Best Amplifier
Old Oct 4, 2005 | 01:47 AM
Dragon's Avatar
Best Amplifier
Currently Im running two 12 inch Type R's off a MB Quart Reference 1000 watt amp at 1 ohm(500 to each speaker). the MB Quart subs Im about to install have an 800 watt RMS and Im looking for an affordable amp that will push these to their max. I kinda wanna stick with one amp but Im not opposed to using two amps. Thanks
Old Oct 4, 2005 | 05:38 AM
Robert_J's Avatar
What size/type enclosure are they going in? Because RMS is an almost useless spec on a sub. For example, here's the Adire tech paper on the Brahma power handling - link.
-Robert
Old Oct 4, 2005 | 07:32 AM
MannyNJ2k2max's Avatar
i think a kw is plenty to drive 2 subs...
Old Oct 4, 2005 | 08:01 AM
maxgtr2000's Avatar
KH3 by popular demand
I would keep the same amp, or trade for 2 class d if you are wanting more rms power. If the quarts are dual 4 ohm you can go either way. 2 d class would take the strain off the amp having to run 1 ohm to put out that much power.
Old Oct 4, 2005 | 08:13 AM
ObsidianIce69's Avatar
Yeah the amp you have is pretty good if i remember correctly. Good clean power, there's really not a reason to switch it. It will drive your subs pretty damn hard
Old Oct 5, 2005 | 10:55 PM
Dragon's Avatar
Yeah I cant wait to install them, I just need to get either a box for each sub and have them in the corners of my trunk or get one box to hold both. Im not sure if I should get a ported or sealed box. I listen to alot of rap and I like the speakers to hit really low, I know that would mean ported but I kinda wanna get a sealed, any suggestions. Do the sealed enclosures still get low and boomy?
Old Oct 6, 2005 | 12:20 AM
AscendantMax's Avatar
port those suckers. it'll be louder than your sealed. sealed enclosures can get decently low if they're big enough, or by the use of some polyfill to trick the sub into thinking it's in a bigger box.
Old Oct 6, 2005 | 11:11 AM
Dragon's Avatar
I was kinda thinkin of makin my own box, I have alot of 3/4 MDF lyin around. Is this that hard or should I just buy premade.
Old Oct 7, 2005 | 03:26 PM
slickrick's Avatar
make your own for sure...
Old Oct 7, 2005 | 09:14 PM
Dragon's Avatar
Any good sites youve found with helpful box-building advice. Like how to calculate the size of the pieces. I bought a program but I dont have some of the parameters it asks for for my sub and I cant find them anywhere, so It doesnt calculate it right, thanks.
Old Oct 8, 2005 | 05:12 PM
kcidmil's Avatar
best amp... simple MCD4KW. 4000watts @ 1 ohm and easily bridged
Old Oct 9, 2005 | 01:45 AM
Dragon's Avatar
Would it be better to make the box outta 1" or 3/4", just wonderin if 1" wouldnt really make a difference.
Old Oct 9, 2005 | 08:58 AM
bookechu's Avatar
Go with 3/4. 1" would be for something like a Re XXX or a W7...
Old Oct 9, 2005 | 11:18 AM
eh, even the xxx doesn't need full 1" mdf unless your got some huge panels that will flex easily.
Old Oct 9, 2005 | 08:18 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
i would have to say go with the mtx1501d modified or a mmats d100hc...your subs will hate you but your ears will love either.. both are beasts and will easily supply approx 1500 watts.
Old Oct 13, 2005 | 03:58 PM
makavelisk's Avatar
If you are looking at building your own box you can also go to rockford fosgates home page and you can input the measurements and it will give the size according to those numbers.
Old Oct 13, 2005 | 08:09 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Teh weak
Arc 4000SE
Old Oct 14, 2005 | 12:30 AM
505max94se's Avatar
Originally Posted by Pearl96Max
Teh weak
Arc 4000SE
US AMPS USA-6000
Two Channel Class AB Amplifier
Total Power Output: 6000 Watts RMS
THD at Rated Power: 0.1%
Signal/Noise Ratio: >105dBA
Frequency Response: 5Hz-50KHz
Damping Factor: >2500
Fuse Rating: 900 Amps
One Ohm Stable
3000 Watts x 2 into 1 Ohms
6000 Watts Bridged into 2 Ohms
(underrated rms power rating)
VLX-400 and USA-800 are beasts as well
vlx400 is rated at 2400x1@1ohm (underrated rms measured at 12v). Since it is a high current amp you can play it at 1/2 ohm also (double the power). I've heard that it can burp at 1/8 ohm.
Old Oct 14, 2005 | 02:45 AM
Dragon's Avatar
Does anyone have any good brands to recommend, I see split opinions on the web regarding the Boss, Hifonics, Lanzar, MA Audio, Sony, and Crunch amps, any recommendations on good brands that give the power they state?
Old Oct 14, 2005 | 11:09 AM
kcidmil's Avatar
Memphis... in fact I've been able to squeeze more than the rated power out of my MC500D.
Old Oct 14, 2005 | 04:56 PM
Dragon's Avatar
Any opinions onthe others, thanks
Old Oct 14, 2005 | 06:02 PM
505max94se's Avatar
I don't know your price range but this should have more than enough clean power for ya.
http://cgi.ebay.com/US-AMPS-CHROME-U...QQcmdZViewItem
sliptap
Sep 30, 2015 05:57 AM
EdRomo86
Sep 12, 2015 07:49 PM
thenewguyy
Sep 12, 2015 11:12 AM
kirkhilles
Aug 8, 2015 10:53 AM
Maxima95GLE
Dec 7, 2000 11:02 AM
