Eclipse AVN5423
Old Jan 22, 2006 | 10:04 AM
HarrisH's Avatar
Eclipse AVN5423
I have this headunit but the antenna goes up when the CD is on. I want the antenna to go down when the CD is on, and only go up when the AM/FM radio is on.
Old Jan 22, 2006 | 10:07 AM
Kevlo911's Avatar
Kevlo for President
Double check all the wireing...
Old Jan 22, 2006 | 10:26 AM
HarrisH's Avatar
Is there a way you can hook it up like that? Don did the install.
Old Jan 22, 2006 | 10:36 AM
slickrick's Avatar
ask "the Don"...he will know.
Old Jan 22, 2006 | 01:27 PM
djfrestyl's Avatar
Suspension Yoda
The blue/white wire coming out of your HU is hooked into your power antenna wire.
Blue/white should be your amp turn on ONLY. and solid blue should go to the power antenna wire.
Old Jan 22, 2006 | 01:42 PM
HarrisH's Avatar
Will this cause the antenna to go down when the CD is on?
Old Jan 22, 2006 | 01:50 PM
Pearl96Max's Avatar
I tend to get a bit irritable
As it is.....
Old Jan 22, 2006 | 02:48 PM
Pearl96Max's Avatar
BTW what the hell is a 5423???
Old Jan 22, 2006 | 03:32 PM
HarrisH's Avatar
You know what I mean.
Old Feb 24, 2007 | 08:03 PM
HarrisH's Avatar
As it is.....
So why does the antenna not go down with CD on?
Old Feb 24, 2007 | 08:06 PM
djfrestyl's Avatar
Suspension Yoda
Because it's not wired correctly.
edit: nvm saw that Don did the wiring.
..but it is the only thing that makes sense.
Also, what the hell is with bumping a 1+ year old thread?
Old Feb 24, 2007 | 08:51 PM
HarrisH's Avatar
Because my problem still isn't fixed. The "DON" supposedly states it's wired correctly yet the damn antenna still stays up with the CD playing.
Old Feb 24, 2007 | 08:58 PM
Pearl96Max's Avatar
And according to caller ID the last time you tried to call about this was...hmmm Nevuary. Despite the post being here you have yet to call or email me directly about it, so want resolution do you expect exactly?
Old Feb 24, 2007 | 09:26 PM
HarrisH's Avatar
Don I did call you about back when I posted this, you stated "the car is wired correctly and if the antenna does not go down there's nothing that can be done."
I'm trying to figure out if the antenna should go down or not if a CD is being played. If it's wired correctly and the antenna still remains up then perhaps there is nothing that can be done. I still want to know if other people that have similar headunit setups found out a way to make the antenna go down while playing any source other than FM/AM.
Old Feb 25, 2007 | 12:05 AM
DcMaN's Avatar
harrish, some radios/even eclipse doesnt have a power antenna input. So the antenna will stay up all the time, however my eclipse does have the power antenna input.
Old Feb 25, 2007 | 08:14 AM
mendon99's Avatar
tastey wheat
take your dash apart Harrish. if there is no straight blue wire coming from the Eclipse, and the blue wire from the car's harness is going right to the blue/white wire, then its hooked up correctly. theres nothing more that really can be done.
Its that, or never have your antenna come out at all..
Old Feb 25, 2007 | 03:19 PM
MacAlert's Avatar
Or wire a switch to the antenna.
Old Feb 25, 2007 | 05:34 PM
mendon99's Avatar
tastey wheat
yeah you could do that too. ...but OCD much?
Old Feb 25, 2007 | 06:14 PM
MacAlert's Avatar
*shrug* It wouldn't bother me....actually it doesn't, I don't even have an antenna to worry about.
hawkdog
Apr 22, 2001 04:52 PM
RaYnMeLa
Apr 17, 2001 06:20 PM
wesley
Feb 2, 2001 01:31 PM
QUANSUNG
Dec 7, 2000 01:29 AM
