Heard JWT cams in a VQ35 last night...
Old 10-29-2004, 05:04 PM
Fastest Fantasy Maxima Evar
IceY2K1's Avatar
I met up with PhnxBlu and it sounded mellow at idle...not lumpy at all. I can't comment on mid/top-end sound, since he just rev'd it a bit in neutral.
He has PR CAI, HS headers, Budget bpipe, Cattman rear section(older style I think), and a custom TechnoSquare reflash for cams to smooth the idle/hicuping issues.
Very healthy sounding HOT car.....
IceY2K1 is offline
Old 10-29-2004, 06:53 PM
Bacon Lover
Tatanko's Avatar
Ahh...so the ECU was changed a little to accomodate the idle? I wonder what it would sound like without that...
Tatanko is offline
Old 10-29-2004, 10:34 PM
living out of a maxima...
JeffesonM's Avatar
what does it idle at?
JeffesonM is offline
Old 10-30-2004, 05:32 AM
Kevlo for President
Kevlo911's Avatar
I would take a guess and say around 900
Kevlo911 is offline
Old 10-31-2004, 03:41 PM
Lives in a 11sec maxima
TILLEYS99's Avatar
my girls 3.5 4th gen with cams idles around 500-600 fine
TILLEYS99 is offline
Old 10-31-2004, 07:25 PM
Cumalot's Avatar
So is it ok to idle around 600 rpm with JWT cams? I heard 900 rpm is the ideal idle. I tried adjusting the idle, but no matter what I do, the idle doesn't change. It stays around 600-650 rpm.
Cumalot is offline
Old 10-31-2004, 08:15 PM
2060lbs and falling...
Broaner's Avatar
Why does the 5th gen need a different idle? Doesn't the CVCT deal with the rough idle by itself. Thats the way it is on the Z's at least.
Broaner is offline
Old 11-01-2004, 09:22 AM
IceY2K1's Avatar
No, it ran bad, not sure how, until TS reflashed it a couple times in person.
The idle didn't sound raised extremely high, but I didn't visually notice on the tach what RPM it was set at. I asked PhnxBlu what TS changed and he didn't know. He just said it was having driveability issues and that the TS reflash fixed it nicely, however supposedly it dropped his peak power a bit, maybe 10whp.
IceY2K1 is offline
Old 11-01-2004, 01:37 PM
Kevlo for President
Kevlo911's Avatar
Warm up car. Turn off. Dissconnect TPS, turn on car. Adjust idle screw on IACV. Turn off car, plug in TPS.
Kevlo911 is offline
Old 11-01-2004, 04:38 PM
Cumalot's Avatar
I already know how to do it. Didn't work for me.
Cumalot is offline
Old 11-01-2004, 05:03 PM
I30tMikeD's Avatar
you can just adjust the TPS to have a higher voltage at closed throttle. I have a 800 rpm idle at the moment from when I reset my TPS after taking off the PF TB.
I30tMikeD is offline
Old 11-01-2004, 05:34 PM
Cumalot's Avatar
That's what I was going to tackle next. Hopefully that will do it.
Cumalot is offline
Old 11-01-2004, 06:06 PM
I30tMikeD's Avatar
it will. You can adjust your idle to exactly where you want it.
Old 11-02-2004, 02:26 AM
MK3 Supra and Focus ST
PhxBlue's Avatar
My car idles nicely at 750. Before the reflash I had severe hesitation until 4000 rpm no matter what gear I was in. I dont know how they fixed that, maybe they toyed with the timing?? My only real prob now is the lack of power until 3500 rpm, the most gutless 4 bangers outthere could prolly smoke me off the line.
PhxBlue is offline
Old 11-02-2004, 05:45 AM
Cumalot's Avatar
Don't you just hate that? I got the same problem. It can get very annoying. Only way to solve this for me is a high stall TC.
Cumalot is offline
Old 11-02-2004, 08:45 AM
IceY2K1's Avatar
Time for VTC pulleys, however TS needs to figure out how to reflash the cam angle vs. load tables stored in the ECU.
http://www.z1auto.com/prodmore.asp?m...ine&prodid=922
IceY2K1 is offline
Old 11-02-2004, 10:12 AM
VG Ridah's Biatch Hoe
Bags's Avatar
small turbo + brake boosting
Bags is offline
Old 11-02-2004, 11:07 AM
IceY2K1's Avatar
N20...............
IceY2K1 is offline
Old 11-02-2004, 04:18 PM
IceY2K1's Avatar
Also, JWT has tuning capabilities on the VQ35s, so hopefully soon they will figure out how to optimize the CVTC to work with their cams <4000rpm or better the Nismo VTCs and their cams.
Hopefully, now that their VQ35 TT Z/G kit is hitting the market at SEMA, they'll start releasing new ECU reflashes for the Z/G and 2K2+ Maxima owners can get some benefit.
IceY2K1 is offline
Old 11-02-2004, 04:30 PM
TILLEYS99's Avatar
3.5 bottom end will change that believe me.
litch
123
01-04-2024 07:01 PM
mclasser
22
11-12-2020 01:58 PM
06-06-2017 02:01 PM
Mahmuth
10-17-2015 12:03 PM
Quick Reply: Heard JWT cams in a VQ35 last night...
