Sponsored by:
Sponsored by: CARiD
Installing wideband on an Auto...
Old Jul 11, 2006 | 07:59 AM
Kevlo911's Avatar
Kevlo for President
Who has done this? Where did you run the wires? Im told on manuals there is a rubber boot you can move and run wires through there. But I dont see anything like that on my auto. Any other holes in this area I don't know of?
Old Jul 11, 2006 | 08:11 AM
DandyMax's Avatar
3.5 in the works
Where are you putting the WB? There's a grommet for the rear O2 sensor you could use if you're putting the WB in a test pipe...
The rubber boot you're talking about on a manual is probably the one around the shifter.
Old Jul 11, 2006 | 08:19 AM
Kevlo911's Avatar
Kevlo for President
Yeah, Jime just told me he also used the rear o2 hole. I have the stock cat right now so I can't use it there. I was planning to add an o2 bung after the flex. I hope the wires will reach.
Old Jul 11, 2006 | 08:59 AM
Larrio Motors's Avatar
Boss Chen Industries
I ran it through the firewall near the glove compart area, it runs through and down into the car and sits behind the ECU area. Auto or 5spd... regardless. There is a cutout already and it slips right through after you work through the insulation material. You'll have to take the glove box out to take a look (although i'm not sure how long your wideband wire is or what type you have)
The o2 bung I have is welded into the y-pipe at the 2 o'clock position
Old Jul 11, 2006 | 09:20 AM
Kevlo911's Avatar
Kevlo for President
Sweet I will check that out too. I need to remove my glove box anyways so I can clean the Fan Blower.
Old Jul 11, 2006 | 11:56 AM
Let me clarify:
The opening is near the right side (fender side), behind the glove box compartment. My wb02 unit is installed behind the ECU area. I think you can see it from the engine bay... i'll try to take a picture if I can find it after work.
Old Jul 11, 2006 | 12:10 PM
jmeister's Avatar
I replaced my stock O2 located after the cat & the wires ran up underneath the drivers seat floorboard thru a rubber gromet.
Old Jul 11, 2006 | 12:53 PM
Kevlo911's Avatar
Kevlo for President
Fcking exhaust shop had no more bungs so I had to order one from fleabay...
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
