Show Us Whats In Your Trunk...
Old Apr 13, 2009 | 10:23 PM
  #2161
Rion's Avatar
oka im new to this site so i cant show whats in my trunk ,can anyone tell me how i can start a thread and download pics so i can show my trunk
Old Apr 14, 2009 | 05:13 AM
  #2162
mendon99's Avatar
tastey wheat
Originally Posted by Rion
oka im new to this site so i can show whats in my trunk ,can anyone tell me how i can start a thread and download pics so i can show my trunk
You're in a thread to do just that, don't bother start a new one.
Just go to photbucket.com or flickr and follow the directions to upload them there. Then take the image code and copy it here.. [IMG]picturelink.jpg[/IMG]
Old Apr 14, 2009 | 10:45 AM
  #2163
Rion's Avatar
k
Old Apr 17, 2009 | 05:15 PM
  #2164
Orgullo's Avatar
$$ Ballin on a Budget $$
Update: Just got it painted. Now I've got to finish out the tv pods, mount the tv's and install the 8's.
Just finished this as well. Putting this into my boys dually. There are side walls too not pictured. There's another one just like it. They will go back to back.
I'm sure some of you won't like it but... I'm sharing it anyway.
Old Apr 18, 2009 | 11:13 PM
  #2165
AscendantMax's Avatar
looks nice. i would brace the hell out of it though.
Old Apr 22, 2009 | 08:49 AM
  #2166
angelmaxima's Avatar
Good luck with that orgullo, gonna look Sickk
Old May 15, 2009 | 10:51 PM
  #2167
maxprivate's Avatar
Black Lion
Originally Posted by eng92
The goal was sound quality and maximizing usable trunk space.
Tru Billet Six, SSLD6, Dyn Esotec 362s and Alumapro 12" IB sub.
Sweet.. Nice to see the end result of your install. Came out nice and neat and plenty of trunk space.
Old May 16, 2009 | 06:15 AM
  #2168
eng92's Avatar
That was from 7 months ago. Things have changed a little since then.
It is now a 4-way active setup with an added amp, different head unit and sound processor.
Old May 16, 2009 | 10:17 AM
  #2169
maxprivate's Avatar
Black Lion
Holy!! I love your setup and cant wait to get mine done. You do have a 4th Gen right? I thought we couldn't mount amps upside down to possible overheating.
Old May 16, 2009 | 10:18 AM
  #2170
maxprivate's Avatar
Black Lion
Where did you move your crossover to?
Old May 16, 2009 | 10:52 AM
  #2171
eng92's Avatar
It is an "active" setup.
The passive crossovers are removed.
Each driver gets its own amplifier channel(s). A signal processor feeds each amp channel with the correct bandwidth of frequencies.
Old May 16, 2009 | 10:55 AM
  #2172
Pearl96Max's Avatar
I tend to get a bit irritable
oops, meant to click quote. Meh, same result though.
Old May 16, 2009 | 11:01 AM
  #2173
maxprivate's Avatar
Black Lion
OH I see so basically you no longer have any use for the crossovers. I have a lot to learn about Audio. Im taking baby steps though need to get my Sub adding in and I'll go from there.
Old May 18, 2009 | 07:18 AM
  #2174
choray911's Avatar
The Crazy Azz Cracka
What kind of radio and processer are you using. Nice job.
Old May 18, 2009 | 07:34 AM
  #2175
eng92's Avatar
head unit - Alpine DVI-9990
processor - Alpine PXI-H990
Old May 26, 2009 | 05:36 PM
  #2176
maxprivate's Avatar
Black Lion
Did you also relocate your Sub from centered? it looks like its off to the right now. Also did you seal off the trunk area behind the seat with wood as well as a piece of wood in the trunk? Im going to be doing mine soon so Im trying to gather as much info as possible. Thanks.
Old May 27, 2009 | 06:00 AM
  #2177
eng92's Avatar
The sub is still centred. It may look otherwise due to the angle of the shot.
There is piece of 3/4" plywood bolted to the sheet metal behind the seats (trunk side) The voids between the two were filled with expanding foam.
Anything that you try and install on the cabin side will interfere with the mounting of the seat back. (unless it is very thin or you remove material from the seat.)
Old May 27, 2009 | 06:43 AM
  #2178
maxprivate's Avatar
Black Lion
I see. Did you use a piece of wood to hang the amp under the rear deck in the trunk? or did you just screw it to the sheet metal? Im surprised there is enough room for it mounted there because the Tru Billets amps are pretty big.
Old May 27, 2009 | 06:50 AM
  #2179
eng92's Avatar
I cut a piece of 1/2" plywood to fit under the rear deck. It is attached with six connector bolts.
Here is an "upside down" component layout I did before installing everything in the trunk.
Old May 27, 2009 | 07:26 AM
  #2180
maxprivate's Avatar
Black Lion
Nice.. you were able to install that whole assmebly like that? How do you like the performance of your system so far?
Old May 27, 2009 | 07:41 AM
  #2181
eng92's Avatar
The mounting boards do not attach to one another. That would be a big mistake as you would be trying to enforce rigidity into the car structure with materials that cannot handle the loads.
The board, with the larger amp attached, is installed first with connector bolts to the plywood sheet (back of rear seats)
The other board is then installed under the rear deck. All the components have to be removed first as this board sits above the trunk torsion bars.
The components are then attached and wired up.
EDIT:
The system has an incredible amount of potential. I have a lot of tweaking to do with my front stage still. As a matter of fact, I should have a couple of new additions coming my way at this very moment.
Old May 27, 2009 | 08:32 AM
  #2182
maxprivate's Avatar
Black Lion
EDIT:
makes a lot of sense. That's what I call Maximizing your trunk space. Excellent job. When Mine is done I'll "Show what's In My Trunk". Thanks for all the info..This will help big time for my install.
Old May 27, 2009 | 05:54 PM
  #2183
arnold931's Avatar
I need to save room for my golf clubs.
Old Jun 2, 2009 | 10:25 PM
  #2184
klemenz's Avatar
nothing special but gets the job done =)
Old Jul 17, 2009 | 08:21 PM
  #2185
luis11821's Avatar
i have two 15" L7 in a sealed box but i want to go ported. i checked the specs for these subs and its 3 cubic feet per sub. ATLEAST. i should go 3.5 tho. problem is i got a maxima. everybody in miami is tellin me datz imposible to do. does anyone know if its possible to but a 6 cubic foot enclosure in a maxima. i dont need trunk space i just need it to fix.
Old Jul 17, 2009 | 09:53 PM
  #2186
Fast1one's Avatar
If you remove the metal piece and use it as a rough template you can add a 3/4 inch piece no problem. Thats how I had an amp rack mounted at one point
Old Jul 25, 2009 | 01:44 PM
  #2187
JEXTEL's Avatar
not really my trunk but here's a recent picture of my car...
Old Jul 25, 2009 | 01:55 PM
  #2188
JEXTEL's Avatar
Originally Posted by AscendantMax
install looks good. i never tried sub up port back in a trunk though. hows the output in that configuration? metered? i was going to pick up a HDC12 or a DD3512 but i opted for something else.
i believe boxes like that work very well in maximas..i had 2 hdc3 12's in a 5cuft box tuned to 35hz and it would do 146.6 on the "old" TL..thats 3 batteries and 2 hk401sx's also i took my backseats out for those numbers
Also boxes that arent very high does alot better in trunk..
-ex. my box was like 10" H 34"w and 32" D (dont quote me on that but its something like that) with 80sqin of port area..that box did the best numbers compared to other boxes that was 14-16" H
Old Jul 31, 2009 | 08:56 AM
  #2189
cmd26's Avatar
hey people I have a single sub setup nn was wonderin wuts the best way to keep it from movin around, somebody told me velcro it to my carpet but thats sounds stupid plus my spare cover is jakked its so limp my sub tips ova all the time.
Old Jul 31, 2009 | 09:41 AM
  #2190
replace the trunk cardboard with a piece of 1/4" mdf or plywood. then bolt the box down to that with some L brackets.
Old Aug 1, 2009 | 10:18 AM
  #2191
Rood's Avatar
2 15'' Power Acoustik ***** in 2 custom ported boxes.
Alpine head unit
2 Power Acoustik Gothic series 5500d series amps
1/0 gauge stinger wiring
and a stressed out alternator
Old Aug 16, 2009 | 10:06 PM
  #2192
95%maxxedout's Avatar
Alpine head unit
wow....and i was thinking the one 15" **** was gonna be to much....guess i gotta find a amp now....
Old Aug 17, 2009 | 10:15 AM
  #2193
bigpopaj369's Avatar
mrood1986 your trunk is amazing!
Old Aug 18, 2009 | 06:51 PM
  #2194
Ignorantkid's Avatar
Yeeaaaaa you guys really don't want to see my trunk LMFAO
Old Aug 18, 2009 | 07:11 PM
  #2195
tigersharkdude's Avatar
i got a question for you audio experts.
ive got 2 12in directed audio SX12D4 subs specs are below. I have had a couple ppl tell me, they sound better in a sealed box. is this true
* Size 12"
* Magnet 109 oz
* Power Handling 600 watts RMS/1200 peak
* Impedance dual 4 ohm v.c.
* Freq. Resp. 25Hz - 2500Hz
* Efficiency 84dB (1W/1M)
* Fs/Hz 32
* Re 7.8
* Qts 0.62
* Vas/liter/ft3 32.07/1.13
* Xmax 16mm
* Depth 7 3/8"
Old Aug 19, 2009 | 07:51 AM
  #2196
most people are going to tell u yes and so am i heres one of my threads theres some info about sealed n ported boxes that may be able to help u out http://forums.maxima.org/audio-elect...amp-setup.html
Old Aug 31, 2009 | 08:48 PM
  #2197
phxgold's Avatar
New gear.
and if you havent heard an IA flatlyne IB you havent heard a real sub stage.
Old Sep 25, 2009 | 11:04 AM
  #2198
Fenton3030's Avatar
Originally Posted by KLOOGY
thats a SICK SETUP!!!
Old Oct 20, 2009 | 08:38 PM
  #2199
dconn's Avatar
Agreed
Old Oct 22, 2009 | 08:16 PM
  #2200
KK07's Avatar
That Eclipse set up is so nice and simple!
