View Poll Results: Which? Why? Better?
Stinger Expert
55.56%
Stinger Dream
11.11%
Stinger Bullet
33.33%
Stinger Helix
0%
Voters: 9. You may not vote on this poll
RCA Decisions...VOte
Old Jan 9, 2006 | 05:04 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
Recommendations?
Currently running some old purple fosgates, and a crap pair for the sub.
Looking at a sub that will take a much smaller enclosure so i can actually get in and glass the damn trunk some...
im checking out rcas currently and curious which you use..
currently looking at the
Stinger Experts
Stinger Dream
Stinger Bullet
Stinger helix
All claim SUPERIOR NOISE REJECTION, so if no difference whats your vote in looks. Rack will be for a duo of xtants, and minimal rca shown. (604x and a 403a)
Old Jan 9, 2006 | 05:21 PM
AscendantMax's Avatar
the stinger experts look nice. but how flexible are they? they seem rather thick...
Old Jan 9, 2006 | 05:36 PM
Rider69's Avatar
In my opinion of those, they are all decent so whichever is cheaper. You will not notice a sound difference between them.
Old Jan 9, 2006 | 05:37 PM
Chocolate_Boi_1Der
no idea, im going on pics currently, my guy has all in stock but I cant make it out till monday so thats when i plan to buy.
Old Jan 9, 2006 | 05:38 PM
Chocolate_Boi_1Der
i get a really good deal on any of em so the cost difference isnt TOO Bad.
Old Jan 9, 2006 | 07:16 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Experts only since they came out. Although my car is also used for demo purposes, and my mentality makes me have the highest line. The dreams are an excellent choice as well. Bullets I can live without and stopped stocking them, Ive had a ton of instances where there was a problem a those were the culprit. The Helix is also now available in a 4 channel as well as the Hypers. Cost considering the Helix and the Hypers are my two most commonly sold.
Old Jan 9, 2006 | 08:05 PM
505max94se's Avatar
I have experience with the hpm and the expert. The experts are really nice, flexible, and have locking ends. Personally, I like knukonceptz top line home home interconnects.
Old Jan 9, 2006 | 08:37 PM
Chocolate_Boi_1Der
alright, ill cop the experts, thanks guys. 505 they only carry the stinger where im going that and finally go to a ot wiring kit may sell my fosgate batt terminals as well
Old Jan 9, 2006 | 08:56 PM
Pearl96Max's Avatar
Try a resitance check between the two.
Old Jan 9, 2006 | 09:16 PM
9Nails's Avatar
I know there has to be a reason for all the gold plating, oxygen free cables, and shielding. As "Joe Consumer" I just can't figure out when I reap the benefits. Is it all about longer life, less interference and better signal quality? And at what point does the market buzzwords meet a tangible gain? In my history, my #1 problem with RCA cables is from them falling off the amp. Seems that most cables offer a locking system that would solve my greatest of problems. My #2 problem is usually from dissimilar metal corrosion. Now gold plating really helps to reduce that. If I carefully choose my cables, I stay away from my #1 and #2 problems, and then the RCA cables don't become the weakest link in my system. I usually think like Pearl96Max, and get the best I can afford so I don't end up replacing garbage that I thought would get me by. Typically the ground wire is where I pickup all my troubles! So I usually upgrade the big 3, and then keep it clean from there, routing my source cables away from power and if I have to, crossing power wires only at 90 degree angles.
Old Jan 9, 2006 | 09:27 PM
Pearl96Max's Avatar
I agree for the most part, although Gold plating to me is crap. Its a marketing gimmic to make items more appealing. Gimme straight plain ole copper anyday. Adding the Gold plating is just adding another coating of potential problems. In ring terminals and such, I Always grind them down prior to installation.
You can run your RCAs and power wire together, it wont cause any problems.
Old Jan 9, 2006 | 10:53 PM
505max94se's Avatar
Between the knukonceptz and the stinger expert? Why? The knukonceptz feel nicer, look nicer, have more shielding, the locking ends are ALOT nicer than the stingers, and they look like they're hand made. I bet they'd have less resistance than the experts. The downsides are the following: since they're made for home use, they aren't near as flexible as many other car specific cables, there is one seperate cable per channel (2 for R,L), and each cable is about the same size as 4 awg.
Old Jan 9, 2006 | 10:56 PM
chinaonnitrous1's Avatar
hmm interesting discussion about the knukonceptz Vs stinger.....any more enightenment?
Old Jan 9, 2006 | 11:14 PM
505max94se's Avatar
http://www.stingerelectronics.com/we...erconnects.asp
http://www.knukonceptz.com/productDe...?prodID=eKs-R2
Old Jan 10, 2006 | 12:29 AM
Pearl96Max's Avatar
I bet they'd have less resistance than the experts. :
Id be willing to accept that bet. Although Im not sure which ones I used to test, Im not all that familiar with them.
Old Jan 10, 2006 | 01:48 AM
505max94se's Avatar
I'll test my 2 meter set of knukonceptz eks interconnects, and to make it fair, you test a 6ft set of stinger expert interconnects. How exactly do you want to test the resitstance (there's a couple of ways to do it)?
Old Jan 10, 2006 | 02:01 AM
505max94se's Avatar
My radioshack digital multimeter reads between 0 and 0.1 ohms(it fluctuates back anf forth) when each lead of the multimeter is connected to the center pin and the outer jacket on each end of one rca (one channel). I wish my meter would go lower than 0.1 so I could get a more accurate reading.
Old Jan 10, 2006 | 06:51 AM
Pearl96Max's Avatar
.001 Fluke Autoranging 73 III
Old Jan 10, 2006 | 08:25 AM
LeX's Avatar
LeX
Nissan by Nature
I never bought into the hype about RCA cables. As long as it's not wal mart stuff i really am not picky. I ran esoteric audio in my old car, no problems ever and was happy with the cables. Got mirasonic interconnects for new car. Nothing expensive but quality , cheap, and functional
Old Jan 10, 2006 | 09:23 AM
myer84's Avatar
I Have the dream series. They sound good
Old Jan 10, 2006 | 02:16 PM
BBOYSTEVIE's Avatar
Back from Hibernation
I'm not much into the hype of RCA cables either. There's so many things I think are more important in getting good sound before RCA's, specifically speakers, speaker locations, deadening, and processing/tuning. Noise free, solid connections is what I'm after.
Anyway, if you're interested I can check resistance on my Knukonceptz RCA's ( I don't have the home audio line, but the "higher" line of their car audio stuff....got em cause they were reasonably priced and black, matching most of what I have going on in my car).
Don's Fluke is definately the ****. I totally want one now, along with the cool test leads it comes with that I hadn't seen before. I prolly wouldn't bother w/ the fluke (autoranging is nice, but not a necessity) if I could just get those test leads. I really dug those. BUT Don could use some jasper circle jigs. I'll trade ya!
Old Jan 10, 2006 | 02:17 PM
Pearl96Max's Avatar
Templates work well also with a flush trim bit. I just did new rings for the mids....a breeze.
Old Jan 10, 2006 | 02:24 PM
BBOYSTEVIE's Avatar
Yeah I guess i want it to be absolutely mindless. I love my circle cutters. When i got home, I put the holes in the double 3/4" (1.5") mdf in 5 minutes.
I know you're good w/ the flush trim bit, but is it ever not big enough of a cutout for the speaker?
I couldn't imagine trying to, for instance, countersink these ribbons without my circle cutter....
But those test leads...I want em.
Old Jan 10, 2006 | 02:25 PM
Pearl96Max's Avatar
Yea with the new 2" bits they work well.
Those leads are only about $30-40...
Old Jan 10, 2006 | 02:28 PM
BBOYSTEVIE's Avatar
thats a lot for test leads...
But I think I'll pickem up How much is the meter AND test leads?
Know a site? I want them leads.
Old Jan 10, 2006 | 03:23 PM
505max94se's Avatar
Hey Steve, are those aurum(spelling?) cantus ribbons?
I'm used to using my friends Fluke (I love Fluke) but I recently got this radioshack and it works really accept it's not quite as accurate (of course).
I also think RCA are mostly overrated. I just like using nice ones because they look nice. I think their main purpose is to block noise with shielding. I did notice my system had a slight amount of noise before I installed the knukonceptz and after I installed them I had ZERO noise. Before, I also had a bunch (active 4-way) of random crappy rca's in my car. As long as decent rca's I think you'll be fine, just get the ones thar look good.
Old Jan 10, 2006 | 03:28 PM
505max94se's Avatar
I need to pick up a circle cutter. You won't believe this, I recently got a NIB Ridgid table saw FOR FREE, LOL.
Old Jan 10, 2006 | 03:37 PM
BBOYSTEVIE's Avatar
Actually those are Fountek Neo 3's. I later went 3 way front with AC ribbons (just like playing w/ different stuff)....that one looked something like this.....
You do have a router, too, right? Wanna make sure you know the attachments are router attachments. I miss my old table saw though. Wanna get a decent one eventually, but first I wanna get air.
I'm lucky that I live like 5 minutes from a woodcraft, so all that stuff is right here....
Old Jan 10, 2006 | 03:52 PM
505max94se's Avatar
Yes I have a router. I had air when I lived in nm but now I don't and I need it badly. Don, what is a good QUIET compressor??
Steve, I thought you were doing ID horns? I'm always changing my setup as well, it's fun to experiment.
It seems like I'm always jacking someone else's thread and I need to stop. Sorry for jacking this one (althogh I feel that the rca questions were answered)
Old Jan 10, 2006 | 03:54 PM
505max94se's Avatar
My friend in NM has a fluke and he also has a set of eks kables so he said he'll meter them tonight.
Steve, how would you say those ribbons compare to Don's dynaudio setup? I have a set of neoplanars that I wanted to put in my car but they're too big.
MannyNJ2k2max's Avatar
since they all do the same, and cost is not an issue...why not just go with the ones that aesthetically would suit your equipment/install best?
Old Jan 10, 2006 | 03:59 PM
505max94se's Avatar
1ochars
Old Jan 10, 2006 | 05:04 PM
BBOYSTEVIE's Avatar
Yeah I am switching to ID horns. Those were just my past few systems
I don't know if it's fair to compare speakers (ribbon tweeters in this case) to a speaker setup (don's 3 ways). I do really like the Dyn 100 (or is it 110)tweet a lot. I also don't think Don's setup was close to optimally tuned (or having HU probs or whatever, or not tuned the way I like it...), so again, not a fair comparison.
Just listening to someones system it can be hard to jusge speakers, cause tuning has so much to do with it.
Guess I'd say the ribbons were more "sparkley" sounding then the dyn (for better or worst) as I have heard the dyn tweet in don's and other systems. I think the Dyn tweet is pretty nice n lively for a soft domer. Sometimes the ribbons sounded so "pretty" it was pretty in an inaccurate way. I didn't like it how the ribbons just hadda stare you in the face. Everyones attention was always drawn down to them, and the soundstage lowered. Prolly shoulda put some grille cloth over them, but again, they're big and have to be pointing towards listeners, still drawing attention there.
My horn setup is becoming a pain in the butt now, as my kick panels are preventing me from getting the horns as far over as I'd like. A narrow soundstage is one prob. associated w/ horns in the car, and I fear that my car is really going to suffer from that, cause I can't get them over to the absolute side of the car without putting them through my midranges. I think i'll be looking at a soundstage not even hitting the a pillars the way things are looking now
Old Jan 10, 2006 | 05:24 PM
Chocolate_Boi_1Der
nah dont trip. Ive pretty much gotten my answer. I was really curious as to the noise rejection properties of each as the site just says "superior" for every cable. SO in going with a complete matching higher quality than im running i just wanted to make sure i wasnt getting something problematic.
as for the ribbons, I still cant believe their THAT damn big.
Old Jan 10, 2006 | 05:36 PM
505max94se's Avatar
Mine are 24"x4.5" and a roughly a 1/4" deep
9aj9
Apr 5, 2020 12:11 AM
Matt93SE
May 24, 2019 02:58 PM
Yellowbrother
Dec 24, 2001 09:46 PM
Kevin Wong
Nov 24, 2001 09:17 PM
ngthing
Jul 6, 2001 04:19 AM
