've been browsing some of the post, but i haven't found anything about changing the Alignment/Camber Kits . is it not needed?.. also i know when lowering your angle for the tires ends up changing and the sidewalls tend to get alot more wear, is this relevant to k sports?
Old Sep 17, 2006 | 02:11 PM
  #1263
d00df00d's Avatar
Hasn't happened to me either...
Old Sep 17, 2006 | 02:12 PM
  #1264
d00df00d's Avatar
Ksport apparently doesn't have a 5 kg/mm spring available, but people have tried 8/6 with apparently very good results.
Old Sep 17, 2006 | 02:16 PM
  #1265
d00df00d's Avatar
Not sure what you mean. If you're asking whether these come with camber plates, then yes they do, and there have definitely been a few posts on how to use them.
Couple of vocabulary issues here, but I understand the question. You're asking whether installing Ksport coilovers will change your camber and cause faster-than-normal wear on the inside or outside edges of your tires. The answer is yes, although how bad it is depends on how much you lower your car: The more you lower it, the worse the camber will get.
Old Sep 17, 2006 | 02:23 PM
  #1266
steven88's Avatar
Need A Light?
how about 7/6? is that a good setup for daily & semi-hard driving?
Old Sep 17, 2006 | 02:44 PM
  #1267
d00df00d's Avatar
I'm sure it would be.
That's the setup that Tein uses on their Basic coilovers, so it can't be that bad. It's not necessarily a perfect comparison since there's more to a spring's behavior than the overall spring rate, but that should give you some idea.
There's even a chance that 7/6 springs would give you less understeer than 9/6, even though it might compromise grip and response in some cases.
Old Sep 17, 2006 | 02:50 PM
  #1268
steven88's Avatar
Need A Light?
sounds good...and if i go with this setup, i get no additional charge for re calibrating the dampers right? i could have sworn...if it's over 2kg, then re calibrating is necessary...
Old Sep 17, 2006 | 03:01 PM
  #1269
d00df00d's Avatar
Exactly. A re-valve would be nice, but it's not necessary.
Old Sep 17, 2006 | 04:47 PM
  #1270
i30dvr's Avatar
has anyone tried anything stiffer like 10/8 or 10/7?
Old Sep 17, 2006 | 06:53 PM
  #1271
vsamoylov
now are you guys jsut saying it hasnt happend to you or its just that you havent looked?
Old Sep 17, 2006 | 07:28 PM
  #1272
steven88's Avatar
Need A Light?
hasn't happened to me
Old Sep 18, 2006 | 04:06 AM
  #1273
d00df00d's Avatar
Hasn't happened to me.
Old Sep 18, 2006 | 04:08 AM
  #1274
d00df00d's Avatar
I don't think anyone's been brave enough...
If you want to stiffen things up, IMO, it'd be best to start in the rear.
Old Sep 20, 2006 | 04:50 AM
  #1275
JeremysBlkMax97's Avatar
I hate to make a stink, but beware. I have been trying to get ahold of K-Sport to have some warranty work done for about 6 weeks with no response. They don't answer the phone or respond to e-mails, and I feel like they are trying to cheat me. I wrote like 3 e-mails over a 3 week period and have tried to call them numerous times. I spoke to a rep. at Autoline Industries who does the repairs. He told me I need a return # and that I should e-mail to info@ksportusa.com. I did, and no response. What can I do to get this resolved. Doodfood, is there a "special" way to get ahold of them, even though it shouldn't be this difficult? Thanks.
Old Sep 20, 2006 | 05:19 AM
  #1276
Darius's Avatar
Try AIM. they're on almost every day. The screenname is ksportsupport
Old Sep 20, 2006 | 05:54 AM
  #1277
jinsu's Avatar
yup, that's actually the best way to reach them. they get swamped with massive emails that you probably don't get to go through all of them. AIM is the best way to go.
Old Sep 20, 2006 | 06:26 AM
  #1278
d00df00d's Avatar
on the AIM suggestion.
That company needs more staff...
Old Sep 20, 2006 | 06:54 AM
  #1279
jinsu's Avatar
they could use more staff but that staff's pay check is gonna be coming out of all you guys' pocket (higher cost of business, higher the price for customer)
Old Sep 20, 2006 | 07:13 AM
  #1280
Pretty weak that all the contact methods that they provide are useless. Am I supposed to hang out on the computer all day waiting for them to come online? This company sux.
