Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
K-Sport Coilovers Talk
Old Dec 14, 2007 | 05:56 PM
  #1961
G4nismo's Avatar
Originally Posted by MOHFpro90
Reppin the sunshine state
What is that at your upper mount?
stock perch for 5th geners
Old Dec 14, 2007 | 09:38 PM
  #1962
MOHFpro90's Avatar
^^Thank you^^ And what is your ride height? (fender -> ground?)
Also, in regards to your question about looking to be low. If your preload is fine(little to none) and youre ride height is ok, then you're good. I guess it really varies from car to car and even strut to strut.
Old Jan 29, 2008 | 03:50 PM
  #1963
bigpulve+'s Avatar
This new search is very good for searching threads so yea...
I was wondering if anyone has had trouble with the K sport springs shifting and popping when turning...its annoying because everytime I turn right It will like lock that way and will make the car pull to the right. Anyone know an idea other than tightening the perches to help it...
Old Jan 31, 2008 | 02:39 PM
  #1964
MOHFpro90's Avatar
Wow. I was going to post this same question today. I got pissed off at it coming home at the noise and 'mis-alignment'...
So when I got home, I did the following: [White Lithium] Greased Rubber on top and bottom of spring. Hammer tight all collars(dont forget black lower one!). Tighten upper nut in the engine bay(the center one that secures the strut body).
Still some clicking, but not nearly as much.
Old Jan 31, 2008 | 03:06 PM
  #1965
bigpulve+'s Avatar
You=75 degrees me=10 degrees.
The noise I dont really care about its the locking and pulling part that is annoying. I will try that if it is ever over 35 degrees here.
Old Jan 31, 2008 | 03:13 PM
  #1966
MOHFpro90's Avatar
Come on, be a man!
You could try simply putting some grease on it(on the springs/rubber). Shorter time being outside. I dont know if it will help much though. I cant think of any other way to feasibly make them stop moving without tightening them.
Old Jan 31, 2008 | 09:15 PM
  #1967
G4nismo's Avatar
the last time i tuned mine, the collars ALWAYS CAME LOOSE! i don't know why but it was like the 2nd or 3rd that it had happened. i know i tightened good but they still came loose.
i still get mild popping noises but don't care cause those are prob just the strut bolts....
Old Jan 31, 2008 | 09:47 PM
  #1968
MOHFpro90's Avatar
Also, I get noises going over bumps, almost like metal stressing, tiny creaking noises. Only front drivers side. Im thinking the upper strut mount bolts[3]?
Old Feb 8, 2008 | 01:19 PM
  #1969
bigpulve+'s Avatar
Ok so I braved the cold and have tightened everything up on both sides and it is not popping as much but everytime I move the wheel to the right it will then pull to the right until I turn the wheel left. I dont get it. On the driver side the bottom collar was a little loose but the strange this is that it was moving with the shaft. I loosed everything up and sprayed in some wd40 to clean it up and then tightened everything until I couldnt feel my hands. But to no avail it still pulled to the right after turning right.
any other ideas...maybe the bottom bolts are a little loose?
Old Feb 8, 2008 | 03:01 PM
  #1970
MOHFpro90's Avatar
I am having the same issue. I tightened all collars on mine, I still get clicking and my alignment is screwing up every time I turn.
Old Feb 8, 2008 | 03:41 PM
  #1971
bigpulve+'s Avatar
I cant figure it out...If I cant figure this out then I am going back to stock and then figure out what new setup I would want. These things really arent as great as I first thought...
Old Feb 8, 2008 | 07:23 PM
  #1972
MOHFpro90's Avatar
I want to go Koni + GC or illuminas + GC. Koni > * but the price...
Old Feb 8, 2008 | 10:16 PM
  #1973
bigpulve+'s Avatar
Well I really want them to work well. I thought the wintry weather might have had been a cause but you live in Florida and are having the same problem...
Right now I am thinking lower mounting bolts.
Oh and I had AGXs and Sprints first and the ride quality sucked so I want some thing that is softer yet will still give good handling.
Old Feb 8, 2008 | 10:43 PM
  #1974
blkAEmax82's Avatar
Glory Glory Man United
Just wondering did you guys get those new spring perches .. Would those help your guys situation ?
my perches always get lose as well .. I havent installed the new ones i gotten but (knock on wood) i havent blown any of them .
Warranty still available on your guys struts?
Old Feb 9, 2008 | 05:12 AM
  #1975
MOHFpro90's Avatar
Nope, havent gotten them. Nope, no warranty.
Old Feb 9, 2008 | 08:16 AM
  #1976
bigpulve+'s Avatar
MY problem isnt that the perches become loose. Actually my driver side was so tight it was spinning the whole threaded part when I tried to loosed one up. Im starting to think that the pulling might be somehow caused by the lower mounts.
Im gonna email K sport and see what they say...
Old Feb 11, 2008 | 02:26 PM
  #1977
bigpulve+'s Avatar
Well I got an email back from K sport and they think either I have to much preload or the spring washers are either torn or really dirty...well I am going to try reducing the preload I have on them first and go from there.
Old Feb 11, 2008 | 04:43 PM
  #1978
Jarods7920's Avatar
my ksports have been great since the day i bought them
Old Feb 11, 2008 | 05:49 PM
  #1979
JAMAICANLOVRBOY's Avatar
how much did those set u back?.
Old Feb 11, 2008 | 06:04 PM
  #1980
skuccio's max's Avatar
Beast Mode!!!
Wowsers
How long is it before you guys have problems?
I have Nex coilovers, had them since November, no clicking, no change in ride no problems.
Old Feb 11, 2008 | 06:43 PM
  #1981
bigpulve+'s Avatar
Originally Posted by skuccio's max
Wowsers
I bought mine back in june, but in november I raised my car for winter and that is when it started...I most likely put to much preload on them and will be lessening that in the near future...
Old Feb 13, 2008 | 12:32 PM
  #1982
bigpulve+'s Avatar
Update...
Well I reduced the preload to just where the springs are tight but dont move much...they was a lot of preload on them. Also cleaned up the spring washers and such. I was satisfied that it was fixed until I took a test drive. Still pops and still pulls to the right.
Stock here I come...again.
Old Feb 13, 2008 | 06:51 PM
  #1983
MOHFpro90's Avatar
I want to get rid of these too...hmm but stock ride height sucks.
What setup you looking at?
Old Feb 13, 2008 | 07:19 PM
  #1984
Beast Mode!!!
Originally Posted by mazzivart
Update...
They didn't come preloaded from the factory???
Old Feb 14, 2008 | 08:54 AM
  #1985
bigpulve+'s Avatar
Well I am going to stock for now and when i have an extra 700 to burn I am looking at maybe sprint again with some Illuminas... I want the softness...
Technically they did but since I messed with them prior to winter I put a lot of preload on them...backed it pretty much all the way down but it didnt fix it....I am tired of messing with these things...
Old Feb 14, 2008 | 06:06 PM
  #1986
adriena's Avatar
mine need to be re-built. whats the website or number i should go to or call?
Old Feb 19, 2008 | 02:16 PM
  #1987
MOHFpro90's Avatar
Anyone know how to remove the pillow ball mount? Got the camber plate and all the collars/perches of, but cant get this little bugger off.
Old Feb 19, 2008 | 03:16 PM
  #1988
bigpulve+'s Avatar
what are you tying to do?
Old Feb 19, 2008 | 03:57 PM
  #1989
MOHFpro90's Avatar
I am cleaning, regreasing and tightening the collars and perches. I got the mount off, now I am not sure how to get it apart to clean/regrease?
Old Feb 21, 2008 | 04:43 PM
  #1990
MOHFpro90's Avatar
Time to throw a . I fixed my clicking(temporarily and hopefully for a while).
My right front was the one giving me the issue. I took it off the car and removed the following parts from the coilover:
Lower black collar
Orange mount
Lower Orange collar
Upper Orange Collar
Lower Spring perch
Spring
Rubber/Plastic perches
Upper nut
Camber plate
Pillow Ball mount
1. I cleaned the threaded body very well
2. Soaked the collars/perches/mounts in Simple Green and removed any loose dirt/grease.
3. Cleaned the pillow ball mount bearings, used white lithium grease on the top and bottom of the ball mount.
4. Used Wd-40 to remove rust in the threads on the camber plate alan bolts.
5. Reassembled, and tightened everything while it was off the car(more efficient tightening)
I have a video of how easy the camber plate/pillow ball spun, I will have to get that later.
I have driven about 90 miles on them(I know, not much yet), but have been over speed bumps, through 3 parking garages and more parking lots. No clicking yet.
Old Feb 21, 2008 | 04:48 PM
  #1991
bigpulve+'s Avatar
Lower black collar
Orange mount
Lower Orange collar
Upper Orange Collar
Lower Spring perch
Spring
Upper nut
Camber plate
Pillow Ball mount
Do you get any popping from the springs? Any pulling to the right?
Old Feb 21, 2008 | 05:25 PM
  #1992
blkAEmax82's Avatar
Nice job MoHF... cant wait for that video wouldnt mind doing all that when i finally get some ***** to put the new spring perches on .
Old Feb 22, 2008 | 08:34 AM
  #1993
MOHFpro90's Avatar
Change your name mazzivart? Anyhow, No, no spring popping. The lithium grease took car of that. My alignment is off now, so I pull left, but if I got it aligned, there would be no pulling, as it doesnt pop and adjust itself around a turn.
However, I wouldnt call this a total victory yet, who knows how long it will last? I am hoping for quite a while.
Old Feb 22, 2008 | 12:24 PM
  #1994
bigpulve+'s Avatar
Yea I did...I got sick of that one....
Yea so the pillow mount was the culprit? Just wondering because I am going to clean my K sports after I get my stock stuff on...Dont want to sell them dirty...
Old Feb 22, 2008 | 07:59 PM
  #1995
MOHFpro90's Avatar
Yes, the pillow mount and the collar threads having dirt in them. And the perches not moving freely.
Old Mar 2, 2008 | 10:02 AM
  #1996
SWIFTMAXAZ's Avatar
I just have to say... I've had these for a while now... THEY SUCK. Don't waste your money on them. You will hate them eventually. I sooooooo regret buying these. If I had nothing better to do... I'd find a way to start a class action lawsuit on ksport.
Old Mar 2, 2008 | 10:08 AM
  #1997
chillin014's Avatar
how much are these things going for now days? 650 bucks new? You get what you pay for.
I've had a love hate relationship with mine. Right now they are like 2 years old and I think another one (or maybe more) just blew out. I'd like suspension to be something I can put on a car and not worry about replacing every 15 thousand miles. I've got enough trouble keeping tires on my car as it is.
Can someone point me towards the products that are performance-oriented and therefore have the longevity, quality superior to that of stock equipment?
Old Mar 2, 2008 | 10:22 AM
  #1998
bigpulve+'s Avatar
I have only had mine for like 8 months and I completely hate them...they are the worst buy I have done for this car...I am now going back to stock before I get some illuminas/eibachs or sprints...
I wont even sell these because I dont want to put this problem on someone else...
Old Mar 2, 2008 | 10:26 AM
  #1999
chillin014's Avatar
You know what kills me is that when these first came out people were hyping the sh*t out of these. Like a stupid noob I jumped right on the bandwagon and got me a set. I dont even know what direction to go next when I upgrade..but I have learned to take what I read online with a grain of salt.
Old Mar 2, 2008 | 10:28 AM
  #2000
bigpulve+'s Avatar
The only track record that right now I am ok with going is either straight stock or the illumina eibach route. Those seem to be the only two that seem to be the most problem free.
just realized this is the 2000th post.
