alternator whine, or engine noise
Old May 28, 2001 | 01:01 AM
ngthing's Avatar
Ever since I installed my second amp I've heard alternator whine and engine noise in my speakers. The power cables and RCAs are all on the same side, I could rerun them, but I'd rather not tear my car apart again.
I've already installed a ground loop isolator on my front set of RCA, which is where I hear the whine. That works sometimes, but I'm wondering if there are other noise filters that might work? or ideas you may have.
thanks
Old May 28, 2001 | 01:05 AM
wmax2k's Avatar
If you're running a LOT of current, then it could possibly be your battery that is inducing the whine. After installing a 1850 Watt RMS system into my car, there was an annoying whine which was cured after I replaced my stock battery with an Optima Yellow. The factory battery isn't exactly the most robust.
Old May 28, 2001 | 05:07 PM
maximadave's Avatar
detailerdaveb@gmail.com
Run your power wire on one side of the car and your rcas
on the other and dump your noise isolator...
Old May 28, 2001 | 06:41 PM
DCmax's Avatar
Behind the dash make sure you dont have any bunched wires or RCAs. I had a big cluster and when I separated the wires, (a much as possible) I lost the whine.
Old May 28, 2001 | 06:57 PM
gmytra's Avatar
I had the same problem after I installed a second amp but it wasn't my wiring it was actually the amp. The RCA inputs were not soldered in properly and it was sucking engine noise. And also try turning your gains down and see if that helps. That could be the problem. This is just my experience.
Old May 28, 2001 | 07:04 PM
gmytra's Avatar
I had the same problem after I installed a second amp but it wasn't my wiring it was actually the amp. The RCA inputs were not soldered in properly and it was sucking engine noise. And also try turning your gains down and see if that helps. If you have your RCA's and power wires on the same side of your car that will definitely induce noise. And noise isolators don't work!!!!!! This is just my experience.
Old May 28, 2001 | 11:46 PM
ngthing's Avatar
Do you mean unbunle RCAs and wires from each other, or unbundle power wires from each other? i've got HELL to pay if that's the case... ;p
Old May 29, 2001 | 01:15 PM
DCmax's Avatar
The RCAs cause most of the whine, but while you're at it, it wouldnt hurt to untangle as much as possible.
derekinthez
Nov 13, 2022 04:00 PM
DJLAX152
May 4, 2021 11:46 AM
seesole
Sep 14, 2015 12:38 PM
jfl330
Sep 4, 2015 01:44 PM
