Need help installing new HU
Old Aug 17, 2010 | 02:45 PM
Spyguy's Avatar
1999 Maxima SE with Bose.
So my Bose HU died and I happen to have an old aftermarket HU lying around. It is the JVC kd-s580. The bad thing is that it only has pre-amp outputs for 2 rear speakers. I bought the antenna converter, the metra console kit, and the metra wire harness with 4 RCA plugs. I was able to convert the front channel RCA plugs to wires with some of the RCA jacks that I had in my parts bin. I hooked everything up and I was left with the following wires unconnected:
From the metra connector:
Power antenna
Amp Turn-on (Amp Ground cable is grounded)
Illumination
Dimmer +
Dimmer -
Phone Mute
From the HU connector:
Right Rear +
Right Rear -
Left Rear +
Left Rear -
Power antenna
NONE of my speakers do anything, but my HU turns on and functions properly. I would at least expect something from the rear because it is plugged in directly from the preamp outputs but no.
Do I need to hook the Amp-on wire to something? It seems like the only possible answer to me.
Old Aug 18, 2010 | 04:38 PM
DcMaN's Avatar
yes the amp/remote turn on needs to be connected. Otherwise you will get no sound output.
Old Aug 18, 2010 | 05:24 PM
Spyguy's Avatar
Thank you.
Mods please close.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
