Bass dilema
Old Dec 1, 2005 | 06:33 AM
JP11283's Avatar
Bass dilema
I've got a Concept CC504 amp running Infinity Kappas and a 12 in. Alpine Type E sub. The sub sounds great with the trunk pass through open, but the bass diminishes quite a bit with it closed. I don't really like having to leave the pass through open all the time, so what can I do to get it to sound better? Thanks
Old Dec 1, 2005 | 06:39 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
What kind of box is this in? You could make a new one with a transmission line or go ported (if not done so already)
Old Dec 1, 2005 | 07:14 AM
JP11283's Avatar
It's in a 1.25 cubic inch sealed box. I listen to mainly rock music so I want to keep it tight for double bass drum hits.
Old Dec 1, 2005 | 07:39 AM
I would recommend a different sub, then. Alumapro subs will hit much better for metal. Don can hook you up.
Old Dec 6, 2005 | 11:27 PM
cmosanna's Avatar
The sub should be fine. I'm not familiar with taht amp, so idk if the sub has enough power going to it.
But i do have a ?
What direction is the sub facing?
Old Dec 6, 2005 | 11:56 PM
slickrick's Avatar
But i do have a ?
one type-e is not enough for any kind of spl in a sealed box IMO. so the sub is not fine. the box should be ported for the spl you want...along with another sub that can handle more than 200 watts rms.
Old Dec 7, 2005 | 12:46 PM
AscendantMax's Avatar
yeah, plus you would want a more accurate sub so the tightness is still there even in a ported application. my brahma was very punchy even when ported
Old Dec 7, 2005 | 01:08 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
no plug for the splinters? Hmmmm...ascendants slippin
Old Dec 7, 2005 | 01:13 PM
haha well my 15 isn't ported, so i can't openly say they perform as accurately in a ported enclosure. (though i'm sure it will still sound awesome)
Old Dec 7, 2005 | 01:22 PM
Chocolate_Boi_1Der
there we go, wth the box size its still a good option.
Old Dec 9, 2005 | 11:40 AM
Big_Ham's Avatar
MaximaFreak
But i do have a ?
Good question. The sub should be firing towards the back of the car, not the cabin. Additionally ... you could get a dedicated amplifier and turn that gain up.
Old Dec 11, 2005 | 06:35 PM
Chocolate_Boi_1Der
gain should be set properly using a dmm, dont use it as a volume control
Old Dec 11, 2005 | 08:35 PM
Big_Ham's Avatar
MaximaFreak
If you want to set it properly, you should have it EQ'd to the tune of 30+ bands and have it set with a o-scope ...
That said, setting a sub amp gain certainly does not require a dmm, just a discerning ear that backs off about 1/4 turn from the point of any audible distortion, clipping or smoke.
Old Dec 11, 2005 | 08:51 PM
Chocolate_Boi_1Der
lol there you go...I dont know where your coming from with the smoke cause its like then lol
Mar 12, 2020 12:06 AM
vybz05
Dec 10, 2015 07:38 PM
popdedop
Sep 11, 2015 11:17 AM
Cincy94Max
Feb 23, 2001 05:57 AM
Nick97SE
Dec 16, 2000 02:52 PM
