Sponsored by:
Sponsored by: CARiD
VI swap misc question
Old May 25, 2005 | 10:57 AM
  #81
Kevlo911's Avatar
Kevlo for President
Find a low mileage engine so when your engine goes, swap the other one in.
Old May 25, 2005 | 11:06 AM
  #82
NOZMaximus's Avatar
Dr. Kevlo911,
You think you could answer post #79 when you have a minute?
Old May 25, 2005 | 11:10 AM
  #83
Terran's Avatar
When my engine goes I'm going to visit tilley .
Well maybe. If I did swap in a 2k engine what would be involved? Is the only difference the VI which would already be solved or would there be more custom work?
Old May 25, 2005 | 11:42 AM
  #84
Kevlo911's Avatar
Kevlo for President
I guess there would be a lil more custom work, Tilley just got done swapping a 2k engine into a 4th gen, PM/Call/Email him.
Old May 25, 2005 | 11:46 AM
  #85
Terran's Avatar
Yeah I just found that thread in general. The only custom work mentioned had to do with the VI, but it wasn't a very detailed thread. I PM'd him so we'll see. Hopefully Vsamylov will pop in too because he did this minus the VI back before the 3.5 swap.
Old May 25, 2005 | 11:51 AM
  #86
vsamoylov
custom work on the 2k enigine onto a 4th gen? as i recall there was none. mototr and tranny bolted in just like a regualr vq30. the only thing that was involved was all the hoses and the wiring. you can pm or email maxs because he just did this swap into his 4th gen with a vi. so its a complete swap.
Old May 25, 2005 | 11:53 AM
  #87
Kevlo911's Avatar
Kevlo for President
Originally Posted by NOZMaximus
So if I have a whole 00 Engine with all manifolds, TB....etc to my avail, what would be the easiest route to accomplish the swap.
What adaptor plates would I need. What TB should I go with? And what IACV should I go with? Will the car's idle.... etc be the same as stock, or will it be slightly higher to keep it running smooth. Please no flaming, I've done plenty of reading, and am just a little un-clear about which would be the easiest setup.
5th gen upper and lower IM's w/ fuel rail/injectors and connectors
00EGR guide tube
00Rear Vavle cover
Apparently people sell the adapter blocks for the 4th gen IACV and stuff, so I would useh te 5th gen TB w/ the 4th gen IACV.
Old May 25, 2005 | 11:57 AM
  #88
vsamoylov
adapters can be bought from maxs. he sells the iacv adapter, the 4th gen tb to vi adapter and the 5th gen tb adapter if you are going to use the 5th gen tb.
Old May 25, 2005 | 12:05 PM
  #89
Terran's Avatar
I'll be doing the VI first anyway and just hold onto the engine for a hundred thousand miles or so. Were the hoses and wiring any different than if you swapped in a regular 4th gen engine? Were you just able to plug in the 4th gen harness into the 5th gen sensors or at least able to use the 4th gen sensors?
Lets put it this way...if you'd already taken car of the VI (inluding IACV and egr) would it simply be plug and play?
I'll PM your brother too, but input from everyone possible is the way I like it.
Old May 25, 2005 | 12:20 PM
  #90
Nismo3112's Avatar
Custom User Title
The hoses are dependant on which emissions equipment you have in your model year.. The blocks and heads itself are identical. But for the most part the 4th gen harness plugs into the 5th gen 3.0. (minus injectors)
Old May 25, 2005 | 12:52 PM
  #91
Terran's Avatar
How about with partial emissions equipment like us '95s have? I would assume it would just be a matter of not plugging in certain ssensors and blocking off some hose outlets? So the injectors are the ONLY thing that doesn't plug in?
Old May 25, 2005 | 01:03 PM
  #92
Kevlo911's Avatar
Kevlo for President
Injectors don;t plug in and I am pretty sure whatever else doesn;t plug in can be swapped.
Old May 26, 2005 | 07:03 AM
  #93
NOZMaximus's Avatar
00EGR guide tube
00Rear Vavle cover
Thanks Kevlo,
So just to clear things up, the only adapting I would have to do is an adaptor plate for the 4th GEN IACV, and the soldering for the injectors. Correct?
Old May 26, 2005 | 07:19 AM
  #94
Kevlo911's Avatar
Kevlo for President
And you need the adapter plate for hte 5th gen TB to cover up where the 5th gen IACV was--maxS sells that one.
Old May 26, 2005 | 08:23 AM
  #95
MaxesRule's Avatar
Keep in mind I am no expert on this subject.
From what I understand the grinding down the coil pack mounts is only necessary when using a 4th gen lower.
So the 4th gen lower is shorter than the 5th gen's or sumthin? Great then, so this doesn't pertain to me as I plan to use the 5th gen lower. Question answered.
I believe that using a 4th gen IACV would be a better option especially given the availability of adapter plates for remote mounting (from both maxS/vysamolov and Stephen Max).
Better than using the 5th gen IACV that's already attached to the tb? How so? Using the stock 5th gen one eliminates the need for excess hardware like adapter plates doesn't it? Why go through the extra hassel when u don't have to? What am I missing?
I don't think anyone has yet used a full 5th gen EGR system. Everyone has either not used it (probably the way to go as--correct me if I'm wrong--FL does't have emmissions testing) or use the 4th gen EGR with the 5th gen EGR guide tube.
That's what I meant to say. I want to use the 4th gen EGR equip. that's already there w/ the 5th gen guide tube and upper manifold. My apologies for the vagueness.
Old May 26, 2005 | 08:32 AM
  #96
MaxesRule's Avatar
Krismax - 96
98SEBlackMax - 96
Me - 97
We all used the 5th gen upper and lower also used the 00EGR guide tube.
So am I to assume that I won't run into any clearance issues w/ the coil pack mounts b/cuz I'm a 96, but if I were a 97-99 I would?
Old May 26, 2005 | 08:33 AM
  #97
MaxesRule's Avatar
Originally Posted by IceY2K1
Thanx again!
Old May 26, 2005 | 08:53 AM
  #98
MaxesRule's Avatar
My sentiments EXACTLY!!! (Minus the having a whole 00 engine part. I'll only buy what I need.) Only I'm one step closer cuz I think I almost got it. How's this?
Parts list for my setup:
1) 00 upper manifold w/ tb & EGR guide tube - bigger tb than 4th gen? and to connect to my 4th gen EGR plumbing and for the VI of course).
Still unsure why I should use the 4th gen IACV + adapter plate(s) instead of stock 5th gen IACV. Something to do w/ 5th gen wiring harness not matching 4th gen IACV plunger solenoid? Discussed w/ another .org member in separate posts.
2) 00 lower manifold - to possibly avoid any coil pack post grinding work and definitely to avoid port matching 4th gen lower to 5th gen upper.
3) 00 fuel rail & injectors & connectors- bigger/flow more fuel, better design (top spraying vs. 4th gen side spraying). Along w/ 5th gen upper manifold runner redesign, prolly 1 of the reasons y DE-K torque curve is soooo much smoother than DE's. More homogeneous fuel/air mixture into combustion chamber.
4) 00 manifold mounting bolts - should come w/ manifolds but just in case.
5) Summit rpm switch.
See, I'm really tryina understand this here, so if some1 could jus chime in and edit this where needed I'd be ready to go!
Old May 26, 2005 | 08:55 AM
  #99
MaxesRule's Avatar
About how much should I expect to pay at car-parts.com for all the parts listed in my previous post? Basically 5th gen everything from the heads up including the EGR guide tube?
Old May 26, 2005 | 09:04 AM
  #100
MaxesRule's Avatar
00EGR guide tube
00Rear Vavle cover
Arrrggh...is there no way to get around using an adapter plate w/ this swap? Why do u need 1 if ur using the 5th gen tb?
Old May 26, 2005 | 09:09 AM
  #101
MaxesRule's Avatar
Thanks Kevlo,
Y is an adapter plate necessary? Because ur using the 4th gen IACV w/ the 5th gen tb? Wouldn't the 5th gen IACV work?
Old May 26, 2005 | 09:22 AM
  #102
MaxesRule's Avatar
I would like this mod to be as close to stock functionality and as clean a retrofit as possible, no weird idle issues, no CELs, properly functioning EGR system, etc. Hence my reason for wanting to use all necessary DE-K parts. Thanx for your patience fellaz!
Old May 26, 2005 | 10:37 AM
  #103
NOZMaximus's Avatar
From my understanding, I don't think you could just straight bolt up a 5th GEN TB on a 4th GEN, you need an adaptor plate. And if you keep your 4th GEN TB, and try to bring over the 5th GEN IACV, there's fitment issues. Correct me if I'm wrong?
Old May 26, 2005 | 10:55 AM
  #104
Stephen Max's Avatar
There's no way to fit the 5th gen IACV to the 4th gen TB.
There are also fitment issues with using a 4th gen TB. The 00VI positions the TB closer to the firewall, directly over the egr valve, and the egr interferes with the coolant pipe at the bottom of the 4th gen TB (as well as the IACV on the bottom of the 5th gen TB). I ended up cutting the coolant pipe off a 4th gen TB for one customer in order to make it fit. No big deal.
Old May 26, 2005 | 11:22 AM
  #105
NOZMaximus's Avatar
So what is the simplest setup to go with? 5th GEN TB with adaptor plate and a 4th GEN IACV with adaptor plate?
Old May 26, 2005 | 12:15 PM
  #106
MaxesRule's Avatar
I think you guys are missing my point. My question is y not use the 5th gen IACV if ur using the 5th gen upper im & tb?
Old May 26, 2005 | 12:20 PM
  #107
Originally Posted by MaxesRule
I think you guys are missing my point. My question is y not use the 5th gen IACV if ur using the 5th gen upper?
I think you are missing the answer.
The answer is 2 posts up. Read it carefully (especially the part in parentheses).
Old May 26, 2005 | 12:30 PM
  #108
s0ber's Avatar
The EGR is in THE WAY..
Old May 26, 2005 | 12:36 PM
  #109
MaxesRule's Avatar
Are you saying that the 5th gen EGR interferes w/ the IACV on the bottom of the 5th gen tb? I'm trying but I keep losin ya.
Old May 26, 2005 | 12:37 PM
  #110
MaxesRule's Avatar
So the 4th gen EGR is in the way of the 5th gen IACV?
Old May 26, 2005 | 12:39 PM
  #111
s0ber's Avatar
Yep, I think you could use it if I eliminate the EGR completely... Not too sure on that, im just going to stick with the 5th gen TB/4th gen IACV
Old May 26, 2005 | 12:47 PM
  #112
MaxesRule's Avatar
Got it. And the 5th gen EGR doesn't interfere w/ the 5th gen iacv cuz the 5th gen upper has the IACV in a different location, or it has a diff. EGR system altogether right?
Old May 26, 2005 | 12:56 PM
  #113
It has a different egr.
Old May 26, 2005 | 12:59 PM
  #114
MaxesRule's Avatar
FINALLY!!! It makes sense now. Thanx Stephen! So then the whole point of these adapter plates is to rotate or otherwise move the 5th gen iacv out of the way of the 4th gen EGR right?
Old May 26, 2005 | 01:13 PM
  #115
Not exactly.
The A33 (5th gen) IACV interferes with the A32 (4th gen) egr. People that want to use the A33 throttle body have to remove the IACV from the bottom of the throttle body. A plate is needed to cover up the IACV ports in the A33 throttle body so that there are no air leaks. If you remove your A32 egr system, then you can retain the A33 IACV, but then you have to change the electrical connectors that plug into the IACV.
People who want to use an A32 or Pathfinder throttle body and want to use the A32 IACV need to mount the IACV on a plate and run an air supply hose from the back of the plate to the intake manifold, like what is shown here:
Old May 26, 2005 | 01:28 PM
  #116
SDot82's Avatar
I use the 5th gen IACV and still have my egr hooked up so u can use it just have to move stuff around a little.
Old May 26, 2005 | 01:33 PM
  #117
That's good to know.
And your ecu controls the IACV just fine?
Old May 26, 2005 | 01:40 PM
  #118
DandyMax's Avatar
3.5 in the works
That's what I was wondering... especially on cold start until it warms up...
Old May 26, 2005 | 01:58 PM
  #119
vsamoylov
ok the easiest thing to do is use a 5th gen tb and remote mount the 4th gen iacv becasue fitment is a problem with the 5th gen iacv. maxs sells adapter plates for the iacv so you can mount it seperatly and the adapter plate for the 5th gen tb that blocks off where the 5th gen iacv used to be at. maxs also sellts the adapter plate for the 4th gen tb if you want to use it still but the cheapest and easiest thign to do is use the 5th gen tb. if anybody needs adapter plates contact me.
Old May 26, 2005 | 02:25 PM
  #120
jmeister's Avatar
I plan on using the lower & upper, 5th gen TB and IACV. I will remove the EGR & block off w/ plate on the upper and still use the 5th gen IACV on the 5th gen TB with no adapter plates or relocation. From what I understand the only problem is the 5th IACV will cause a low idle when cold. Is that correct?
Regardless, I will be doing the install this weekend w/o adapter plates so I'll let you know how this method works out. Dyno on Tuesday w/ VAFC.
I'm sure I'll be posting up as I go... gotta remember pictures.
