LED for stock NON-Bose in a 4th gen?
Old Feb 16, 2012 | 11:39 AM
Amerikaner83's Avatar
Hey y'all, was wondering if anyone knew how to LED the NON-Bose stock HU in a 4th gen? I have to take apart my dash trim this weekend to LED my shifter and was wondering if anyone knew which LEDs I could throw in to the stock HU. I am not a fan of the faint green color...so I want to get cool white if possible.
Anyone know off-hand?
Also, can the "change clock color by red cellophane" mod be done to the HU as well to change color output of the display?
Old Feb 17, 2012 | 03:04 PM
NOBODY?
C'mon
Old Feb 17, 2012 | 08:38 PM
AscendantMax's Avatar
I dont think I've ever heard or seen someone swap out the LEDs in their factory radio before...
Old Feb 17, 2012 | 09:02 PM
come on, I can't be the only one here! I mean, the factory radio isn't anything all that fancy but it beats a couple hundred for aftermarket...I just hate that green and am in the process of changing interior to cool white LEDs
Old Mar 13, 2012 | 05:58 PM
Digitized's Avatar
I am actually wanting to do that too to my stock HU.. but unsure if I have to solder resistors to the new LEDs
*** i think I found what we were looking for**
http://forums.maxima.org/4th-generat...heir-bose.html
Old Mar 13, 2012 | 06:35 PM
Forgot about this thread! Lol
I figured it out last week...I ended up using the 360* 5mm white LEDs and a resistor, soldering to the board. Here's my little writeup on the interior led thread:
So this one is actually a bit more of a ***** than I expected it to be...not a "skip lunch and get it done" like I thought.
^^ This ^^ is what my factory PCB looks like. I circled the little bulbs (6 of them)...don't worry about the missing one top right corner, I removed that one already. These are little incandescent light bulbs, NOT LEDs as I had hoped. Just makes it a bit more time-consuming, that's all.
I have both 5mm 360* white LEDs as well as regular 30* 3mm white LEDs...I am not sure which ones to use. I'm going to try and use the 5mm 360* LEDs but if space is tight, I'll have to use the smaller ones. BUT a bit if good news: since these all have the little bulb condoms on them I won't have to worry about shoosing white or blue I can pull the little covers off if I want the change
Will edit this post with process as I go along.
EDIT 1:
Here is the thing with all the LEDs + resistors installed. VERY tight squeeze with the light diffuser when the faceplate goes on, but first, before the faceplate, we need to plug it in and make sure they work. The red on the VFD is just sharpie...I'm at work right now and I left my cello paper @ home.
...aaaand all lit up:
I removed the red sharpie since it didn't do well at all with regard to readability... will just throw cello paper on when I get home.
very carefully put the faceplate on and re-test with 9V battery to pwr and ground pins, all looks good, with a nice blue coloring to all the buttons... (No pic since I did this when I wasn't on a break - don't tell my boss)
ok, fine...quick pic:
Contrary to how it looks, all of the buttons are nice and evenly lit up in a shade of blue that's perfect! Can't wait to see it in my dark garage when I get home.
This is about as good as it's going to get taken here @ work... Never realized how light it actually is in here until I want it dark...I always thought it was pretty dark in my little corner...
Old Mar 13, 2012 | 06:38 PM
Finished the LED interior...got her all buttoned up again.
^^ Center console (Radio with white LEDs+blue bulb covers=nice faint blue backlighting)
^^This stuff is GREAT!!!!! For changing the clock color. None of that cello paper crap LOL
^^Blue filter from LEE Filter media shown above, in radio display
^^ Slightly darker blue filter from LEE media shown above, in clock.
Changed out shifter LED from the bright blue to a less-bright white. Goes better with the subtle-blue of the radio. Mee likey!
That's from afterwards and when I got it how I liked it.
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
spidgeon
Aug 18, 2015 05:46 AM
