Sponsored by:
Sponsored by: CARiD
350z IM on fwd maxima
Old Mar 15, 2006 | 02:51 PM
  #321
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Anyone have a side-by-side pic of the FWD VQ35 LIM and the 350Z LIM?
Old Mar 15, 2006 | 04:22 PM
  #322
eng92's Avatar
I may be able to accomodate you. Any view in particular? (inlet ports, side, end ???)
Old Mar 15, 2006 | 04:24 PM
  #323
IceY2K1's Avatar
Side, ie height difference.
Thanks.
Old Mar 15, 2006 | 06:24 PM
  #324
Nismo3112's Avatar
Custom User Title
Height, they are the same height. The ports do not match at all though.
Old Mar 15, 2006 | 06:28 PM
  #325
Nismo3112's Avatar
Custom User Title
As of today:
I took IceY2K1's advice, and shaved a hump off of the front of the manifold, and now I might not even need hood spacers!
Things left to do:
-Run VC breather hoses
-Make a throttle cable mount
-Extend TPS harness
Old Mar 15, 2006 | 06:34 PM
  #326
Puppetmaster's Avatar
Wow.... nice job. Have you driven it yet?
Old Mar 15, 2006 | 06:36 PM
  #327
vsamoylov
Originally Posted by Nismo3112
As of today:
oh my. thumbs up for the creativity though.
looks like you cut the neck from the oil filler tube? just the pic isnt very clear.
and what hump are you talking about exactly?
Old Mar 15, 2006 | 06:37 PM
  #328
vsamoylov
yes the lower on the 350z is different from the maxima. they are bigger.
Old Mar 15, 2006 | 06:49 PM
  #329
IceY2K1's Avatar
AWESOME....this is great news for the sleeper crowd.
I just hope there is enough clearance for the motor rocking, but a set of ES mounts should help take care of that.
  #330
Nismo3112's Avatar
Custom User Title
That is a Maxima valve cover. To use it I had to shave some off of the middle plenum, and shave some off of the oil cap.
This is the hump I shaved:
Hopefully tomorrow or Friday!
Old Mar 15, 2006 | 06:50 PM
  #331
IceY2K1's Avatar
"they are bigger"...what does that mean?
  #332
SR20DEN's Avatar
VQ Wizard
What is 'they' that you claim are bigger? It certainly isn't the port sizes, which take different shapes givving the appearance of size differences.
Old Mar 15, 2006 | 06:53 PM
  #333
Nismo3112's Avatar
Custom User Title
From my observations, the ports on the ZLIM are the same size as the "large" ports on the 2k2 IM. Every other port on the 2k2 IM is a bit smaller.
Old Mar 15, 2006 | 06:56 PM
  #334
vsamoylov
the motor will still move even with a set of es mount. it wont move as much but it will still move.
  #335
IceY2K1's Avatar
Interesting....
Nismo3112...when are you going to dyno? Also, were the ports equal and aligned perfectly with the heads?
Old Mar 15, 2006 | 06:57 PM
  #336
IceY2K1's Avatar
No ****......
Old Mar 15, 2006 | 06:59 PM
  #337
vsamoylov
correct the 350z are alll the smae but the maxima lower has different size ports. the easiest way to see that is what i did was take the gasket that goes between the lower and upper and put it on the 350z or take the same gasket from the 350z and put it on the maxima lower. you will see a difference in size.
Old Mar 15, 2006 | 07:00 PM
  #338
vsamoylov
No ****......
hey you made it seem like it wont move at all. you know there are newbies everywhere man. one of them might say i read that the motor wont move at al lwith es moutns or soemthing like that.
back on topic
Old Mar 15, 2006 | 07:02 PM
  #339
IceY2K1's Avatar
I guess.....
back on topic
  #340
vsamoylov
Interesting....
you could have asked me that.
the ports on the 350z lower im are a perfect match for the maxima heads.
Old Mar 15, 2006 | 07:03 PM
  #341
IceY2K1's Avatar
Thanks..........
Old Mar 15, 2006 | 07:05 PM
  #342
vsamoylov
now i guess its dyno time to see who produces how much power
nismo3112 what are your mods?
Old Mar 15, 2006 | 07:07 PM
  #343
Nismo3112's Avatar
Custom User Title
I should get some tuning device installed before I head to the dyno
Old Mar 15, 2006 | 07:08 PM
  #344
IceY2K1's Avatar
Yes, VTC vs. no VTC...I hope you switch to a G35S ECU to see what happens.
Do you have headers?
  #345
Nismo3112's Avatar
Custom User Title
VQ35
350Z plenums
HS Headers
K&N Intake
UDP
5th gen muffler
Old Mar 15, 2006 | 07:09 PM
  #346
IceY2K1's Avatar
I see Emanage Blues for DIRT cheap....
Old Mar 15, 2006 | 07:10 PM
  #347
Kevlo911's Avatar
Kevlo for President
Blue's are for pu$$ies
Old Mar 15, 2006 | 07:11 PM
  #348
vsamoylov
current mods for me are intake and exhaust and 17 degree timing and de-k injectors. no headers as of yet and i am also looking into a tunning device before i hit they dyno next month.
Old Mar 15, 2006 | 07:12 PM
  #349
vsamoylov
yeah i see you be on the 350z forums trying to pick up harnesses. i was thinking about emange though cause it is possible to make the 350z ecu work but stupid nissan changed soo much that an emange unit would be a better option
Old Mar 15, 2006 | 07:14 PM
  #350
IceY2K1's Avatar
"I don't know what you're talking about".....
Old Mar 15, 2006 | 07:17 PM
  #351
IceY2K1's Avatar
For $100 new...I be a pu$$y then. Luckily, I can get EU harnesses for less and just swap the EU back-n-forth.
Old Mar 15, 2006 | 07:35 PM
  #352
Kevlo911's Avatar
Kevlo for President
Melted coils FTL.... No timing advance FTL...
But for AF tuning that is a good price, I will give you that much
Old Mar 15, 2006 | 07:37 PM
  #353
SR20DEN's Avatar
VQ Wizard
They aren't necesarily smaller. The entry angles between the banks is different. What you're looking at are cross sections of the similarly shaped ports cut at different angles.
Old Mar 15, 2006 | 07:41 PM
  #354
Kevlo911's Avatar
Kevlo for President
Yeah if one bank was smaller, wouldnt it be leaner? Wouldn't that show up on the widebands or the ECU throwing a code?
Old Mar 15, 2006 | 07:45 PM
  #355
SR20DEN's Avatar
VQ Wizard
Only if the smaller ports didn't have compensating (higher) air velocities to deliver equal air masses to each cylinder. But that would cause a different set of problems altogether.
Old Mar 15, 2006 | 07:51 PM
  #356
IceY2K1's Avatar
Each bank is trimmed independently.
Old Mar 15, 2006 | 08:14 PM
  #357
eng92's Avatar
Probably a few hours late, but here are a few pics to illustrate what you guys have been talking about
350Z on the right. Yes they are the same height.
Top view. 350Z on the bottom. I will get out the bore gauges tomorrow to see what the actual flow areas are.
The next two pics are meant to show how much more of a straight thru shot that the flow path is in the 350Z LIM. I adjusted the camera angle to maximize the "visible" port area on the other side of the LIM
The first one is the FWD LIM
Notice how the 350Z path below is much straighter.
Old Mar 15, 2006 | 08:16 PM
  #358
eng92's Avatar
These last two pics are just closeups of the head ports.
Notice on the 350Z port below there is a small machined step on the inboard lip. It only goes about halfway around the port circumference.
It is on the wrong side of the port to prevent flow separation so there must be another reason. Any ideas?
Old Mar 15, 2006 | 08:20 PM
  #359
IceY2K1's Avatar
eng92 - Thanks...those really did help explain above posts.
Old Mar 15, 2006 | 09:08 PM
  #360
aznsap's Avatar
looking good, good looking guys. so what's it gonna take to get these suckers on a vq30?
