Sponsored by:
Sponsored by: CARiD
VI swap misc question
Old Jun 1, 2005 | 06:56 AM
  #201
NOZMaximus's Avatar
Originally Posted by IceY2K1
I doubt that, but who knows with Nissan and their crossbreeds. Hell they switch stuff up in the same production year, so it could depend on production date.
FSM says swirl valves are Cali models only, but that doesn't mean it's 100% true.
I have a 2000 Canadian motor I'm taking parts from. All Canadian cars are FED spec, and mine has an EGR guide tube, and swirl/swivel valve.
Old Jun 1, 2005 | 06:58 AM
  #202
NOZMaximus's Avatar
Originally Posted by s0ber
You can remove the Swirl Valves in the Lower IM if you do get them, u just have to plug 2 holes so you wont have a leak.
What holes? Do you have a pic?
Old Jun 1, 2005 | 08:51 AM
  #203
Kevlo911's Avatar
Kevlo for President
I don't see anywhere in the 2000FSM where it talks about the EGR system, not even in the ECU pinout.
Old Jun 1, 2005 | 08:55 AM
  #204
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Just search the EC-section for EGR or swirl.
Old Jun 1, 2005 | 08:57 AM
  #205
IceY2K1's Avatar
You sure you don't mean all Canadian cars are Cali spec?
I know at least all 2001s are Cali spec.
Old Jun 1, 2005 | 08:59 AM
  #206
IceY2K1's Avatar
I thought you were the one who said FED specs didn't have the swirl valves or was that on your 4th gen?
Originally Posted by krismax
ive gotten two fed specs so far egr and swirl valves in both
Old Jun 1, 2005 | 09:06 AM
  #207
Kevlo911's Avatar
Kevlo for President
I have a FED spec lower w/o swirl vavles, krismax had FED spec 00 w/ swirl vavles. All 99's had swirl vavle, FED and CALI.
Old Jun 1, 2005 | 09:27 AM
  #208
IceY2K1's Avatar
Again, at least from the 2000/2001 FSMs I have only Cali-spec 2000s and all 2001s have swirl valves.
Old Jun 1, 2005 | 09:32 AM
  #209
NOZMaximus's Avatar
So is removing this valve the only solution? How hard is that?
Old Jun 1, 2005 | 12:42 PM
  #210
s0ber's Avatar
Remove the screws on the butterflys, theres 2 screws that goes into the rod that you must take off, and it _SHOULD_ slide out, (mine didnt, I cut it into peices and got it out....)
Then you have the fill the holes on the side of the manifold so you wont have a leak there.
Old Jun 1, 2005 | 04:28 PM
  #211
IceY2K1's Avatar
DAVEB has one of the last production date 2000 FED specs and he just verified he has no swirl valves in his LIM.
So, unless someone can 100% say they have a 2000 FED spec LIM with swirl valves, I'm still skeptical.
krismax...how did you know the two LIMs w/swirl valves you've had were from a FED spec vehicle?
Old Jun 1, 2005 | 06:46 PM
  #212
Kevlo911's Avatar
Kevlo for President
Interesting, 00-02 Have EGR vavles and 95-01 have same rear header so that means that it prob has the long EGR tube. It is just how the the guide tube is setup that is different I suppose.
Old Jun 2, 2005 | 07:20 AM
  #213
NOZMaximus's Avatar
Thanks, make a lot more sense now with the pics
Hopefully mine'll slide out
Old Jun 2, 2005 | 08:51 AM
  #214
nismology's Avatar
Only the 2000's have an EGR valve. 2001-2002 don't have EGR at all.
Old Jun 2, 2005 | 08:52 AM
  #215
IceY2K1's Avatar
2001s do not have EGR...actually 2001-2003 do not have EGR.
Old Jun 2, 2005 | 08:53 AM
  #216
IceY2K1's Avatar
Beat me to it.
Old Jun 2, 2005 | 08:58 AM
  #217
Kevlo911's Avatar
Kevlo for President
Under the nissan parts websites, they list EGR vavle for the 00-02. And teh same rear manifold for the 95-01. So I guess the rear header just has a bolt to cover up the egr?
Old Jun 2, 2005 | 08:59 AM
  #218
IceY2K1's Avatar
I've heard of an EGR bolt, but not sure if that's what was meant.
What "nissan parts website"?
Old Jun 2, 2005 | 09:06 AM
  #219
Kevlo911's Avatar
Kevlo for President
http://www.trademotion.com/partlocat...01&catalogid=1
1400431U00
147104L601
Search those 2 part numbers on this site:
http://www.nissandealer.com/jerry-ro...ts_catalog.cgi
It will list all apps.
Old Jun 2, 2005 | 09:08 AM
  #220
IceY2K1's Avatar
Okay...that's what I figured.
Just FYI, I find errors with those ALL the time. The Nissan FAST CD is the most reliable, but even it has revisions.
If you need to know 100% for sure, call DAVEB. He knows all.
Old Jun 2, 2005 | 09:12 AM
  #221
Kevlo911's Avatar
Kevlo for President
I still haven't figured out how to use hte FAST cd yet
Either way it doesn't bother me at all, I dont own either of those Maximas and I got the good manifold combo
Old Jun 3, 2005 | 08:08 AM
  #222
NOZMaximus's Avatar
The FAST software doesn't like my VIN# for whatever reason Anyone else experience this?
Old Jun 3, 2005 | 08:17 AM
  #223
s0ber's Avatar
Nope, whats your VIN# and i'll give it a try
Old Jun 3, 2005 | 08:42 AM
  #224
Kevlo911's Avatar
Kevlo for President
Do you guys use CD1 or CD2?
Old Jun 4, 2005 | 09:37 AM
  #225
s0ber's Avatar
I only used CD1
Old Jun 30, 2005 | 09:19 AM
  #226
Powerman5115's Avatar
What is this fuel fitting I've seen on a few peoples fuel rails who used the A33 LIM and fuel rail? Is the fuel rail, injectors, and harnesses not all you need for the fuel rail change?
Mooney
Old Jun 30, 2005 | 11:15 AM
  #227
Nismo3112's Avatar
Custom User Title
Mooney
http://www.sx7r.com/fuelfitting.htm
Old Jun 30, 2005 | 11:28 AM
  #228
Thanks. Stupid question, but what is the point of this, to connect the fuel rail to the fuel lines? Can someone explain this. Sorry for my stupidity.
Mooney
Old Jun 30, 2005 | 11:36 AM
  #229
Nismo3112's Avatar
Custom User Title
Mooney
yes..
10char
  #230
s0ber's Avatar
That's to remove the fuel damper, you dont NEED to remove it to get it started, im running with it on still.
Old Jun 30, 2005 | 11:37 AM
  #231
DandyMax's Avatar
3.5 in the works
The DE-K rail has a damper on that end which is not necessary with the 4th gen setup. That fitting replaces it.
EDIT: doh.. 3 replies at once...
Old Jun 30, 2005 | 11:48 AM
  #232
jmeister's Avatar
I'm running w/ the damper on still too.
Old Jul 6, 2005 | 01:29 PM
  #233
IceY2K1's Avatar
I have to correct myself....
I don't know WHERE I was feeling or why the 2001 FSM doesn't even have an EGR section, but Friday when I was changing my oil from underneath, I clearly saw that I do indeed have an EGR tube that connects behind the throttle-body below the manifold on my 2001.
VERRRRRY sorry for the misinformation.
I give up on figuring this whole EGR/swirl valve answer out.
Old Jul 26, 2005 | 07:15 AM
  #234
scrhale's Avatar
OK I am doing it provided I can find an upper and someone to install it in the ATL metro. The only question I have is will I be able to use my PR CAI on the 5th gen TB and still have it fit down the drilled hole? I have never seen a pic of it ... only of a short RAM/HAI.
My common sense says no because the inlet of the A33 TB is larger but I suppose it is all dependent on the rubber coupler.
To sum up my plan ... (A32 Lower, IACV, EGR) + (A33 Upper and TB) + Adaptor plate from A32 TB to A33 IACV.
Please help a brother noob out
Old Jul 26, 2005 | 08:22 AM
  #235
s0ber's Avatar
I got my PR CAI to fit on th e5th gen TB...
all I gotta say is it took a freakin while to make it fit, make sure u got good clamps because you really need to tighten it down so it doesnt come off... i'll take a pic for you later.
Old Jul 27, 2005 | 09:33 PM
  #236
eckohb's Avatar
i got my OSCAI to fit. I just like the stock resonator.
Old Jul 30, 2005 | 08:06 PM
  #237
sean05's Avatar
is there a write up for the 00vi install or am i on my own? haha i think i know the answer but its worth a try
Old Jul 30, 2005 | 08:21 PM
  #238
s0ber's Avatar
you're on your own,theres too many different setups to have a writeup :\
It's not that difficult to figure out once you get into it.
Old Jul 30, 2005 | 08:28 PM
  #239
sean05's Avatar
lol thats what i was afraid of. Have you installed one? In looking for a est. time my car will be down. Can it be down in a weekend?
Old Jul 30, 2005 | 08:45 PM
  #240
s0ber's Avatar
Yes sir, dont do it alone tho, if you have everything planned out you could get it done in one day, if not might take you a weekend...
Mine took a weekend because of grinding down the coil pack towers, and what actually took teh longest was figureing out how to put the PCV valve, wasted a few good hours with that...
Soldiering the new injector plugs takes a while too.
