Where to run the power wire
Old Feb 22, 2004 | 09:19 PM
Hunter11's Avatar
I hate to ask this b/c I know it has been asked many times before but where is the best place to run the power wire? The door jam? I think that is the best place besides through the fire wall. I just don't want to see any wires. Any suggestions? Any succesful attempts at running through the firewall?
Old Feb 22, 2004 | 10:26 PM
Cool J's Avatar
i ran mine underneath the car and then went up through the spare tire well. worked very nicely. i can get ya some pics if you want. the wire is zip tied underneath down the whole car. i can get you some pics if you like
Old Feb 23, 2004 | 11:54 AM
AscendantMax's Avatar
you're not afraid of it gettind damaged by road debrise, weather, etc?
Old Feb 23, 2004 | 12:03 PM
Hunter11's Avatar
I would think about running under the car but I am putting the amp under the front passenger seat. But it does seem like it would be more prone to be damaged under the car.
Fosgate Fan,where did you run your power wire?
Old Feb 23, 2004 | 01:27 PM
ShRapNeR's Avatar
I ran mine through the firewall
Old Feb 23, 2004 | 01:39 PM
Hunter11's Avatar
Where though? I didn't see any where that I could run it. Did you drill? If yes then where?
Old Feb 23, 2004 | 01:47 PM
damadmonk's Avatar
if you get down under the steering wheel, you'll see a wire with a rubber grommet running through the firewall. just above and to the left of the brake pedal (right above where the clutch would be if you had a manual). Pull out the grommet, and you can squeeze a 4GA wire in there. It's a ***** to do, but it's easier than drilling. Then have a friend look down the back of the engine bay behind the strut tower. If you coordinate properly, you can figure out how to get a hold of the wire and then route it through the engine bay to the battery. It takes a bit of effort and some patience, but once you get it done, the rest is easy.
As for the grommet, just let it hang. the 4GA pretty much covers most of the hole, so you won't get that much air leaking in. I don't feel anything at my legs.
Old Feb 23, 2004 | 02:14 PM
I ran it through the firewall, down the driver side dash area, and under the front and rear driver side door trim pieces. Then it finally goes into the trunk under the seat cushion. Best part is that you can't see the wire.
Old Feb 23, 2004 | 02:24 PM
Chitwista's Avatar
I think the grommet isn’t necessarily intended for sealing the hole from leaks, but for protecting your power wire from being cut against the bare metal..
Old Feb 23, 2004 | 02:26 PM
sadice's Avatar
same thing i did but i did it from engine bay in..
EDIT i didn't pull the grommet out i squeezed the 4ga wire along with a bunch of wires coming in the car from the engine .....
Old Feb 23, 2004 | 02:28 PM
when you drill through the firewall, it can leave some sharp edges. when the wire moves around, the metal can cut through the wire's insulation, which can cause a short.
Old Feb 24, 2004 | 12:09 PM
damadmonk's Avatar
I agree here on this point, but understand that the hole I was talking about was already there, and i checked before i ran the wire. The edges were decently smooth. Nothing sharp there.
Old Feb 24, 2004 | 03:25 PM
well, then i guess a grommet isn't needed. but wrap the area that will touch the metal with some electrical tape (for extra rubbing protection), just for peace at mind.
Old Feb 25, 2004 | 08:55 PM
ShRapNeR's Avatar
i can post a pic you if you like
just can't until tomorrow after work.
let me know
Old Feb 26, 2004 | 02:57 AM
jtm087's Avatar
please do because i cant find this hole either
Old Feb 26, 2004 | 05:59 AM
Hunter11's Avatar
Yea, please do post a pic. I won't have time to do the install untill Friday but the more I know the better.
Old Feb 26, 2004 | 06:00 PM
Hunter11's Avatar
let me know
If you can, will you post the pics. I am gonna run the wire tomorrow.
Old Feb 27, 2004 | 10:20 AM
ShRapNeR's Avatar
Sorry it took so long, but here are the pics
Engine Bay:
Inside the Car:
I don't know how the stereo shop drilled the hole..
But what I do know is when I took my system out. That is the hole the wire was run through.
The inside pic is almost directly above the deadpedal
If you for some reason can't see the pics.. They are on page 2 of my cardomain site.
Old Feb 27, 2004 | 04:19 PM
Hunter11's Avatar
Thanks a bunch. I read this post right before I was about to go find another way to run the wire. I saw that spot before except I would have never thought that I would end up not hitting anything. That made my day a whole lot easier. Thanks!
Old May 19, 2024 | 07:38 AM
mennygonza7250's Avatar
Can find the wire grumet
Who knows where is the esiest way to put a 2:0 wire tru fire wall
vybz05
Dec 10, 2015 07:38 PM
sake1bs
Sep 19, 2015 09:32 PM
conansriver
Sep 3, 2015 06:38 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
