09 max power wire run
Old Aug 22, 2009 | 11:48 AM
Sagaboy3's Avatar
Hello
I have install a few systems
in my day but for the life of me
I cant find a grommet or way of
passing the 4g from engine bay to
truck please help
sagaboy3@hotmail.com
Old Aug 22, 2009 | 11:52 AM
AscendantMax's Avatar
i just drilled in my 06 below the master cylinder. it made things a ton easier to run my 0awg.
Old Aug 22, 2009 | 12:28 PM
Sagaboy3's Avatar
did you seal it anyleaking ?
Old Aug 22, 2009 | 12:58 PM
nope no leaking. i bought one of those locking grommets that grabs on and secures the cable. it's a watertight seal.
http://www.hifisoundconnection.com/S...id/0/SFV/30046
the grommet is secured onto the firewall, then when you pass the wire through, you tighten the larger **** and it'll grab onto the power wire.
Old Aug 22, 2009 | 04:01 PM
travis1129's Avatar
you can ether drill a hole and get a grommet for like ascendantmax is talking about, or the way i do mine is run them completely under the car and sucure them with brackets, but since your only running 1 4g it probably be easier to drill a single hole, just another suggestion on how you could run it
Old Aug 23, 2009 | 12:10 PM
Sagaboy3's Avatar
i sure hope i dont hit any wires drilling this car
7/8s its a large hole they are requiring for that grommet
Old Aug 26, 2009 | 11:03 AM
i used a step bit to drill the hole. it made the edges nice and clean. but yes, make sure you look under the dash so you don't hit any lines. i had an empty clutch plate that was perfect for drilling.
vybz05
Dec 10, 2015 07:38 PM
conansriver
Sep 3, 2015 06:38 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
