need help with ECLIPSE AVN 2454!!!!!!!!!!!
Old Apr 18, 2006 | 11:59 PM
Talyan03's Avatar
Hello guys I need help getting my back up camera 2 work! The unit has video out and I plugged my camera in and wired the power cable to the battery! And for some reason it doest work. And I’m also trying 2 wire my steering wheel buttons with SWI-ECL module but I can’t get buttons to work, Can some one please help me out???????
Also I was told if you have wireless remote you can program it through remote, how can that be done???????? Please post some info
Old Apr 19, 2006 | 04:49 AM
nismos14's Avatar
§è~® f®ÈÄk
The intructions are in the PAC for how to get the steering wheel functions to work. It's not hard at all. I just did mine on the pioneer last night, too easy.
No idea about the vid inputs, you might have to go into the functions of the HU and switch on/over to the other input?
Old Apr 19, 2006 | 05:04 AM
djfrestyl's Avatar
Suspension Yoda
Did you say that you're using the video OUT on the AVN for your camera INPUT?
You may want to reverse that, champ, use the output from your camera to go to the INPUT of the AVN.
Old Apr 19, 2006 | 05:05 AM
djfrestyl's Avatar
Suspension Yoda
Also, are you using the Eclipse camera?
Old Apr 19, 2006 | 06:25 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Also...no a remote is not used to program the unit. The SWI-ECL is intended to be hardiwred, thus not needing a remote.
Old Apr 19, 2006 | 06:26 AM
Pearl96Max's Avatar
...and did you connect the reverse wire?
Old Apr 19, 2006 | 12:13 PM
Talyan03's Avatar
the reverse wire is just a source of power corect me if im wrong
Old Apr 19, 2006 | 12:27 PM
Pearl96Max's Avatar
thats correct, but if its not used either via switch or reverse, then the camera view will not turn on.
djfrestyl's Avatar
Suspension Yoda
It's a signal wire, not sure if it's + or -
Old Apr 20, 2006 | 11:14 AM
Talyan03's Avatar
still no image, black screen and wite lines go across any ideas?
Old Apr 20, 2006 | 11:29 AM
djfrestyl's Avatar
Suspension Yoda
It would help if you answered my question about it being an Eclipse camera.
Old Apr 21, 2006 | 12:39 AM
Talyan03's Avatar
o no its ebay one it has one cable for power source and other is video male thats it.
Old Apr 21, 2006 | 04:37 AM
djfrestyl's Avatar
Suspension Yoda
Well then the reverse feature from the AVN really wouldn't work in your situation.
Hook the camera up to the AUXILIARY IN of the HU and switch to VTR in your menu to make it work. You will also need to power the camera via a switch, you can rig that up however you want.
hawkdog
Apr 22, 2001 04:52 PM
RaYnMeLa
Apr 17, 2001 06:20 PM
wesley
Feb 2, 2001 01:31 PM
QUANSUNG
Dec 7, 2000 01:29 AM
