4th gen Max 2-way active!
Old Sep 6, 2008 | 09:40 AM
  #81
djfrestyl's Avatar
Suspension Yoda
Looks good.
Personally I would have picked a darker color for the carpet.
Old Sep 6, 2008 | 05:58 PM
  #82
travmaximas1998's Avatar
for the baffle or the whole box?
i tried to tap the knowledge of the audio section, but know buddy had anything to say about gettin the right color carpet.
so this is what i went with it works for my purpose but in the future i wanna try some different carpet cuz this stuff is sort of hard to work with
Old Sep 6, 2008 | 06:02 PM
  #83
djfrestyl's Avatar
Suspension Yoda
Isn't the baffle and rest of the box the same colored carpet?
know buddy? do you mean nobody?
What kind of carpet did you use?
Old Sep 6, 2008 | 06:09 PM
  #84
AscendantMax's Avatar
shoulda asked me trav, i go to keystone bro's off of 45 near 610. they got a crapload of carpet in a bunch of colors.
Old Sep 6, 2008 | 06:49 PM
  #85
alright man well for the next box we will be in touch
i may put the icons in a sealed box so i can get some trunk space back, but that is pretty far down the road
Old Sep 7, 2008 | 12:15 PM
  #86
mtnickel's Avatar
Nice Job on the deadening all round. I just finished most of mine about 2 months ago. Spent a week on the entire floor (whole interior out), and another week on the front 2 doors. What i find really useful is to have the amps and deck in temporarily, then with an AUX in (or CD If that's your only source), use a signal generator to go through sweeps with your midbasses blasting. You can find a lot of rattles that way. I did it first without the door panel on (which was actually pretty good for rattles), and then again with the deadened panel on (which had more rattles to rid).
This is my first post in the Audio section, but i was happy to see a 4th gen with a very similar setup to mine.
I'm running the 880prs, Seas 27TAFNC/D (neo's), B&C 6NDL38 (7" midbasses...B&C is a pro-audio brand, so they are high efficiency, but also high excursion (5.5mm), and high power handling and my favorite of all...very high output.)
As for subs, currently running a Dayton 10" Reference HF in 1.1cu ft.
Amps - Xtant A2002 (tweets), Xtant 4.4 (bridged to midbass), Avionixx Axt1200.2 (highly recommended budget amp buy. 1500rms @ `14v @ 4 ohms, and only $129.99 on ebay...on final clearout. 3-4 years ago, they were $250ish+ and were still a good deal. Class T design and very clean.
Anyways, I shoudl get an install thread on my setup going i think. My only other plus in my setup is i did custom A-pillars for the tweets (fully molded all together..they're loookin good ).
Good luck on the rest of the install!
Old Sep 7, 2008 | 01:14 PM
  #87
ya i would be interested in seeing ur log
Old Sep 7, 2008 | 01:46 PM
  #88
djfrestyl's Avatar
Suspension Yoda
no homo.
Old Sep 7, 2008 | 02:02 PM
  #89
BLACKonBLACK98's Avatar
Former Vendor
Old Sep 7, 2008 | 03:19 PM
  #90
build log that is...
Old Sep 24, 2008 | 11:05 PM
  #91
now for some steps in the right direction
new rcas ran(no whine ) and ipod connected up
test setup lol
remote wire(extra stuff i had lying around)
more pics to come in the morning
Old Sep 25, 2008 | 05:49 PM
  #92
now for the 1/0 being ran underneath the car
grommet the wire will come through
wires in
Old Sep 25, 2008 | 06:23 PM
  #93
the wire in the loom under the car
battery with its new 1/0 friends
Old Sep 25, 2008 | 06:25 PM
  #94
now for the temp setup in the trunk with the 100.4 so i have some tunes
till i get the box in.
Old Sep 25, 2008 | 08:03 PM
  #95
Former Vendor
all i'm sayin is can i get some shop time? need some woodworkin' sucka.
Old Sep 25, 2008 | 08:29 PM
  #96
its my friends shop so i would have to talk to him and there aint much wood work goin on in this shop where i did the wiring. but we could probably get some stuff worked out for ya
Old Sep 26, 2008 | 06:57 AM
  #97
djfrestyl's Avatar
Suspension Yoda
Underneath the car? Seriously?
And they ran ground the entire length of the car too?
Old Sep 26, 2008 | 07:15 AM
  #98
nismos14's Avatar
§è~® f®ÈÄk
If you bottom out those wires could get scraped and cut, could be some fireworks
Old Sep 26, 2008 | 08:17 AM
  #99
ya the ground all the way to back i know its overkill just wanted to have a real solid ground.
and yes im aware of bottoming out, my car isnt dropped or anything, so im not real worried about it i will keep an eye on my wiring.
i am double fusing the positive run, to avoid a fireworks show if it happens to short out
Old Sep 26, 2008 | 01:59 PM
  #100
oh and the real reason i brought the negative to the back cuz i will be running a second battery
Old Sep 26, 2008 | 02:25 PM
  #101
djfrestyl's Avatar
Suspension Yoda
A more solid ground would have been to ground it to the sheet metal in your trunk. It all goes back to the same place anyway.
Double fusing is absolutely unnecessary unless you expect something to go wrong in between your battery and your first fuse... ~15 inches? I think not. Once a short occurs, you want the power cut as close to the battery as possible. Think about it logically.
Old Sep 26, 2008 | 03:32 PM
  #102
since i was going to run 2 batteries i thought having a fuse ~15" from starter battery then ~15" from battery in trunk
Old Sep 27, 2008 | 01:30 PM
  #103
ThurzNite's Avatar
The body probably has more resistance than the wires he ran.
Old Sep 27, 2008 | 01:54 PM
  #104
not if he grounded directly to the frame rails or any other solid piece of metal in the trunk. the difference might be negligible.
trav i'm jealous of that workspace you got there.
Old Sep 27, 2008 | 02:01 PM
  #105
Former Vendor
double fusing is completely necessary since there is a hot in the trunk as well as underhood. suppose something happens between the underhood fuse and the rear battery. without being double fused the front fuse will blow but you will have a hot wire from the rear battery up. a fuse as close to the front battery + and one as close to the rear battery + as possible is the right way to do it.
i've asked about running a ground back up to the battery as well. some say it doesn't make a difference and some say it does (although it may be negligible). i researched a little on ground loops and came to the conclusion that it's probably a good idea because of al the bcu's grounded to the chassis in the 4th gen. one thing is for sure though; a sheet metal ground is not more solid. it is as solid at best.
Old Sep 27, 2008 | 02:12 PM
  #106
djfrestyl's Avatar
Suspension Yoda
I was under the assumption only one battery was being used.
Reading >>me.
Old Sep 27, 2008 | 02:44 PM
  #107
Former Vendor
had a feeling there was a misunderstanding. you're in the audio section way to much to not know what you are talking about.
Old Sep 27, 2008 | 08:37 PM
  #108
exactly
thanks mike
and im glad everybody is on the same page now
Old Sep 27, 2008 | 08:38 PM
  #109
ya its my buddies shop. very nice to have a big solid slab of concrete, and plenty of tools at my disposal
Old Mar 17, 2009 | 04:20 PM
  #110
first lets start with the box modifications
battery box
Old Mar 17, 2009 | 04:36 PM
  #111
more battery box
deadened the trunk lid
new terminals(screw my terminal cup)
Old Mar 17, 2009 | 04:37 PM
  #112
finished product
sry about the big pictures photobucket is being gay
Old Mar 17, 2009 | 04:54 PM
  #113
ThurzNite's Avatar
Wow, I like the lattice-work of your ceiling!!!
Anyways, very impressive custom build. How's it sound so far?
Dr J
Old Mar 17, 2009 | 05:19 PM
  #114
VTonmymind's Avatar
Mmm, fresh lobster
Impressive indeed. Also curious about the sound. I've got a mad hankerin to go 2-way active this summer and wanna know how it sounds compared to a standard bridged setup. I'm thinking my system can sound a heckuva lot better if I go active but I wonder if my current amp has enough ***** to make it worth it (75 x 4)
I see that your tweets are getting 100w, what are your mids getting a piece?
Old Mar 17, 2009 | 05:31 PM
  #115
the 2 way is definately very nice.
i can control the range of frequencys the speakers see. The pioneer 880 has the abilitys to control the crossover points without messing with the amps.
the tweets are probably seeing in the range of ~30watts, the gain is about 1/3 on those guys.
and my mids are seeing close to 100W i have the gain almost maxed out. I hope to soon be running the mids bridged on the 4 channel and put the tweets on a smaller amp.
Old Mar 17, 2009 | 06:05 PM
  #116
VTonmymind's Avatar
Mmm, fresh lobster
Aye. My Eclipse has the same capability so I'm gravy in that department...good news then...sounds like 75 watts to each might do alright after all too. Nice.
Now I just gotta figure out how to do it.
Old Mar 17, 2009 | 08:59 PM
  #117
you do know i have to hear this right?
Old Mar 17, 2009 | 10:34 PM
  #118
of course man
might be able to come to your neck of the woods this weekend
Old Mar 17, 2009 | 10:36 PM
  #119
it was pretty easy for me.
got alot of info form soundsolutionsaudio.com
i pretty much have the same setup as one of the guys on the forum.
my mids are 8ohm so they need more power, thats y i wanna bridge them
Finkle
Sep 27, 2015 09:53 PM
JoeWhit
Sep 20, 2015 08:01 PM
tgreen
Aug 27, 2015 08:34 PM
wellz
Aug 26, 2015 09:05 PM
Slamrod
Aug 10, 2015 12:33 PM
