this is pissin me off
Old Nov 4, 2010 | 08:18 PM
Mistah_M's Avatar
alright so when i got my max the radio didnt work. swapped it out wit an alpine n wired the bose wires to it. everything works right. hooked up my amp and for some reason wont work. rca's goin to the H/U , power is right, grounded right, everything is right. but nothin wud come out of my subs. my friend hooked my subs up to his amp and they worked. he thought my amp was blown. so he gave me another one and i can see power is gettin to it but its not turnin on. **** is pissin me off. i need some help wit this one.!!
Old Nov 4, 2010 | 08:20 PM
importcf's Avatar
sub out off on the HU?
Old Nov 5, 2010 | 05:48 AM
nismos14's Avatar
§è~® f®ÈÄk
If everything is right, maybe there's some installer error. You can also turn the sub on on the HU as mentioned, if it's not. Also you may have the amp hooked up to incorrect outputs of the HU, lastly, if you can't figure it out perhaps take it to a pro?
Old Nov 5, 2010 | 06:39 AM
tigersharkdude's Avatar
IDK if this helps but did you leave the stock bose amps in place? Did you bypass bose or leave it place?
Old Nov 5, 2010 | 07:31 AM
mrfliboi's Avatar
on ur head unit you probably have a sub on and off setting.. if that helps.. i had a similair issue.. and i have a alpine head unit
Old Nov 9, 2010 | 08:16 AM
Mistah_M's Avatar
i went through the headunit and turned on the sub from there. only thing im thinkin is the remote wire. becuz the amps not turning on. but the light to say its protected is on. i really dont wanta take the headunit out again **** is annoyin as hell.
Old Nov 9, 2010 | 08:19 AM
nismos14's Avatar
§è~® f®ÈÄk
Protection light = amp is bad or fuse is blown.
Old Nov 9, 2010 | 10:51 AM
mendon99's Avatar
tastey wheat
or a bad sub (ie, coil is ground out)
Old Nov 9, 2010 | 06:34 PM
Mistah_M's Avatar
ya my boy was sayin the amp cud be blown. but ik the subs work we hooked it up to his amp and that **** bumped. i think ima jus have to bring it to a shop.
pitman
Jan 16, 2015 07:14 AM
greaseyoda
Sep 16, 2014 12:35 PM
tooreckless00
Sep 16, 2009 09:51 PM
XeroX
Jun 24, 2008 05:38 PM
speedfreak4996
Apr 2, 2007 08:02 AM
