Someone please help me out. Im so confused ? ? ?
I have a Pioneer Deh-p7200 headunit
Pioneer TS-A6960R 6x9
NEW PIONEER TS-C504 5 1/4" COMPONENT SET
Pioneer GM-X972 800W 2 Ch Amp.
My question is can I run the 6x9 and components on the amp I mean its 800 watts but Its only 2 channel would that keep this from working?
Please help me. Any and all help is appreciated. Thanks
Re: Someone please help me out. Im so confused ? ? ?
very simple, 2 channel is for 2 speakers, 4 channels is for 4 speakers....so definately the 2 ch. won't work. I suggest u just push the front speakers, cuz usually 6x9s r kicking hard.
Re: Re: Someone please help me out. Im so confused ? ? ?
Brett
Ok so this is what I decided. I am going to buy a 600 watt sub. Now this is my new question the amp is 800 watts so if it pushes the sub at full capacity there will still be 200 watts left over and my components max is 160 watts is there a such thing as sending too much power to the compnents if I send the remaining 200 watts to them? Would this hurt them or distort my sound?
http://www.crutchfield.com/S-cUcTSzN...sp?I=130GMX972
Originally posted by erty67
I'm going to try and help you here....According to Crutchfield, your amp is rated for 150x2 or 400x1 rms at 4ohms. If you are buying ONE 600W sub, use your amp to power that one sub only. Then, get a second amp(4 channel) to power the 6x9s and your components. If you's prefer a 2-channel amp, use it to power the components and let the head unit power the 6x9s. The rear speakers are supposed to be used as fill. You mainly want the sound in front of you, so the 6x9s don't need a lot of power. You should not power the subs and components off the same 2-channel amp. The sub will only want low freqs and the components will want full freqs. Hope this helps.
Thank You. I really appreciate you helping me out. I went ahead and bought a 300watt amp today that Im going to just run the components off of. I will keep the original amp for just the sub and let the headunit push the 6x9's. One last question though my components say 160watt max does this mean that the 300 watt amp will be too much or is that ok. Thank you in advance for your help.
Originally posted by D Love
The 300W amp will not be too much for your components. You can buy as big of an amp as you want...you just have to make sure that you don't try and use all of the power if your speakers aren't meant to handle it. (i.e. turn up the volume too much)
I know Im going to love my system once its done. Thank you guys for all of your help and thanks to Don for respondidng to my email. I really appreciate it.
TallTom
50
07-08-2022 09:54 AM
