Sponsored by:
Sponsored by: CARiD
VQ35 internals in VQ30 makes VQ33 stroker, bolt on! PICS!
Old Apr 21, 2004 | 03:51 PM
  #121
BlueC's Avatar
wat
Originally Posted by SR20DEN
"whY havE A 3.5 wHen I cain hav A 3.3 wIth l3ss powah f0R More $$$"
So how cheap is it then??? Id do the 3.5 swap, but swapping in a completly different engine means new parts. If the block itself bolts upto the VQ30 heads id do it in a second.
Old Apr 21, 2004 | 05:02 PM
  #122
SR20DEN's Avatar
VQ Wizard
The cost of the VQ35 longblock, ECU, wiring harnes.
Tranny optional.
The easy way is just to use the VQ35 shortblock and bolt on the VQ30 front and top end. The comp. will be 11.5 to 1
Old Apr 21, 2004 | 05:39 PM
  #123
BlueC's Avatar
wat
You sure the short block fits?? How hard is that to do? Ive located VQ35 blocks cheap like $300-500. Id do it in a second if its an easy swap.
Old Apr 21, 2004 | 11:31 PM
  #124
007max's Avatar
Tranny optional.
what exactly do you mean by VQ35 longblock & VQ35 shortblock? i'm lost here
Old Apr 22, 2004 | 06:17 AM
  #125
BlueC's Avatar
wat
Long block is the entire engine. shortblock is just the block itself, no cyl heads, manifold, etc.
Can Anyone else confirm the VQ35 shortblock bolts upto the VQ30 cyl heads?
Old Apr 22, 2004 | 06:49 AM
  #126
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Nobody can 100% confirm/deny, since nobody has done it or at least admitted it, yet.
Mardi and I believe Tilley(could be wrong) have both sat the 3.0 heads on the 3.5 block and said they look fine/good. Other then that, seems like everyone is waiting for someone else to make the first leap-of-faith.
Old Apr 22, 2004 | 06:55 AM
  #127
Donkey®'s Avatar
wat
I'll confirm it if you need independant scientific laboritorical testing.
Old Apr 22, 2004 | 11:49 AM
  #128
BlueC's Avatar
wat
If all I need is the VQ35 short block and nothing else, ill be doing it in a couple months. Ive located a short block w/ 9k miles off of a pathfinder for $500 shipped. If thats ALL i need to do the swap, im doing it soon.
Old Apr 22, 2004 | 12:19 PM
  #129
IceY2K1's Avatar
You'll at least need a 350z head gasket and I'm not sure which flywheel, since all Pathfinders are autos.
Is it coming with accessories, ie alternator, A/C compressor, water pump, power steering, etc? If not, you'll have to swap all those over, I think.
I'm not sure about fuel/timing and there are probably lots of other small tidbits you'll find out along the way too like hoses/EGR stuff/etc..
Old Apr 22, 2004 | 12:51 PM
  #130
95maxrider's Avatar
Lightly modded
err, i *think* 3.5 pathfinders come, or came with stick as an option. i think the engine with the stick also got a 5 hp bump. i could be confused with something else though.
Old Apr 22, 2004 | 03:14 PM
  #131
IceY2K1's Avatar
Looks like you're right, in 2001 SE models, at least.
Bet his is an auto or doesn't come with a flywheel though.
Old Apr 22, 2004 | 05:47 PM
  #132
BlueC's Avatar
wat
Im auto, so why would I need a flywheel then..?
Old Apr 22, 2004 | 06:04 PM
  #133
SR20DEN's Avatar
VQ Wizard
Block = BLock
Short Block = Block with crank,rods, pistons assembled.
Long Block, Fully assembled engine, minus a few details specific to the recipient vehicle
Old Apr 22, 2004 | 07:47 PM
  #134
billy_corgan's Avatar
And if Chase (BlueC) does this, I will be right behingd him, You first though.
Old Apr 23, 2004 | 03:42 AM
  #135
BlueC's Avatar
wat
Haha, so you can learn from my mistakes. Dont worry, It will happen, its just a matter of time.
Old Apr 23, 2004 | 03:53 AM
  #136
You got it!
Old Apr 23, 2004 | 05:01 AM
  #137
Stephen Max's Avatar
So a VQ35 block with VQ30 heads gives 11.5:1 CR? That is a significant enough bump in CR that ignition timing might be an issue. A J&S Safeguard might be a good idea for pulling timing if detonation becomes a problem. Or burn race gas.
Old Apr 23, 2004 | 06:20 AM
  #138
Just came across this in nissanperformancemag.com:
Nissan Motorsports just released a new head which has the VQ30DE chamber volume but the VQ35DE ports and titanium valves which raises the compression ratio to 12:1 if you’re interested in building a naturally aspirated Maxima.
Old Apr 23, 2004 | 07:45 AM
  #139
IceY2K1's Avatar
You wouldn't...I don't have everyones trannys/mods memorized yet, but I'm working on it.
Old Apr 23, 2004 | 07:54 AM
  #140
BlueC's Avatar
wat
Awesome, so that mean the swap is easier than you thought. Im still waiting to hear back from the salvage yard to get a quote on what kind of condition the short block is in. If it tests out ok, Ill seriously consider doing this. Im also going to contact a couple shops I know and get their opinion on costs.
Old Apr 23, 2004 | 08:24 AM
  #141
IceY2K1's Avatar
Honestly, I don't have a *CLUE*. As much as I'd like to tell you to go for it, you really should be asking Mardigrasmax what's involved. He knows more about this swap then anyone at this point, I'd say.
Old Apr 23, 2004 | 11:28 AM
  #142
BlueC's Avatar
wat
Yea hes hard to get ahold of. I DID however print of like 5 pages of diagrams comparing the VQ35 on the Pathfinder to the VQ30 on the maxima from Alldata. Looking closely, they are very similar, the cyl heads look like they will bolt up fine, youd just need a different headgasket like you said. Since its just a shortblock being replaced, theres not alot of tearing apart to do. We'll see, Im going to do hours of research before I do anything, but this has major possibilities.
Old Apr 23, 2004 | 11:36 AM
  #143
IceY2K1's Avatar
I'm pretty sure on the cylinder heads, since I've heard from two different sources they line up. Gasket is a given, but the 350z one has more layers then the VQ35 Max one so it might be a littl stronger. That with head studs should clamp down nicely.
Don't let me deter you and keep us posted.
Old Apr 23, 2004 | 11:38 AM
  #144
SupermaxGxe's Avatar
What is the horsepower rating on a pathfinder?
Old Apr 23, 2004 | 12:22 PM
  #145
Kevlo911's Avatar
Kevlo for President
240hp...
Old Apr 23, 2004 | 12:35 PM
  #146
stephenlc's Avatar
Can you post link, I searched but could not find it.
Old Apr 23, 2004 | 01:30 PM
  #147
IceY2K1's Avatar
One big difference to note that I've found between the VQ30 and Pathfinder VQ35 is that the VQ35 was *CLEARLY* designed with reducing detonation in mind per SAE tech article:
IMPROVEMENT OF EXHAUST PORT SHAPE – Knock
resistance of the VQ35DE has been improved by
reducing the temperature around the combustion
chamber as a result of improving exhaust gas flow by
adopting an improved exhaust port shape.
IMPROVEMENT OF WATER FLOW BY LONG REACH
SPARK PLUG – Cooling performance of the VQ35DE
has been improved by expanding the water jacket
around the spark plug as a result of increasing the spark
plug screw length. Consequently, knock resistance has
been improved.
Since you can't use the VQ35 heads and you're bumping compression considerably, you're going to need to worry about this. I'd recommend having the combustion chamber bowl(top-half of combustion chamber) in the VQ30 heads deburred, smoothed, and opened up as much as possible to remove any ridges/areas that could be likely ignition spots and open up a few cc's maybe to help lower CR some. I'd also recommend at a MINIMUM having Swain Tech TBC coat the heads, valves, and top-half of the combustion chamber for $190. You could do exhaust ports and more too.
Old Apr 23, 2004 | 02:51 PM
  #148
flashover's Avatar
Ok, IceY2K1
What is the difference between the VQ35DE Max engine and the Pathfinder's? Why is everyone viewing the Path's short block versus the Max's?
I really want to try and figure this out. I live in Nebraska, but would be willing to drive to Kansas City to work on this.
Oh, this is an awsome idea. Hope it floats.
Old Apr 23, 2004 | 02:55 PM
  #149
Originally Posted by flashover
Ok, IceY2K1
I don't think theres and differance performance wise between the two when it comes to the short block. It's when you put on the head that there is a differance ie. cams, valves, intake manifold, ect... I hopes this helps.
-Chirs
Old Apr 23, 2004 | 03:17 PM
  #150
IceY2K1's Avatar
AT LEAST heads, intake/exhaust ports, cams, valve timing, compression ratio, intake, intake manifold, ignition timing, valvetrain noise/vibration reduction measures, silent timing chain, etc..
However, the ONLY short block difference I can tell are oil pan ribs for stiffness/noise reduction ASSuming the compression bump from 10:1 to 10.3:1 was from the top half of the combustion chamber.
At least from what I can understand from the SMALL SAE tech docs I've read, which may not include 100% everything.
Ok, IceY2K1
Old Apr 23, 2004 | 04:29 PM
  #151
flashover's Avatar
So the PathVQ35's comp is 10.3:1, eh? if im reading that right. Hmmm.... So look for the 2001 Path SE 5-speed short block. Gotcha.
Im im wrong.... Dogh!
Where can I find data to calculate the new timing?
The PVQ35 short with VQ30DE as the rest.
Right?
Old Apr 23, 2004 | 11:25 PM
  #152
IceY2K1's Avatar
No, 10:1 on the 2nd gen VQ35.
Latest VQ35s(3rd Gen) like the Altima, Max, Z/G, are 10.3:1.
Old Apr 24, 2004 | 05:01 AM
  #153
2k3TitaniumSe's Avatar
Very nice work, Dixit. I'm wondering if I can do this to my VE30DE.
Old Apr 24, 2004 | 06:21 AM
  #154
SR20DEN's Avatar
VQ Wizard
Just look for a Maxima/Altima long block. They're far more abundant in the boneyards.
Old Apr 24, 2004 | 04:11 PM
  #155
http://www.nissanperformancemag.com/march04/ask_sarah/
At the bottom of the page.
Of course, that is from the same person who wrote:
Turbos use wasted energy from the exhaust stream while superchargers use a compressor, to increase the density of the intake air charge.
Old Apr 24, 2004 | 05:12 PM
  #156
stephenlc's Avatar
Thanks man.
Old Apr 24, 2004 | 05:29 PM
  #157
SR20DEN's Avatar
VQ Wizard
The only thing you can do to the VE30 is possibly getting a VG33 shotblock and seeing if the VE stuff will bolt upto it. Keep in mind that the VG33 uses the same 83mm stroke as the VG30 and VE30. the only difference is the bore (raised to 91.5mm over 87mm)
Old Apr 25, 2004 | 03:08 AM
  #158
MrGone's Avatar
The only problem is the VE is a chain, while the VG is a belt.
Later today I'll see if the VG30DE crank will fit in the VE. Still, it's a pain because the VE was only produced for 3 years and the only real options so far seem to be using 300zx pistons/rods.
it still owns you
I'll post pics of VG30DE vs VE30DE cranks when I get my camera back. (hopefully tonight)
Old Apr 25, 2004 | 03:53 AM
  #159
Jime's Avatar
She also wrote this, which is BS:
"However, since the transmission controller is programmed to give full line pressure at wide open throttle"
http://www.nissanperformancemag.com/...r03/ask_sarah/
However her editor admitted finally that it was wrong but it was never edited so people still read that BS and believe it.
Old Apr 25, 2004 | 11:30 AM
  #160
BlueC's Avatar
wat
Anyone know how much the shortblock weighs??? I had some extra time this afternoon, so I looked through the engine bay seeing how much room there is to play with, overall I think if I spent a couple weeks during the summer, the shortblock swap could be done in my garage. Im wondering about the weight to know what tools would be neccessary for the swap. I think this swap is very doable, but it would require a good week or two so I can take my time and make sure everything goes together ok.
I think the first step is 1) Save up $$$
I know im not capable of doing it by myself, but with the help of a couple experienced people, diagrams, part #s list, and a good amount of tools, I think I can accomplish this. Nothing better than tearing apart the engine bay to prepare it for a large raw NA power upgrade.
