amp recommendations
Old Jun 16, 2003 | 06:24 PM
henock
amp recommendations
Hey ppl..
im planning on installing 2 12" w7 subs in my trunk.. i had a few qustions about amps..
how many watts can these subs take without blowing in the future? (750 is rec. by jl audio)
i dont know much about amps.. and i needed a few recommendations on which amps can be used with my subs and what the best setup is for them..
if it at all matters:
Alpine CDA-7893
(4) Infinity Kappy 62.5i speakers (75w)
Old Jun 16, 2003 | 07:16 PM
jmax
Power handling will dependant on the enclosure. But they should be able to handle 750 in just about any enclosure. Unless they have lowered the quality of the coil or some of the suspension parts. Do those have dual 3 ohm coils, or do you have a choice of configurations?
Old Jun 16, 2003 | 11:23 PM
BlkMaXinMD's Avatar
ummm if you get 2 12in w7's you should get 2 jl 1000.1 amps to power those suckers those subs work best with 1000watts rms runnin through them so if you want the most out of those get 2 of those 1000.1 amps
Old Jun 17, 2003 | 02:46 AM
henock
not sure what all that means.. thats why i came here first.. but here's the site right here:
http://www.jlaudio.com/subwoofers/w7.html
blkmaxinMD, those 1000.1 amps are pretty long.. i have space considerations and one more amp for my components to worry about too. you sure 1000 watts wouldnt compromise reliability?
Old Jun 17, 2003 | 06:44 AM
jmax
Okay, I repeat, power handling is dependant on the enclosure. Smaller can handle more power at the expense of efficiency and low bass extension. http://www.jlaudio.com/subwoofers/RP_Chart.html
It appears the 12W7 is only available with single 3 ohm coil. You can go the expensive route mentioned above or get a single mono amp with high power at 1 ohm. I really would not worry about 1000 watts blowing these subs properly installed.
Old Jun 17, 2003 | 08:55 AM
crazyravr's Avatar
Re: amp recommendations
Originally posted by henock
Hey ppl..
Alpine CDA-7893
You have all this $ to spend on those subs and amps to power them and yet you are running coax speakers ?
Dude... before getting those subs you better upgrade those spkeakers to something that wont get overpowered. If you want to stick with JL the get their set of comps and 300/2 to power them with.
As for the power... they will be very happy with 1000Wrms into each.
Old Jun 17, 2003 | 12:23 PM
henock
something like this ?
http://www.ikesound.com/Prod_Details.asp?Prod_Id=832
Old Jun 17, 2003 | 01:49 PM
jmax
$1000 subs deserve equivalent amplification. Eclipse has a couple new amps. JBL has a couple new amps. And there are a lot of amps that have been out for several months or even a couple years that would work good.
Old Jun 17, 2003 | 02:53 PM
maximamaybe's Avatar
There have been many people that have run the JL 12W7s off a JBL BP1200.1. That is ~600 watts per sub. It will hit hard. Another option is to get a 13w7 and run it off the same amp. Less space and you will still hit harder than people with more subs. The key on the W7s is the box and the design. Build it exactly to spec and watch it slam!
chisam14
Nov 6, 2018 08:56 PM
MaxLvr21
Oct 17, 2015 12:11 PM
sliptap
Sep 30, 2015 05:57 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Redfox
Sep 28, 2015 10:41 AM
