Alarm install help. 791XV
Old Aug 17, 2006 | 07:23 AM
Kevlo911's Avatar
Kevlo for President
On the H1 harness, the Blue "multiplex" input wire. Where do I connect this?
I bought this used from another 4th genner.
On the H2 harness, all the wires are cut and only the violet/black wire is left, but it is already connected to the White/Blue wire on the H1 harness. Do I need to extend and use the other wires on the H2 harness?
There is a 4pin connector out of the 500m with wires stripped at the end, what do I do with that?
Old Aug 17, 2006 | 07:54 AM
Pearl96Max's Avatar
I tend to get a bit irritable
The Blue multiplex is your trunk trigger...connect it to your trunk trigger on the car...Purple/yellow (smaller gauge) in the kick.
Sounds like a hacked install on the H3 harness..Violet/Black is the tach input (White/Green @ the ECU). NOTHING from the alarm should be looped to it. You also NEED the brown wire from the same harness which connect to the brake. How that thing ever worked properly without it is beyond me...
Nothing.
Old Aug 17, 2006 | 07:58 AM
Kevlo911's Avatar
Kevlo for President
The Violet/white wire on the H3 harness is there and is long to reach the ecu.
The Violet/black on the H2 is the Programmable 4channel output.
Old Aug 17, 2006 | 08:00 AM
Kevlo911's Avatar
Kevlo for President
The H2 harness has the Factory arm and disarm on it, but the only wire used was the violet/black.
Old Aug 17, 2006 | 08:12 AM
Pearl96Max's Avatar
haha I read it to fast...you dont need that wire. Unless your connecting something else...you dont need that harness at all.
Pearl96Max's Avatar
read post 5 sir, just leave that harness out..
Old Aug 17, 2006 | 08:22 AM
Kevlo911's Avatar
Kevlo for President
WHat about this 4pin connector on the 500m. It has blue, orange, violet(ish), and a pinkish wire on it. The blue, orange, and violet have stripped ends.
The green door trigger wire also has a diode on it, does your installs have that too?
My Doorlock Harness is taped up and has a 3 pin connector comming out of it with a blue, red, and green wire on it. Where do I connect this?
Old Aug 17, 2006 | 08:39 AM
Kevlo911's Avatar
Kevlo for President
H1:
Red - Constant 12(ING Switch White/Red or White/Purple)
Black - Ground
White - Parking lights(Steering, red/green)
Brown - Siren
Blue - Trunk(kick panel, purple/yellow)
Green - Door Trigger(kick panel, red/white)
White/Blue is connected to the Violet/Black(h2) wire on mine
H2 Harness:
Not used/see above
H3:
Grey - Hood(bcm, yellow/black)
Brown - Brake(brake swtich, red/green)
Violet/White - tach
Black/White - neutral safety(green/orange
Doorpin connector:
4pin 500m harness:
Blue -?
Orange - ?
Violet - ?
Pink - ?
The heavy guage wires are self explanitory: All on ignition switch
Purple - to starter(Black/Yellow or Black/White
Green - key side starter(above)
Red(s) - 12v(White/Red or White/Purple )
Orange - Accessory(blue)
Pink - Ignition(Black/White or Black/Red)
Pink/White - Ignition2(Red/Yellow)
DOes that sound right? Or are there any more wires I need to use? Do I need to use a relay for anything?
Old Aug 17, 2006 | 09:31 AM
Pearl96Max's Avatar
You dont use that harness AT ALL.
green and blue go to the door lock wires in the door.
No need for a diode on a 4th gen
Old Aug 17, 2006 | 09:39 AM
Kevlo911's Avatar
Kevlo for President
Nice, so my diagram looks right minus the door pin connector?
Since our lock and unlock are (-) and it takes a double pulse to unlock, does that mean I will have to push unlock twice for it to unlock the doors?
Old Aug 17, 2006 | 09:57 AM
Kevlo911's Avatar
Kevlo for President
Never mind about the double pulse, I guess I have to hope mine is unlocked and change the setting via the valet switch.
Old Sep 15, 2006 | 05:15 AM
sean05's Avatar
im pretty sure the couble pulse is changed through the valet programming. I have my basic keyless, door triggers, and parking lights all wired. As of right now mine is on double pulse but i think in the second programming menu you can switch it back to single pulse.
Old Sep 15, 2006 | 05:16 AM
sean05's Avatar
opps didnt see this thread was over a month old.. ekk
pears
Sep 18, 2015 05:25 AM
toyoking
Sep 16, 2015 07:05 AM
flu2000
Sep 14, 2015 12:34 PM
