THE BBK PiCTURE THREAD (Show off your BBK setup here)
i have a 4th gen maxima im thinking about doing a bbk with the works and all...W hat would be the best way to go as far as choosing the company thats sells the kits...I know that Brembro does not make them for the 4th gen anymore.... What can i do i really wanted them but hey thats life....What to do fellas can some one help me out
thx
thx
When you buy standard Brembo rotors with holes, they have been DRILLED after the fact, not cast that way.
Hey Wizard,
How do you like the kit ? I just had my 1st track event with them and I think I will dump the Brembo pads for some Hawks. The floating rotor design takes getting used to when braking on the track, initially it feels like the rotors are warped under light braking when the brakes are HOT... but when you hit them harder they just stop the car like crazy.
I would also like to thank you for posting pictures of 17" wheels over them. I am going to pick up some 17" track wheels so I can run my Hoosiers on them, and I wasn't sure if they where going to clear the calipers.
I need to upgrade the rear brakes now, they actually get really hot on the track and stink a bit. HPS on stock rotors.
Well got mine put on now...got bored at work 1 day :P
300-Z Calipers/rotors milled 4mm in diameter everything else stock for now no mods had to be done to get them to fit everything bolted right up,hopefully have stainless lines soon!
Last edited by Afterlife; Feb 29, 2008 at 04:50 PM. Reason: 4mm spacers for the murano wheels to fit also.
From: Long Beach, CA is where i live. Queens NYC is always home.
[IMG][IMG]<a href="http://s292.photobucket.com/albums/mm14/GAMERA30/?action=view¤t=caliperclearance.jpg" target="_blank"><img src="http://i292.photobucket.com/albums/mm14/GAMERA30/caliperclearance.jpg" border="0" alt="Photobucket"></a>[/IMG][/IMG]
Thanks for the backup Newfound...here`s what I actually wanted to post.
92 Max SE ... cobra rotors,Q45 calipers,Maxxim Oxygene rims... Close fit huh ?
IMG]http://i292.photobucket.com/albums/mm14/GAMERA30/Cobrafront.jpg[/IMG]
very clean on the altima. I just bolted up some G35 Coupe wheels. Feels great to have tons of clearance between the inner barrel of the wheel and caliper now compared to the crappy 17s I had.
HEY GUYS ?!?!?!.... I made a nice discovery for those w/ 3/4th gen maxima`s who want brembos. Using SER Spec V Brembos will bolt up. All u have to do is drill the rotors to 5 lug and they bolt right up. For a mock up on my friends B15 sentra, I used 3rd. gen Max rotors w/Maxima calipers. We found out the dimensions from the FSM that the 2k Sentra SE ( w/sr20de) are the same size rotors and same calipers as 3/4th Maxima`s. Being that the B15 Spindle is the same on the SE-Spec V, The Calipers are the direct bolt on w/ the rotors drilled. I`m searching for Brembo calipers from a Spec V to d the test fit on my 3rd gen.
The holes aren't drilled after the rotor is produced, they are part of the mold Brembo uses and cured in place.
