XM installation
Old Sep 15, 2003 | 10:59 AM
speedemn's Avatar
XM installation
Hi guys... I need some advice here.
I am planning on getting the Audiovox or Kenwood XM package from Sirius... most probably the Audiovox since it comes with a built-in FM transmitter.
I need some advice on how to install all of this. Do I need to gat a shop to do this or is it simple enough for me to do the entire setup? I have a stock BOSE system from a 1995 SE.
Where should I mount the antenna? I was debating between the top of the rear windshield or on the trunk itself, starting at the bottom of the windshield. Where would I run the wire from the antenna to the receiver? Do I have to rip apart paneling, etc?
Is there anything else here that I need to know or do?
Hope I can get some advice here. Thanks!
Old Sep 15, 2003 | 05:09 PM
Nismo's Avatar
I can help if you had the xm ready HU but not shure about the one your getting
I have my terk antenna inside the car right next to the 3rd brake light on the rear deck and never had any interference problems other than if Im next to a big building or if I drive under bridges, ect.
I used to have it on my trunk lid but it looked ugly so I moved it inside. I have 35% tint also
Old Sep 15, 2003 | 07:07 PM
speedemn's Avatar
I already talked to Matt, and he said that it will work fine with the stock BOSE system... so mechanically I am not worried... I am just not too sure about the actual physical installation of it all. I have 15% tints all around... but i like your idea of installing it on the rear deck on the inside. I wonder if I would have problems with that.
Now the part that I am most concerned with... how did you run the wire from the antenna in the back deck to your receiver which is installed.... ? (somewhere in the front I assume)
How did you do yours?
Old Sep 15, 2003 | 11:56 PM
Nismo's Avatar
my xm reciever is in the trunk so that was easy.
If your putting yours in the front then all you have to do is route the antenna wire(its pretty long)along under the rear seat, and under the carpet as if you were running amp power cable. just make sure you dont pinch or bend the wire in sharp angles or you will brake the insides of the antenna. best way to do it is to remove the door sills and pull up the carpet and stuff it under there.
Old Sep 16, 2003 | 04:16 AM
speedemn's Avatar
Maybe I'm missing something here... but isn't the receiver the little device with the screen that controls the stations and programming and such? Should that not be in the front where you can operate it?
Old Sep 16, 2003 | 12:17 PM
Nismo's Avatar
sorry for the confusion, I ment to say tuner, not reciever. my Pioneer headunit is XM ready, that means I can control the XM through the HU so no need for an extra screen remote. Instead I have just the tuner box thats in the trunk.
Old Sep 16, 2003 | 01:45 PM
speedemn's Avatar
Ah I see... so is there a wire that runs from the tuner box to your head unit?
No matter what, you are still going to have to run wiring all through the car, right? I'm just trying to find out the easiest way... if I get the AUdiovox kit from Sirius.
Old Sep 16, 2003 | 05:44 PM
Nismo's Avatar
yes, I had to run the wire from the HU to the box. that wire has the signal from the HU and also the power.
Old Sep 16, 2003 | 06:26 PM
jrklar's Avatar
i just did this over the weekend, very easy. i had a sirius ready head unit. just one wire from tuner in trunk to back of head unit. another from antenna to tuner. antenna is currently inside on back deck. so far, not to bad reception. i have 35% tint all around. i might be moving it outside, we'll see.
Old Sep 17, 2003 | 08:18 AM
speedemn's Avatar
So did you guys also run the wire from the trunk to the front, under the rear seat and under the carpet? What all do I have to rip out in order to do this?
Thanks.
Old Sep 17, 2003 | 08:32 AM
jrklar's Avatar
not sure the set up in a '95, but here's how i did mine:
1. tuner goes in trunk
2. single wire goes from tuner to back of head unit. wire is pulled through behind back seats, then run under the plastic molding where the door closes. the plastic pops right up and runs all the way to the front of the car. then you have to remove your head unit and just run the wire in from the back and pop the head unit back on.
3. antenna is on back deck, single wire running from antenna, behind back seats, to tuner in the trunk.
Doesn't get any easier than that. If you decide to put antenna on roof, i think you can just run the wire under the weatherstrip along the window to the base and then run it into your trunk. Haven't gotten that far though.
Old Sep 18, 2003 | 01:24 AM
Nismo's Avatar
I first had the antenna on the trun lid, got bored and moved it on the roof, looked like shyt and moved it into the car on the deck. deck is were it stays
Old Sep 18, 2003 | 06:02 AM
speedemn's Avatar
If I am installing this on a stock BOSE system in a 95, I don't think I need to plug anything into the actual BOSE unit, do I?
Wait... then how do I get it to play on my speakers?? Umm I'm missing something here... I hope the Sirius unit comes with some sort of install instructions (the electrical part now).
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
