BASS help :(
Old Jul 26, 2009 | 06:58 PM
colinod's Avatar
BASS help :(
In my 94 maxima, I have 4x6s up front and 6.5s in the rear
I wouldn't prefer to go with an amp+sub setup because of trunk space issues and budget concerns, even though admittedly the weight dist. change would give more entertaining handling dynamics.
I do not listen to songs where bass is emphasized, but sometimes I have to turn the bass gain into the negative to avoid crackling from the rear speakers. This would lead me to believe the stock amplifier biases the bass to the rears.
So would mounting two 6.5 subwoofers on the rear deck, replacing the 6.5 speakers do me any good?
Old Jul 26, 2009 | 09:50 PM
AscendantMax's Avatar
are you still using original gear or aftermarket stuff? when i still had my 3rd gen, i had some baffles to fit 6.5 coaxials in the front doors to replace the 4x6. it sounded much better and didn't distort as easily.
Old Jul 27, 2009 | 01:19 AM
colinod's Avatar
6.5 infinity reference in the rears
4x6 pioneers in the front.
I have no issues with the front though
Old Jul 27, 2009 | 12:00 PM
djfrestyl's Avatar
Suspension Yoda
Are your speakers amplified?
Also, stock amplifier? In a 94?
Old Jul 27, 2009 | 12:19 PM
nismos14's Avatar
§è~® f®ÈÄk
Must have had bose.
Old Jul 27, 2009 | 12:26 PM
djfrestyl's Avatar
Suspension Yoda
So, Bose amp, aftermarket speakers, sounds like garbage. Wonder why...
Old Jul 27, 2009 | 01:24 PM
nope, no bose if the front are 4x6's. bose came with 4" rounds.
Old Jul 27, 2009 | 01:33 PM
djfrestyl's Avatar
Suspension Yoda
Well then it's no wonder why the speakers are distorting without an amp.
Old Jul 27, 2009 | 01:44 PM
yep, something isn't adding up. his aftermarket HU should be able to get those speakers fairly loud.
Old Jul 27, 2009 | 01:45 PM
colinod's Avatar
So replacing the stock amp would solve all problems?
Wait the stock amp is actually getting in the way of my aftermarket HU?
My HU is a Jensen VM9313
Old Jul 27, 2009 | 01:46 PM
djfrestyl's Avatar
Suspension Yoda
First you have to determine if there IS a stock amp.
Old Jul 27, 2009 | 01:50 PM
colinod's Avatar
So no stock bose, no stock amp?
It's a 94 GXE with "Active Sound"
Old Jul 27, 2009 | 01:53 PM
i'm almost certain you don't have the bose...and yeah it does say' active speaker' on the factory grills.
IIRC there IS a stock amp under the rear deck. but you can just bypass it. me thinks that amp is blown.
Old Jul 27, 2009 | 01:54 PM
colinod's Avatar
Well it's a little hockey puck stuck on the underside of the rear deck that says amplifier lol
Old Jul 27, 2009 | 01:55 PM
colinod's Avatar
Oh alright, then I can actually get bass out of the rear speaker without crackling?
Old Jul 27, 2009 | 03:16 PM
yeah i think so. just run the speaker leads directly from your head unit's harness to the speakers. you'll have to snake some wires through your car to make it work, but it'll be worth it.
Old Dec 2, 2010 | 12:36 PM
colinod's Avatar
I upped the bass setting and the wattage supply on the head unit, and miraculous melodious bass poured out of my rear speakers... Sounded like I had 2 10" subwoofers in my trunk
Now since I totalled the maxima's front suspension, the Head unit crapped out so I will have to replace it .
But it's nice to know now I won't need a pricey amp and subwoofer setup!
Old Dec 2, 2010 | 12:42 PM
djfrestyl's Avatar
Suspension Yoda
Well, this is an old thread.
How exactly did you "up the wattage supply" on the head unit?
Where are you located? I do audio and suspension installs for org members.
Old Dec 2, 2010 | 01:40 PM
nismos14's Avatar
§è~® f®ÈÄk
Oh EM GEE your rears sound like 10's? WTFBBQ.
Old Dec 2, 2010 | 03:19 PM
ctsmith39's Avatar
Old Dec 3, 2010 | 06:43 AM
colinod's Avatar
I upped the built in amplifier in my headunit. I wasn't correct saying I upped the wattage
Old Dec 3, 2010 | 06:45 AM
nismos14's Avatar
§è~® f®ÈÄk
Yea? How'd ya do that?
Old Dec 3, 2010 | 07:52 AM
colinod's Avatar
Its sounds very bassy enough to resonate your eardrums. Its a classy sort of bass
Old Dec 5, 2010 | 03:54 PM
Car Addict's Avatar
Hope you didn't put the radio on the "loud" setting.
Old Dec 7, 2010 | 09:17 AM
bassy enough to resonate your eardrums...?
Mar 12, 2020 12:06 AM
vybz05
Dec 10, 2015 07:38 PM
popdedop
Sep 11, 2015 11:17 AM
Cincy94Max
Feb 23, 2001 05:57 AM
Nick97SE
Dec 16, 2000 02:52 PM
