Sponsored by:
Sponsored by: CARiD
3rd gen VQ35DE Full ECU Swap Progress Thread
Old May 11, 2009 | 09:21 PM
  #681
streetzlegend's Avatar
Congrats!!!
Old May 11, 2009 | 10:33 PM
  #682
93altima's Avatar
Turbo 4th Gen
Congrats
Old May 12, 2009 | 04:39 AM
  #683
mmg23max's Avatar
Congrats again bro,now go have some fun breaking it in and then tune and get ready for MAXUS.
Old May 12, 2009 | 06:01 AM
  #684
eng92's Avatar
Congrats Aaron.
After all the hours spent wiring, it is certainly a wonderful feeling turning the key for the first time and having the motor fire right up.
The 4G speed sensor will work fine with the 5.5G cluster. One terminal of the sensor connects to pin 15 on the cluster and the other one should be grounded.
However, the vehicle speed output, from the cluster, is a much higher frequency on the 5.5G than on the 4G.
Old May 12, 2009 | 06:34 AM
  #685
Aaron92SE's Avatar
NWP Engineering.com
Originally Posted by eng92
Congrats Aaron.
Thanks everyone!
Dave, I haven't looked into it yet, but do you think the speed signal coming the cluster won't work for the TCM? That's what I did.
But step one is to get my speedometer working today and the alternator connected and charging the battery.
Old May 12, 2009 | 07:04 AM
  #686
eng92's Avatar
I do not have a 3G manual, but I thought the TCM derived the vehicle speed from the revolution sensor.
It will not "like" any signal it gets from the cluster due to the increased frequency.
I drove around for a few months with a 5.5G cluster installed with a 4G ecu before I started my swap. I had my Auterra hooked up one day and I found that it indicated a speed that was roughly four times what my cluster was showing.
In my case, the only drivability problem it created was a "soft" speed limiter at about 70 mph. If I approached 70 in fifth and slowly tried to accelerate, it would not go any faster. If I backed off to about 65, dropped it into 4th and hammered it, it would sail past 70 and keep accelerating with no problems.
Once I swapped in the 5.5G engine and ecu, that issue disappeared. I attributed it to the difference in the cluster speed signal frequencies.
Old May 12, 2009 | 07:07 AM
  #687
DandyMax's Avatar
3.5 in the works
Good job Aaron... almost there!
Old May 12, 2009 | 07:15 AM
  #688
Aaron92SE's Avatar
NWP Engineering.com
Oh ok thanks. Did you have any issues with the throttle position only being 85% on the Auterra software?
That's what my DynoScan software is showing and my throttle plate physically appears to be open slightly less than 100%. Did you look at your throttle plate position with your eyes?
Old May 12, 2009 | 07:34 AM
  #689
eng92's Avatar
I do not recall ever monitoring TPS with my Auterra. The sampling was so so slow, I always monitored the minimum number of parameters when doing any testing.
I actually hooked up the ecu and my pruned harness to the engine before I even touched the vehicle to make sure everything would work. The throttle plate would open as close to parallel as I could tell by eye when I pressed the pedal to the limit of its travel.
Old May 12, 2009 | 07:46 AM
  #690
Aaron92SE's Avatar
NWP Engineering.com
Ok thanks. The TP is slow to respond. VERY slow. But I just press the pedal to WOT and it goes to 85% everytime. Jim said many people have been fooled by this inaccurate information the ECM has. But I am curious what other people have seen the throttle plate open to when they look at it with their eyes. My VE (cable driven) opens to perfectly parallel when at WOT. The 3.5 TB is just shy.
As for the revolution sensor, the stock VE TCM receives a signal from both the VSS and the Rev sensor. Right now, the rev sensor is connected probably just like it would be stock. The VE Cluster gets the VSS signal first, then sends it to the TCM. That is how I wired it up on my 3rd gen. I let it pass through the 5.5G cluster first. I may have to split the wires and send the VSS signal to the cluster and TCM.
Old May 12, 2009 | 07:53 AM
  #691
Deckdout2's Avatar
Play with my balls
Sick Aaron! Nice work man. And it sounds very stout with the components you have. Get's me excited to see the results of my own build. btw, Maxus is probably going to be out of the question for me this year. Aside from the build not being completed in time, I have so other obligations outside the car realm that I need to tend to.
I'll have to roll over with Darren however at some point to check that beast out.
In for more vids.
Old May 12, 2009 | 08:03 AM
  #692
Aaron92SE's Avatar
NWP Engineering.com
I just uploaded the 1.9 GB High Def 19 minute video. I'm sorry, but I do not have any way to reduce the quality or shorten the video length right now.
This is the video of the real initial startup. Then is the VERY first time I ever turned the engine over!
A very fast internet connection will be needed. If you have a 1.5meg connection, it will probably take you 4-6 hours to download. If you are able to download at 500kb/s, it will only take an hour.
Right click, Save as...
http://www.nwpengineering.com/forum/...20Original.MOV
Edit: I'm sorry guys. I had to take the video down since I was reaching my bandwidth limit. The full video will be available in reduced quality on Youtube sometime tomorrow.
Old May 12, 2009 | 08:06 AM
  #693
Kevlo911's Avatar
Kevlo for President
I think the auto and manual clusters have different wireing so I am not sure if the 2k2 auto will have the same speedo wiring as eng's
Old May 12, 2009 | 08:12 AM
  #694
Aaron92SE's Avatar
NWP Engineering.com
I don't know what terminals he used on the cluster. I used the FSM to determine all mine. I just used Dave's awesome spreadsheet to double check my work.
Old May 12, 2009 | 08:27 AM
  #695
Kevlo911's Avatar
Kevlo for President
Gotcha. Looking at EL-124(2k2), when the speedo doesn't work it is the ABS.
Check page EL-125 on how to test. Jack it up the car and drive it at 12mph and then measure the voltage at pin 15. it should be from 0-5v
Old May 12, 2009 | 08:35 AM
  #696
Aaron92SE's Avatar
NWP Engineering.com
Thanks. I'll have to put the car on jacks again. Thanks for the page numbers. Will save me some time.
I really appreciate all the support and help from everybody.
Old May 12, 2009 | 09:39 AM
  #697
eng92's Avatar
That does not apply here because there is no ABS module with a speed sensor output.
The speed sensor is wired the same as on an 01 with TCS (EL-116)
The test is still valid though.
Old May 12, 2009 | 09:45 AM
  #698
Aaron92SE's Avatar
NWP Engineering.com
I just got the speedo working and now it shifts into 2nd gear. I just gotta hook up my alternator so I can confidently leave my driveway without the battery dying on me. My battery is weak and very old.
I grounded my 4th gen VSS to the body. The resistance between that ground point I chose and the battery was around 40 ohms (very high). So I just changed that ground point to the intake manifold and it's much better.
But I also found out that b/c I switched cluster face panels, my speedometer sticks between 0mph and 15mph. So, I don't know if I was going fast enough yesterday for the speedo to register or my VSS ground wasn't sufficient. But, I got the tranny to shift into 2nd gear when the front tires were off the ground. It wouldn't shift until around 20-25mph though, even at VERY light throttle. Like Capecadaver mentioned, I don't have a TPS signal going to my TCM and in order to get proper part throttle shifting, it appears I will need this signal.
Thanks Jared for pointing out that the APP signal is similar to the VE TPS signal. I may just use it. I didn't want to research anything last night since I deemed the entire day a success (engine fired up) and I didn't want to do any more research. It was the first evening that I actually relaxed and watched TV in the past 3 months! That's how busy I've been with this 3.5 project lately.
Oh yeah, and last night, I ran up to the gas station and got some fresh 93 octane and dumped it in my tank. Yesterday, when I drove the car, the throttle response was REALLY bad and inconsistent when I gave it a little gas. The gas that was in the tank was from late Sept 08. But when I just now drove my car down the driveway with the fresh gas, it felt a whole lot better. I'll post later after I get a chance to drive the car over 30 mph on the road and see how it shifts without a TPS signal.
Old May 12, 2009 | 10:09 AM
  #699
Gunther's Avatar
Just watched the first startup vid, good stuff, it really did just start up, probably easier than my car now. I could convert to mpeg4 [smaller] if you'd like, it'd just take a while. It's a lot of friggin data.
Old May 12, 2009 | 10:32 AM
  #700
CapedCadaver's Avatar
Call me Wookiee Goldberg
how was the shifting when you were driving it to the gas station and back? how many gears did it use? glad to see you got 1 of the 2 issues tackled tho.
Old May 12, 2009 | 11:14 AM
  #701
Gunther's Avatar
Aaron, you have a PM
Old May 12, 2009 | 09:06 PM
  #702
hadman's Avatar
Congrats buddy. I watched all 20 minutes - it was nice to spend quality time with you finally lol.
... and I thought my exhaust cutout was obnoxious. Will be nice to hear when you have the beast sewn up, and see it hustling down the road... in the next video (hint).
Old May 12, 2009 | 09:11 PM
  #703
Aaron92SE's Avatar
NWP Engineering.com
Thank you. I appreciate all your help compressing the full video. I will have it on Youtube shortly.
The shift from 1-2 and 2-3 seems ok. Since it doesn't have any TPS signal, it seems to be locked into one throttle position setting. The 1-2 shift always happens at a specific rpm, higher than normal. Maybe around 25 mph, no matter how light the throttle is. I haven't revved the engine past 3K rpm though.
I didn't drive it to the gas station. I brought 5 gallons to the Maxima. but I did drive it up the road a little bit today. I now have 1.4 miles on the trip odometer. I didn't go fast enough to shift into OD, but at least I got it to shift into 2nd and 3rd.
Old May 12, 2009 | 09:15 PM
  #704
Aaron92SE's Avatar
NWP Engineering.com
Thanks a lot.
Obnoxious? I am thinking about keeping the open headers all the time. lol It sounds really good in person. But I will start trying to find a capable exhaust shop tomorrow. I will have to do some major cutting of the RH control arm to make room for the Ypipe. I don't care. The engine is running! It's just now starting to sink in after I actually drove it on the street this afternoon. More fun will come tomorrow!
Old May 12, 2009 | 09:22 PM
  #705
AEMAXIMA01's Avatar
I've been following this thread for a little while. This is a really cool build! I admire the effort you've put into this. I can't wait to see it all put together. What happened to the vid on your website? I tried downloading it but it says not found on the server.
Old May 12, 2009 | 09:41 PM
  #706
Aaron92SE's Avatar
NWP Engineering.com
Thank you.
I took down the 2gb video cause I was reaching the bandwidth limit on the NWP Engineering website. I can't afford that website to go down.
I should have the same full video in reduced quality on YouTube sometime tomorrow.
Old May 12, 2009 | 10:00 PM
  #707
Aaron92SE's Avatar
NWP Engineering.com
Here is a quick test drive I took today to make sure the tranny changes gears:
http://www.youtube.com/watch?v=UdJxVh3J0Gg
Old May 12, 2009 | 10:16 PM
  #708
pmohr's Avatar
No more Maximas...
Taken her WOT yet?
Old May 12, 2009 | 11:03 PM
  #709
NiZMo1o1's Avatar
good shat ! congrats Aaron !
Old May 13, 2009 | 01:18 AM
  #710
what was the sort of spikey sound just before gear changes? were you pushing the pedal harder or something? does using the gear selector still override the upshift properly tho? i saw you using non-D positions... i think.
Old May 13, 2009 | 06:14 AM
  #711
hadman's Avatar
Thanks a lot.
It does sound good at idle. It's actually quite similar sounding to when I have the cutout open, but at high speed it becomes a bit much. Just watched your other video. Good to see you crack a smile. Hey, so what was that sudden spiking sound? It almost sounded like a slipping tranny, but judging by your reaction in the video that doesn't appear to be the case.
Old May 13, 2009 | 06:21 AM
  #712
Aaron92SE's Avatar
NWP Engineering.com
Originally Posted by pmohr
Taken her WOT yet?
Haha no. I want to though. I will keep it under 4K rpm for the next 75 miles or so for camshaft break in. And I won't go WOT until I can monitor AFR and have a Ypipe.
That was me blipping the throttle. Instant throttle response!
It shifts by itself in D. Manually shifting does not force it to shift sooner than it normally would. All that will do is hold the shift from happening until you are above the normal shift point.
The tranny feels great. No slipping. I just blipped the throttle just a hair to feel the raw power and to see how fast the engine responds. I have to say, the throttle response is MUCH faster than my VE. It's definitely a pretty mean engine build.
Old May 13, 2009 | 06:39 AM
  #713
grey99max's Avatar
LandShark has Cosworth
You gotta love the 3.5 - it's a torque beast compared to any previous Maxima motor. Is the queasy feeling in the pit of your stomach gone yet? There's nothing like the feeling of relief when things start to work right.
You've done a remarkable job. Kudos to you, and Spray It as soon as possible!
Old May 13, 2009 | 06:53 AM
  #714
Aaron92SE's Avatar
NWP Engineering.com
Thanks. Yesterday when I drove it on the street for the first time, I actually started to smile a little bit. I haven't gotten on the gas or anything. I have no idea what this engine will do at WOT above 4K rpm. I will drive it easy for now though.
I need to wire up the illumination lighting on the cluster so it comes on when the headlights are on. And I will wire in my high beams light on the cluster as well. All the gear selection indicator lights are wired up too and working.
And just yesterday, I finished wiring the alternator. For some reason, I couldn't get it to charge the battery. I decided to connect the wire for the battery light on the cluster and viola, it started charging!
Old May 13, 2009 | 07:25 AM
  #715
grey99max's Avatar
It's amazing how a build project like this one will nag at you all the time - you wake up at night wondering if you actually tightened all the head bolts, and other random stuff...
Your wiring adventures reminded me again why I'll never convert to a later ECU - too many details, too little time. While we're sharing secrets, I found out why my last transmission only lasted 1 1/2 runs at the strip. When changing plugs sometime earlier this spring, I took off the vacuum hose from the MAP solenoid and I accidentally replaced it with a surplus solenoid's (ECU wants it - engine doesn't care) vacuum hose. The MAP sensor pretty much rules the ECU, so I was getting random error codes that didn't make any sense, like Solenoid A and 1105's and the car would occasionally go into SAFE mode and then die on the street. At the track, near as I can remember, on the second pass I made with the full 175-shot engaged, when the car shifted into 2nd gear, it started rev-limiting at 3000 and I rolled through the traps in the 80's. After I left the track and got to the return road, the engine died and I coasted to the timing booth and parked there. The car wouldn't restart - the battery was practically dead, so it was Trailer TIme.
Later at home I figured it out, but the damage was done - the tranny oil smells like burnt pancakes and has no reverse gear. I'll have to replace it - but now all the weird codes are gone. Shizzz happens. Stupid also happens...
Old May 13, 2009 | 08:11 AM
  #716
Aaron92SE's Avatar
NWP Engineering.com
Yeah, I always smell my fluids. That sucks man. But so does my VE blowing up. I guess it helps motivate you to bigger and better things. Either that, or you just go out and buy a G35 or BMW.
Old May 13, 2009 | 08:37 AM
  #717
grey99max's Avatar
"What doesn't kill you will make you stronger"... or something like that.
New transmission, new engine, probably more "stupid" to come, but hey, it's the journey that counts for me. If I just want a consistent 10-sec street car, I can buy one. - but what fun is that?
Old May 13, 2009 | 09:00 AM
  #718
Aaron92SE's Avatar
NWP Engineering.com
Yeah, what's the fun in going out and buying a Viper. People EXPECT that to be fast. There's NOTHING like seeing the looks on people's faces when you whoop up on a Corvette or Cobra Stang. My 3rd gen looks pretty close to stock from the outside. Just clear corners, 17" wheels, tinted windows. And I always run stock mufflers on the street to keep it as quiet as possible. If I want to go fast and be loud, I just open my cutout with a flip of a switch. There's nothing like having the sleeper status of stock mufflers.
Old May 13, 2009 | 11:05 AM
  #719
GRNMAXDMON's Avatar
yeah, i can relate to that Aaron.
Old May 13, 2009 | 03:25 PM
  #720
hadman's Avatar
I enjoy the opposite. Usually when some Civic or Corolla is riding my bumper in traffic when you clearly can't go any faster, and you try and create that gap to keep traffic moving, and they almost hit your bumper like 10 times because you aren't moving fast enough for them. When that bottle neck opens up... WOT - buh-bye.
