Double-checking on VAFC install
I just finished wiring up the VAFC II to my 4th gen. This is how I have done it.
Red Wire-- to the power source of the ECU
Red/Black-- to the power source of ECU (1cm away from red wire)
Green Wire-- To the Tachometer
Yellow wire-- connected to cut MAF wire(closest to the ECU)
White wire-- connected to MAF wire (to the other end of cut wire)
Purple wire-- Knock sensor
Grey wire-- Throttle position sensor
Pink wire-- to positive terminal of VIAS solenoid
Brown wire-- to ground of the ECU
Black wire-- to ground wire of the ECU (1cm away and behind of bronw wire)
What I am left with:
Orange wire-- ???? Apexi shows it is for: VTC
Blue wire-- ???? Apexi shows it is for: VTM signal
Light Blue-- ????? Apexi shows it is for: TDC
Which one am I supposed to use as ground for the VIAS? And are the other ones left disconnected???
http://forums.maxima.org/showpost.ph...68&postcount=2
When(RPM) do you plan on activating the 2k2 VIAS?
so i hooked up my VAFC2 as well, but i didn't cut my MAF wire yet, so those 2 wires i have not hooked up. how hard is it to tune? b/c right now my vafc is acting as a fancy rpm switch for my 00vi, and when i get time to mess w/ tuning i'll cut the MAF wire and hook it up to the vafc.
Sorry to say but the V-AFCII WILL NOT control the 2k2 VIAS properly. You need something that will stay ON until a certain RPM then turn OFF after that because the 2k2 VIAS is open by default and closes when vacuum is applied. That's the exact opposite of the V-AFCII's capabilities.
This should be in the sticky.
Well im not sure if theres a difference between the 2k2 VIAS and the 2K4 VIAS. I have the 2k4 engine/VIAS set-up.
Okay, so after going over the wiring diagram through Apexi, I did find the reason on why not to connect the purple to the knock sensor. So the knock sensor goes untouched?? And what about the other wires?? Do those stay disconnected??
This is my first time installing and messing with an air/fuel controller so I hope evreything goes well. I have been tight on money so getting a WB O2 sensor is out of the question.. at least for a couple of months. I plan on just taking it to a local shop and getting it tuned, then leaving it alone, and when I get the WB O2, I can start messing with it.
Are there any typical set-ups, or numbers anyone can recommend for me to try to tune the car (safely) for the time being. I need to go back in and make sure it is connected and functioning correctly before taking it to the shop.
Oh..
I was thinking about what you mentioned regarding the VAFC II not controlling the VIAS properly. I see reason in that because the V-tec kicks in as soon as it hits a specific rpm and continues to function until it drops back under that rpm range.... so this means in addition to the AFC, I would need to keep my rpm switch... Hmm.... okay.
I got the set-ups down... 1 in 1 out, 6 cylinder, up/right arrow v-tec 1<-- which this wouldnt mean anything anymore...
Now I have my points as follows:
Lvt: 2000,2200,2400,2600,2800,3000,3200,3400,3600,3800, 4000,4100
Hvt: 4200,4400,4600,4800,5000,5200,5400,5600,5800,6000, 6200,6400
Would this be okay?
Now i've been reading about how to set the Narrow throttle and high throttle... and it seesm to me the ideal place would be to set it at 40% on wide throttle but where would I poisition it for the narrow?? Or am I even doing it right?
I wish you guys were local so I can get some help.. There's no luck for me in this Honda infested city.
Would this be okay?
I still havent made any adjustments on the air/fuel side, but I did disconnect the vtec wire and connected my msd rpm switch... The car feels a whole lot better. I guess nismolgy, you were correct, unless I didnt have the VIAS hooked up properly to the Vt-ec controller. Before I did the change, the car was very torquie but lacked a whole lotta top end.
I know we both have differnet set-ups, but how do you have your correction points set?? I dont have a WB so I dont know how to put it... I just want to mess with it and see how it would feel. I'm taking it to a shop this weekend to get it tuned. Can you help a brotha out NmexMax?
Hey, did you get my pm regarding the shootout in Deming??
Well, right now, I'm pulling back ( -4 --> - 7%) @ 800-1400, since I have a slightly rich idle problem/lo throttle(12.8-13.0) issue with the larger MAF. I think this is actually caused by me not having my primary O2 sensors in. I also reset my base fuel schedule when installing the new MAF, so that too may have had an affect. It would work fine before (maintain 14.7:1 even w/o primaries in), but now with the larger MAF it went a touch rich. But I'm sure getting my primaries back in the mix will help out. I wont know for sure until I reconnect my primaries and then check AF.
Also, I have a full tune TS ECU, so my WOT readings are actually pretty good. Raw street tune looks to be - 3%--> - 5% from 4k+.
Smartest thing to do is to stay away from blind tuning. Wait for the weekend so they can do it at that shop.
I did get your message..... I'm going to try and make it
[QUOTE=NmexMAX]Well, right now, I'm pulling back ( -4 --> - 7%) @ 800-1400, since I have a slightly rich idle problem/lo throttle(12.8-13.0) issue with the larger MAF. I think this is actually caused by me not having my primary O2 sensors in. I also reset my base fuel schedule when installing the new MAF, so that too may have had an affect. It would work fine before (maintain 14.7:1 even w/o primaries in), but now with the larger MAF it went a touch rich. But I'm sure getting my primaries back in the mix will help out. I wont know for sure until I reconnect my primaries and then check AF.
Great, I see you help others now, good thing since you have a lot of knowledge. I also have that same kind of hurry to get results. On my last S-afc2 I had, I tunned it up to -12% at 5000 rpm with super good results (94 octane and a good eye on knock readings) It ran well. I switched it for a V-afc2 this weekend but not tunned it yet. I have problem with my rpm readings, it goes up when i lift the gas!!! 1 in 1 out arow at 2 oclock 6 cyl v-tec type 1... Could you help a bit?? I have no idea but the wires are all connected well.
I thought I was rich like every other stock 5.5g, but turns out TS made me AF curve pretty nice, so those down low corrections are great for my set-up.
i DO have a wb monitoring afr 24/7. that's the safe way to do it.
Might be a wiring problem. RPM signal is a frequency (hz) and is sent to the VAFC, the VAFC then deciphers it as RPM depending on how many cyls you chose when setting it up.
With that said, it may be a wiring problem/issue.
all wires has been soldered and recover with electric tape. Is it possible that the computer puts himself in a learning curve of the tach signal? Gonna check the wires anyway because there is nothing to do besides that.
one thing i forgot, there are two red wires from the v-afc2 and only 1 from the ecu. We connected the two vafc red wires 1 inch apart on the red power wire from the ecu, is it correct to do so? like the brown and black???
so far, no problem but rpm difference needle at 700-800rpm V-afc2 at 2200... did a lot of researches in the stickies but nothing that lighted me up... there is certainly someone that have a v-afc2 in a vq30de 4th gen around!!! Gonna go try do a run and gonna come back a bit latter.
Curious... Is you're VI activating with the vtec set to 1 on the VAFC?
Not sure what to tell you about the tach issue, I know there is some discrepancy usually but not that much.
I doubled the red power wires when installed. I phoned a dyno shop that are used to work with V-afc's and he told me I had a 'loop' in the reading circuit or something like that that's why it read doubles because the infos are circulated in loop... SOB!! still trying to figure out what it may be!! Today, the rpm's completely went to 0 on a stop light...WTF!! tach signal is soldered and taped with electric tape. The idle rpm's are doubled and as I rev past 1500rpm all is fine correct rpm's showing. I'm going crazy and gonna sell the thing to get me a EB for god's sake!! If not corrected in 2 weeks, FOR SALE!!!
Originally Posted by VQ'ed
Cardana24, please join the researches!! please
My RPM and throttle reading are also screwed up. I need to go read my manual. the only thing that I can think that I may have done wrong is hook up the two red wires to the ECU when it should have been only one...I am not sure but I am going to go read my manual. My RPM is showing to be around 1500 when the tach shows the car idling at 800. And my throttle does not start showing a reading until I have pushed the gasy pedal about 20% in, then the throttle reading starts at 1%. If I figure anything out I will report back.
I read through the manual and the the initial set up again and made sure everything was set right. My engine size was set to 4cyl so I changed it to 6cyl. After I double checked everything else I left the throttle closed for at least 10 seconds and then wide open for at least ten seconds (ignition on, but engine not running). After i did this I turned the ignition off...waited a few seconds and started the car back up. I went to the monitor function and now it appears to be reading correctly. RPM and throttle position appear to be correct now.
same over here, cut the second red wire and nothing changed. My tps% is now o.k thought... I checked all the solderings on the green(tps), grey and reds. all seems fine to me actually. gonna see the nissan guru over here in delson. so freaked out that i will need to pay for getting it fixed!!! but have you remarked after 1500rpm and part throttle, all the readings are dead on, in my case... so only idle speed is doubled(I don't mind if not displayed on the v-afc. Gonna simply show my corrections factor and tps now in 2 channels. I still have the rpm needle to look at. I put mine on the steering column behing the steering wheel. Super cool in the dark and no need to leave sight on the road.
ok so, I initialize the computer, get the car hot to get the ecu to learn the hot idle speed. 1 in 1 out 1 cyl 2 oclock arrow v-tec type 1. get the 1 channel thr% and wait 10 seconds at 0%. floor it for min. 10 seconds at 100% thr. Cut the ignition after... Gonna try to do the exact thing and gonna post tomorrow. I snowed a lot over here today. I had an appointment with the dyno guy but there's 5 inches of white **** on the ground.f..ck!!
I'm gonna print the manual on the apex-i site. I used to hooked the damn thing in 30 minutes. I made 6 and this is by far the most problematic install I had.
As of late, they do not have SAFC or VAFC manuals on there.
I had to DL and decipher a Japanese version of my SAFC, until I found the damn thing in a huge stack of papers at home.
just got it printed in technical documentation on the official site took 4 minutes... gone to page 13 like cardana24 told me gonna get it done by the book right now. gonna post tomorrow, my results.
MaxLife17
Jun 27, 2019 01:37 PM
