Sponsored by:
Sponsored by: CARiD
VQ35 internals in VQ30 makes VQ33 stroker, bolt on! PICS!
Old Apr 5, 2004 | 09:21 PM
  #81
stephenlc's Avatar
Does someone have the pictures from my350z.com I have been trying to get on their forever and I can't, you have to be a member
Old Apr 5, 2004 | 11:41 PM
  #82
SupermaxGxe's Avatar
Originally Posted by icemax
how about valve clearance, any issues there?
That's the same question I have. I am in the prrocess of building an engine right now, it's down to nuts and bolts. If I can drop in this setup that would be great.
-Chris
Old Apr 6, 2004 | 04:25 AM
  #83
Deac's Avatar
Originally Posted by BigDogJonx
93mm 3.0L
94.5mm 3.5L
Nice discovery Dixit. It will be interesting to see how this will work out!
Deac
Old Apr 6, 2004 | 04:27 AM
  #84
multiplexor's Avatar
so how much more power do you think doing this will gain? approximately?
Old Apr 6, 2004 | 05:10 AM
  #85
JAY25's Avatar
Originally Posted by Oxidizer2k
now... who can figure out to get better gas milage?
Buy a Geo Metro, over 30MPG
Old Apr 6, 2004 | 09:33 AM
  #86
SkyMaxGTR's Avatar
wow thats amazing, def. a BAD *** discovery!!!...looks like i'm goin to have to switch out some engine parts with my sisters VQ35 engine with mine, without her knowing LOL
Old Apr 6, 2004 | 09:56 AM
  #87
krismax's Avatar
Father of the 00 VI
I dont know much about this stuff but I plan on reving really high and what would be the result if you used the 3.5 block and pistons and 3.0 crank and rods . Thanks
Old Apr 6, 2004 | 10:01 AM
  #88
BigDogJonx's Avatar
SkyMaxGTR, if you do that then you and your sister will have almost the same size engines because you will destroke her engine bring it down to like 3.2-3.3L.
krismax: Wont be an issue as long as you stay below the 7200rpm level.
Dixit
Old Apr 6, 2004 | 10:22 AM
  #89
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
You'd be fine up to 8000rpm, since the piston speed would be equivalent to a stock VQ35 stroke at 7200rpm.
Old Apr 19, 2004 | 06:52 PM
  #90
THT's Avatar
THT
Throbbing member
What's the status on this? Does the car run?
~THT
Old Apr 19, 2004 | 07:07 PM
  #91
stephenlc's Avatar
I think they were just playing around, it was 2 peoples seperate parts.
Old Apr 19, 2004 | 07:28 PM
  #92
THT's Avatar
THT
Throbbing member
I wana know because I think I can have this done for the cost of labor but will only do it if it's proven to work.
~THT
Old Apr 19, 2004 | 07:33 PM
  #93
BlueC's Avatar
wat
~THT
I also want to know if everything is ok, and all you need is just the crankshafts and the rods from the VQ35 and nothing else. This will be my summer project if all goes through. Auto + MEVI + 3.3L = fun
Old Apr 19, 2004 | 07:37 PM
  #94
BigDogJonx's Avatar
Easy there cheetahs. My main job is a software analyst, not a fulltime mechanic.
Dixit
Old Apr 19, 2004 | 07:48 PM
  #95
Jason R's Avatar
aka UNCDooD
Dixit
come on now dixit, you know you are supposed to dedicate all your free time to the .org. j/k
if this setup works i know what i'll be saving up for all summer.
Old Apr 19, 2004 | 09:08 PM
  #96
Blackwind's Avatar
i have an extra vq in the garage right now. hehehe!
Old Apr 20, 2004 | 06:22 PM
  #97
flashover's Avatar
Kudos all involved. New to the Vq, this is going to be a great improvement when I rebuild later this year. Keep posting. this is a great thread.
Old Apr 20, 2004 | 08:26 PM
  #98
Jack3D's Avatar
I love it! I'll be attempting to sell/trade my max in for one with a stick....this would be great to do!
Old Apr 21, 2004 | 12:26 AM
  #99
ChromeSE5's Avatar
This is going to be good hopefully. Thank goodness I only have to pay for parts. Big props Dixit
Old Apr 21, 2004 | 10:57 AM
  #100
BlueC's Avatar
wat
Anyone have a ballpark range of how much this would cost for a shop to install the cranks + rods?
Old Apr 21, 2004 | 11:38 AM
  #101
BigDogJonx's Avatar
Shop charges can vary alot due to the complexity of the build according to them.
I see shops charging normally $1000 at least just to remove the engine and tear it down. Then you talking about getting a VQ35 so you can steal the parts from which will run anywhere from 500-1000. No point in ordering it from a dealer since it will be more than a new engine. Then need new bearing seals, rod bearings, etc.
The cost of this is probably going to run in excess of $3000 in my opinion if you get a shop to do this.
Do it yourself and probably look around 1000-1500.
Dixit
Old Apr 21, 2004 | 11:47 AM
  #102
BlueC's Avatar
wat
Ive located the parts (crankshafts + rods) for under 500. I can get a whole VQ35 for under 900.
So what other parts are needed? bearing seals? whats else?
All im worried about is labor costs. But Im sure i can find a shop to do it for a good price.
Old Apr 21, 2004 | 12:23 PM
  #103
BigDogJonx's Avatar
I dont have the pricing on seals and bearings, but you talking about all the crank bearings, cap bearing, rod bearings, front and rear engine seals, and other misc items that will have to be replaced since you are that deep into the mess. Not to mention depending on your motor condition possibly new Piston rings, oil rings and probably hone the cylinder walls.
You may be able to find a shop at good price, but im still thinking no normal performance shop is going to do this all for less than 1500-2000 in just labor. I know you looking at at least 10hrs they will probably charge in just engine rebuilding time not to mention the engine removal and inserting times.
Dixit
Old Apr 21, 2004 | 12:33 PM
  #104
IceY2K1's Avatar
Hmmmnnn.....
I guess it would be better to just swap the VQ35 short block and just use VQ30 heads.
Dixit
Old Apr 21, 2004 | 12:38 PM
  #105
BlueC's Avatar
wat
sounds like it....
Old Apr 21, 2004 | 12:47 PM
  #106
BigDogJonx's Avatar
Originally Posted by IceY2K1
Hmmmnnn.....
Now you tell me........
I dont know what my plans are on this, its been up in the air on this setup for the past month now since the cost is starting to outweigh what i budget'ed.
Dixit
Old Apr 21, 2004 | 12:53 PM
  #107
BlueC's Avatar
wat
What would be involved in using the VQ35 short block?? Technically would it be less work?
Old Apr 21, 2004 | 12:55 PM
  #108
SR20DEN's Avatar
VQ Wizard
Damnit, someone just bring me a 4th gen so I can do the how-to on the VQ35 swap. I still do not understand why any of you want to short change yourselves by settling with 3.3 liters instead of 3.5 .
Old Apr 21, 2004 | 12:56 PM
  #109
IceY2K1's Avatar
Hahahahaha...LOL! Like I'd have a clue what it costs to build an engine.
For the price you paid, I think you can sell off parts and eventually get your money back, so not too bad off.
We still don't know if Mardi was sucessful or not, but he keeps hinting like he was, ie "my compression ratio is around 10.5:1". Until he or someone does it, who knows if it will work. Plus, 11+:1 CR isn't going to be boost friendly and SGP or similar low CR pistons are pricey.
Dixit
Old Apr 21, 2004 | 01:05 PM
  #110
THT's Avatar
THT
Throbbing member
You need a 4th gen? How's this summer look?
~THT
Old Apr 21, 2004 | 01:20 PM
  #111
Luquire's Avatar
I would seriously think about getting a VQ35 if it would work with my 5 speed
Old Apr 21, 2004 | 01:25 PM
  #112
jetsam's Avatar
I can!
step 1: install tall tires. 225/75 reduces engine speed from 2400rpm to 2100rpm at 60mph in 5th.
step 2: install 3:1 diff. to reduce 60mph engine speed to 1700rpm.
step 3: replace intake with 2½" cone and muffler with 1¼" pipe so your engine breathes like a 1.5 liter 3 cylinder. The maf will meter much less fuel now.
Old Apr 21, 2004 | 01:29 PM
  #113
95maxrider's Avatar
Lightly modded
sorry to hijack, but this is thread has some knowledgeable people in it, so...
whats the deal with the 3.5 Altima 5 speed tranny? is it the same as the 2k/2k1 5 speed in the maxima? i dont think it has LSD as an option, but if it's stronger than our 5 speeds, and isn't as notchy/time consuming as a 6 speed swap, i think it might be worth looking into for people with blown trannies.
  #114
IceY2K1's Avatar
The VQ35 in the Altima uses a 5spd...doubt it's much different.
Supposedly, someone here bolted up the 6spd to the VQ30, so I'd say it can be done.
Old Apr 21, 2004 | 01:31 PM
  #115
IceY2K1's Avatar
Haha...posted at the same time.
Old Apr 21, 2004 | 01:47 PM
  #116
95maxrider's Avatar
Lightly modded
right, but you dont think nissan would beef up the tranny when going from 222 hp to 240/245? or do i have too much confidence in nissan?
Old Apr 21, 2004 | 01:48 PM
  #117
flashover's Avatar
Are there any mating problems with the Vq30 heads on the Vq35 lower? I am debating what to do. Again though, i have a 4th gen.
Old Apr 21, 2004 | 03:07 PM
  #118
007max's Avatar
so what is the status of this? has anyone put together a vq33 yet to see if it runs? has anyone done the vq35 block with vq30 uppers and lowers yet?
Old Apr 21, 2004 | 03:20 PM
  #119
SR20DEN's Avatar
VQ Wizard
"whY havE A 3.5 wHen I cain hav A 3.3 wIth l3ss powah f0R More $$$"
Old Apr 21, 2004 | 03:40 PM
  #120
flashover's Avatar
so its cheaper to drop a VQ35 lower into a 4th gen... do the manual tranny's hook up?
