Wideband O2 Zeitronix Zt-2 install
Can anyone help me with the install of this WB? Are there any pics of the 4th gen ECU pin-out with which wires from the Zt-2 to hook them up to which pin? like to which pin would I hook up wire from the Zt-2 unit #2 - white wire - wideband analog output?
I quote "Tap the Signal Harness RED wire to the switched power (+12V) and BLACK wire to the ground." Does that mean that I only need those wires to run the WB? I only need the WB to tune the car with the A/F ratio. All I need is the power and sensor hooked up to a laptop? or is there more to hook up?
dude its a WIDEBAND you use the wideband O2 sensor it comes with. No tapping into stock sensors. Yes all you need is power for the unit and a bung welded into the exhaust for the new WB O2.
MaxLife17
06-27-2019 01:37 PM
