Sponsored by:
Sponsored by: CARiD
How does the JWT ecu change rpm limit?
Old Oct 12, 2004 | 08:17 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
Does the JWT ecu cut off injectors or fuel pump for the rev limiter?
Old Oct 12, 2004 | 08:28 PM
SR20DEN's Avatar
VQ Wizard
It will be a normal injector off fuel cut. And if want you can specify exactly how you want the rev limiter to work. You can make the on/off more narrow like some '95 Nissans or wide like most of them.
Old Oct 15, 2004 | 12:04 PM
Toolrocks's Avatar
sr20den, what do you mean by making the on/off more narrow? Guessing, I think you mean that the fuel cut can be tapered or all at once?
Old Oct 15, 2004 | 01:34 PM
Kevlo911's Avatar
Kevlo for President
They make extended fuel and ignition maps to extend the redline.
Old Oct 19, 2004 | 10:28 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Same with TS, ie add more columns/rows to the stock map.
However, I've noticed a few TS fuel maps tend to still jump lean after the stock redline to new redline range.
Old Oct 25, 2004 | 02:20 AM
ChromeSE5's Avatar
Is it that much harder to find and unlock the coding in order to do this? I mean $500 harder?
Old Oct 25, 2004 | 10:34 AM
IceY2K1's Avatar
What do you mean "unlock the coding"?
There isn't a magic address somewhere containing a hex representation of 6400 that can just be changed to 7XXXrpm. They need to fill in points, so the ECU can interpolate the additional timing/fuel data between those points.
mvm062
Nov 30, 2020 09:00 AM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 10, 2015 09:35 PM
slowlifer
Sep 8, 2015 05:53 AM
dcardello
Sep 3, 2015 11:44 PM
